Problems editing posts?
  • May 25, 2023 12:18 PM UTC
  • 12 replies
  • 109 views
sdagley
Anyone else seeing a problem where the Edit option isn't available for posts you've made? I've now seen it on multiple posts I've made in the past couple of days and I'm wondering if I have company.
mvu
  • May 25, 2023 12:52 PM UTC
Just checked: I don't see the Edit button either. Using Safari/Ventura latest.
sdagley
  • May 25, 2023 1:06 PM UTC
I'm also a Safari user, so tried Chrome and the Edit button is missing there as well. Sounds like a borked forum software update
  • May 25, 2023 7:56 PM UTC
Posting a reply just to see if I can edit it.
Edit: I can edit. The edit is still showing up for me under the down arrow. Maybe they fixed the issue already?
Edit 2: Forgot to mention, this is using Google Chrome. I didn't test with other browsers.
JustinV
  • Employee
  • May 25, 2023 7:58 PM UTC
Hey all, We have limited the time to edit posts to assist with backend management. I understand how this may wrench your plans to update your post. We can do one of two things. I can edit the post for you, or you can post on the post thread with an update. Thanks for working with us on this solution!
- Justin
sdagley
  • May 25, 2023 8:05 PM UTC
- Justin
@JustinV What is the threshold for losing the ability to edit a post? I don't think it had been more than 15-20 minutes since I had originally posted a reply this morning when I wanted to clarify something and realized the missing Edit button I'd seen yesterday wasn't a fluke.
JustinV
  • Employee
  • May 25, 2023 8:08 PM UTC
Hey @sdagley, I will reach out directly.
  • May 25, 2023 8:09 PM UTC
- Justin
So what is the time limit now? It would be nice to know.
  • Feb 27, 2025 5:38 AM UTC
- Justin
Can we delete a post and start over if we have made a typo?
Mitchell_Gordon
Hello @alstalent I can edit or delete anything for you on Jamf Nation!
Please let me know by sending a dm or email to jamfnation@jamf.com I can get something changed/deleted for you!
  • Mar 6, 2025 5:44 PM UTC
- Justin
Hi Justin I have a post I just submitted yesterday that I need to edit or to please just have deleted so that I can resubmit. The title is Blank White Box Appears When New Okta Users Sign in via Jamf Connect Before MFA Enrollment. It is my first and only post so should be easy to find. If we can please delete it, I can just resubmit it as new. I would appreciate it. I noticed right away I did not have any options to edit or delete even just 7 minutes after submitting. I appreciate it please let me know if there is anything else you need from me.
Mitchell_Gordon
Hello! @cduran I was able to make an adjustment to your post and replied to your email that was sent to jamfnation@jamf.com I hope this was completed correctly for you!
  • Mar 7, 2025 4:12 PM UTC
Hi Mitchell, Yes thank you so much for that the corrections are all there. I appreciate the speedy response and assistance with this. Much appreciated!
