Power BI and Jamf pro token authentication
  • Jun 4, 2024 2:28 PM UTC
  • 5 replies
  • 235 views
n_lecchi
Jamf Pro 11.5 has disabled classic API authentication by default, but soon it may be removed altogether. If you are interested in integration with Power BI, please visit this link and vote for integration.
https://ideas.fabric.microsoft.com/ideas/idea/?ideaid=1d1acbef-5e21-ef11-8ee8-000d3a7c8d70
  • Jun 13, 2024 2:16 AM UTC
Take a look at this; I am currently in the process of changing my dashboard to use this method, which requires some massaging of data but will provide you with greater scope on the data you can pull from Jamf.
 Unlocking Insights: An Introductory Guide to Integrating Jamf Pro and Microsoft Power BI for Powerful Reporting - The Geeky Gordo
DrumBum213
  • Aug 7, 2024 12:32 AM UTC
I am not following you on the setting the ClientID and ClientSecret parameters. Should they both be filled with the secret code? I got this when I put the secret in both parameters... "Expression.Error: The import paramClientID matches no exports. Did you miss a module reference?"
  • Aug 7, 2024 12:59 AM UTC
Hi, just a disclaimer this is not an article that I published but one that helped get things going again. But for you question the "paramClientID" PowerBI variable should match your API account in Jamf ClientID and the paramClientSecret should match your Jamf API Client Secret.
DrumBum213
  • Aug 8, 2024 7:38 PM UTC
Ok I am now up to the section after Privacy levels and I get "Please specify how to connect." Edit Credentials and cannot advance any further.
Tim Hedge
Client Engineering Senior Manager
Global Information Technology
[Newell-logo-color]
Better Together
Mobile: +1 (931) 205-4172
Office: +1 (931) 685-6683
Tim.Hedge@Newellco.com
www.newellco.com<>
*Please consider your environmental responsibility before printing this email*
  • Jan 13, 2026 2:00 PM UTC
Hello,
You can use this guide :
powerbi/Jamf PowerBI Basic Installation Instructions for PowerBI Desktop.pdf at develop · jamf/powerbi · GitHub
It works with basic authentication (user/password)
