PowerShell Script
KyleEricson
Does anyone have a simple PowerShell script to delete a device out of Jamf via device serial number? I have a Mac sh script with curl, but need this in PowerShell.
Best answer by koalatee
Invoke-RestMethod -Uri $JAMFAPIURL/computers/serialnumber/$SERIALNUMBER -Credential $Creds -Method DELETE
Forum|alt.badge.img+31
  • October 8, 2019
I do not use PS for this but I would look at Invoke-RestMethod cmdlet. You should be able to use it in the same method you use curl
  • October 8, 2019
KyleEricson
  • October 9, 2019
@koalatee How are you do the creds variable I get a 403 error?
I tried $CREDS= Get-Credential
I then type in my username and password just like I was logging into the Jamf pro console.
  • October 9, 2019
Oops, I edited the line to remove a faulty quote at the end of $SERIALNUMBER
But using Get-Credential works.
KyleEricson
  • October 9, 2019
@koalatee I get this error
Invoke-RestMethod :
   Status page
Not Found
The server has not found anything matching the request URI
You can get technical details here.
Please continue your visit at our home page.
KyleEricson
  • October 9, 2019
my URL: https://mydomain.jamfcloud.com/JSSResource/computers/serialnumber/$SERIALNUMBER
KyleEricson
  • October 9, 2019
I got it figured out. Thanks
  • October 9, 2019
@kericson Just because I am curious and was following your post how did you finally get around it?
Cookie policy
Cookie settings
