Set LocalHostName using scutil - errors - problems with hidden and illegal characters
  • January 3, 2022
  • 0 views
I know there are a number of other posts related to setting up your Macs with a script that does something like:
# newHostName="$smallImportantStr0-$smallImportantStr1-$smallImportantStr2"
# scutil --set ComputerName "$newHostName"
# scutil --set HostName "$newHostName"
# scutil --set LocalHostName "$newHostname"
Only I encountered errors setting LocalHostName. Sure there is another way to do it (see the command systemsetup -setlocalsubnetname) but that doesn't fix the errors.
After quite a bit of checking the syntax and strings involved, I discovered that my $newHostName string had a new line buried in it and macOS was just not having it.
LocalHostName is fussy and there are a bunch of illegal characters that generate errors.
The errors didn't show up when I entered the command manually because I used copy and past to put in the string, which necessarily dropped the hidden [and illegal] characters.
This took me a while to figure out, so I thought I would leave this hint for you....
I was able to fix it by cleansing my string with the following command(s):
newName=$(echo "$smallImportantString0-$smallImportantString1-$smallImportantString2" |  tr '[a-z]' '[A-Z]')
NewHostName=${newName//[$'\\t\\r\\n']} && NewHostName=${NewHostName%%*( )}
My clean up process is perhaps not elegant, but it worked...  Like almost everything in bash, there are many ways to accomplish a given job.
Reference:
https://stackoverflow.com/questions/19345872/how-to-remove-a-newline-from-a-string-in-bash
Forum|alt.badge.img+15
  • January 3, 2022
I've found on macOS 12 that you need a short pause in between scutil commands to set the names.
scutil --set ComputerName "${computerName}" sleep 1 scutil --set LocalHostName "${computerName}" sleep 1 scutil --set HostName "${computerName}" sleep 1
Cookie policy
Cookie settings
