Problem with IOS Home Screen layout configuration
  • Dec 12, 2023 9:02 AM UTC
  • 124 views
Pshen
Hello, I encountered a problem that is not allowing me to add apps in "Home Screen Layout" configuration. I click "add" and select the app, after I try to add another one nothing happens, and it disappears after saving. New blank configuration without pre-settings. Can you help with it please?
  • Mar 1, 2024 4:35 AM UTC
Hi, I have exactly the same issue. Is there anyone knows the solution?
  • Mar 7, 2024 12:15 AM UTC
After adding an item, hover your mouse over the item you just added then scroll to the right hand side. You will see the a save button there.
That design is not helpful. It took me a while to find out.
