Setting / Verifying Mac SUS problem...
I've set up a Software Update Server and pointed clients at it in the JSS. This seems to work fine on most clients, but on a few it's still going to Apple / App Store for updates.
if I run the command to check where it's pointed:
sudo defaults read /Library/Preferences/com.apple.SoftwareUpdate CatalogURL
I get this response every time:
The domain/default pair of (/Library/Preferences/com.apple.SoftwareUpdate, CatalogURL) does not exist
This is on El Cap and Yosemite clients. Not sure if it's something wrong with that command, I'd expect it to return something?
Best answer by davidacland
That response means the value isn't set, which is the case on my Mac so I would assume that means "get updates from Apple".
How are you setting the SUS address? Are you able to verify if the setting has been applied to all devices?
davidacland
  • June 14, 2016
  • June 14, 2016
Thank you for responding David.
I've established the cause and rectified it now - my colleague had deployed via a policy applied to a smart group. The criteria needed tweaking to include the affected Macs.
