If you're running this at login you can use $3 for the logging in user.
You shouldn't need the su
part for a defaults read.
@swaroopmj you are also missing the grave ticks to make your currentuser call work:
currentuser=`/bin/ls -la /dev/console | /usr/bin/cut -d " " -f 4`
defaults read /Users/$currentuser/Library/Preferences/com.apple.dock | grep corner
Grave ticks are on the tilde (~) key.
No, I don't think he was missing the grave marks. The forum treats them as the single line code
formatting from Markdown, so they don't appear in the post. The way to preserve them is to wrap the entire script in the script code with ``` at the start and end.
Ah, yes, I see what you mean @mm2270 . My mistake.
Changing the defaults read line to what I have there should work. At least it did in my quick testing.
Yes, thats right. Since the logged in user name is being grabbed, there's no need to run the command as the user. Just do a default read against the user's plist file. Its being run as root so it won't have a problem reading a plist from a user's home directory. So both @davidacland and @stevewood have the right answer for you.
Thanks for the quick reply @stevewood and @davidacland
I'll explain my problem a little more. I'm implementing the CIS benchmarks for hot corners. One of them is to ensure that the user never sets a hot corner to disable the screensaver. So I've to ensure that none of the corners have a value of 6. I've two problems when I use the command in the script above
1. The default file permission for com.apple.dock.plist is rw-------. So I cant even read the file as a different user
2. I do intend to run this script with a Login hook. The policy still runs under the jss management account on the box. So unless I can run a chmod to allow read on the plist, I wont be able to read/write into the plist if I do find the value 6.
I'm new to JSS and maybe there is an easier way to accomplish this? Also, in the actual script I do use the ` key.
Unless I'm mistaken, running as root you should be able to read that plist file even if it is set to 600. So using the defaults command as @davidacland and I mentioned, should work.
@swaroopmj The JSS runs scripts as "root", so it can in fact read into another user's plist file without issue. The only problem you may run into is if your script is making changes to another account's plist files, you'll probably to make sure to set the permissions on the plist file after the write is done so the account can read it. Generally speaking, when a defaults write
command is done under the root context, root becomes the owner of the file and is typically the only account that can read it back, meaning the user's account will ignore the preference at login since it can't read the contents.
You can fix this by adding something along these lines after you make the change to the plist:
chown $currentuser /Users/$currentuser/Library/Preferences/com.apple.dock.plist
chmod 600 /Users/$currentuser/Library/Preferences/com.apple.dock.plist
You may want to try …
sudo -u $currentuser /usr/bin/defaults write /Users/$currentuser/Library/Preferences/com.apple.dock.plist
… which theoretically shouldn't hose the user's permissions.
@swaroopmj You need the -l flag for your su command, and the pound sign for your shebang line. Try this:
currentuser=$(/bin/ls -la /dev/console | /usr/bin/cut -d ' ' -f 4)
su -l $currentuser -c "defaults read /Users/$currentuser/Library/Preferences/com.apple.dock | grep corner"
Then chmod/chown as needed.
So, I ran the chown and chmod in the end to make sure the plist file has the same permissions as it did before. My output says the file permissions were set right. But I see the hot corner still set to old value in the new file. The default write was suppose to set the value to 0 instead of 6. Seems the plist gets overwritten by whatever the values were before.
@jholland That fixed my problem. Thanks a lot everyone.
@swaroopmj - I'd be curious to know what you find in your results on this one! I've thought about that too, and it seems folks have not figured out that little work-around...
@scottb Not sure I follow the question.
@swaroopmj -
Just curious to see how many clients know to use this to bypass the setting to avoid being sent to screensaver...
Oh ok. I don't have any hard data on that. But I work in Finance and Insurance sector so it is a mandatory thing to implement irrespective of how many know how to do bypass it.
I just remembered that a long time ago I worked on something similar, but my approach was a bit different. I had created a combination LaunchAgent and script if my memory serves. The LaunchAgent would detect changes to the dock plist or something like that, and would fire a script that checked if hot corners had been enabled and would disable them if so.
I honestly can't even remember now why I worked on that. It must have been a possible requirement for us to prevent those settings from being changed or something, but was later dropped.
But to back up a sec, have you looked at the possibility of a Configuration Profile for this? If you can get your settings as you want them, you may be able to use mcxToProfile to convert it into a user level profile that would apply the settings and lock them into place, but I'm just guessing since I can't say I've even tried doing it that. Might be worth exploring though, instead of mucking around with repeatedly run scripts.
@jholland your post in this thread solved a very frustrating issue I've been having with a user-context based install/agent. Wish I'd found it in earlier searches and saved more time, but I thought you deserved a shoutout/thanks as I was putting together some pretty rube goldberg type stuff to try to accomplish the installation.
So I'm trying to run a command as the logged in user at login with Jamf 10.8 on high sierra (10.13.6) but I'm noticing that the
currentuser=$(/bin/ls -la /dev/console | /usr/bin/cut -d ' ' -f 4) is getting root and not the user who is logging in.
This does not happen on macOS 10.12.
When running this from a terminal window using sudo jamf policy -event login it works fine and gets the correct user.
Any ideas?
Update: turns out you have to have login logout hooks set to preform in the background
https://www.jamf.com/jamf-nation/discussions/9360/login-script-command-run-as-user-not-working-anymore
Hi @mm2270
I have a script that must be run as user. I'm trying to create a launch demon to call it but when I run it using launchctl load -w My daemon path nothing happens.
I've placed the daemon and script under ~/Library/LaunchAgent/
I've also chmod 755 both files
The Daemon is:
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.zerowidth.launched.run_data_science_bash</string>
<key>LaunchOnlyOnce</key>
<true/>
<key>ProgramArguments</key>
<array>
<string>sh</string>
<string>~/LaunchAgents/Data Science/Datascience_High_Sierra.sh</string>
</array>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
Any idea what am I missing!
@Buraq I think one issue is probably the POSIX permissions. LaunchAgents and LaunchDaemons are supposed to be set to 644, not 755. The script/program it runs can be set to 755 though.
Second, I would consider putting the script in some other more general location than in the ~/Library/LaunchAgents/
folder. While it might work from there, a better place might be in /Users/Shared/
for example, or even in some more hidden location, like /private/var/
Third, are you wanting the LaunchAgent to only run when the one account logs in, and not any other accounts? Because putting it into ~/Library/LaunchAgents/
for the current user means no other accounts will have that run. If you want it to run when any account logs in, it should go into the higher level Library folder, meaning /Library/LaunchAgents/
Outside of these things, I can't say I've looked over your agent plist very carefully. There could be a formatting issue with it, but I don't know without bringing it into another program to check it.
I see a space that isn't escaped
edit @Buraq
@cdenesha If you're referring to this section:
<array>
<string>sh</string>
</array>
Believe it or not, paths to executables or scripts in the Program or ProgramArguments section of a launchd plist don't need to be escaped. Here's an example from the Box.com Helper LaunchAgent. Notice the three different spaces in the path for the program arguments string. Yet it still works.
<dict>
<key>Label</key>
<string>com.box.desktop.helper</string>
<key>LimitLoadToSessionType</key>
<array>
<string>Aqua</string>
</array>
<key>Program</key>
<string>/Library/Application Support/Box/Box/Autoupdater/Box Helper.app/Contents/MacOS/Box Helper</string>
<true/>
<key>KeepAlive</key>
<true/>
</dict>
</plist>
@mm2270 Thanks for your reply!
I've just set the permission of the Agent to 644, but same blank result when I launchctl load -w MyAgent
You are right in this should be only run for the current user therefore I guess the path is ok.
Any thoughts?
