Using Jamf's built-in CA for certificate based Wifi authentication
  • Mar 18, 2026 1:06 PM UTC
  • 8 replies
  • 393 views
KeremDurdabak
Hi everyone,
We have a WPA2/WPA3-Enterprise network, and I am wondering if it is possible to use Jamf’s built-in CA to push certificates to end devices, so that users can be authenticated for Wi-Fi using those certificates.
Additionally, what is the typical approach for this setup? I see docs recommend using AD CS, but our organization uses Azure rather than on-premises Active Directory.
I would appreciate any guidance from someone with experience in this area. Thank you.
Chubs
  • Mar 18, 2026 1:10 PM UTC
What are you using for RADIUS auth?  I’m pretty sure you don’t want to use the built-in CA for anything other than device communication to the binary.
If you want to move to the ACME protocol, check out Small Step for this.  If not, use jamf as a SCEP proxy and go to something like digicert.  If not either of those, then stand up ADCS and host your CA on prem and go that route.
peterlbk
  • Mar 18, 2026 2:25 PM UTC
`Hi ​@KeremDurdabak you can, but it is not easy to accomplish and has some pitfalls. Usually you use a pki server set up to maintain certificates.
KeremDurdabak
  • Mar 18, 2026 2:32 PM UTC
Hi, if the Jamf’s built-in CA is not recommended, I was wondering what would be the costless and jamf friendly solution to this. Thank you.
peterlbk
  • Mar 18, 2026 2:41 PM UTC
Well if you can find any free PKI server, that might do the trick. Or the other solution chubs refers to, that jamf step proxy
dletkeman
Forum|alt.badge.img+19
  • Mar 18, 2026 2:55 PM UTC
What are the pitfalls?  I know my network admin has talked about doing this.  Right now we use WPA2-Enterprise but we have certificate based networking with our Windows computers.  I’m not a certificate master but there’s been dragging of heals about using SCEP.  I don’t know why, but my network admin has wondered about using Jamf built-in certificate too.
peterlbk
  • Mar 18, 2026 2:57 PM UTC
Well for instance you jamf certificates expire after a rather short time, so you need to script to refresh your eap settings and trust. And that trust setting is not easy to manage properly.
And expired jamf certificates block a Mac from network - you may want to send it to a guest network or something. Else you may need to run around a lot to find those Macs
Chubs
  • Mar 19, 2026 12:20 PM UTC
If you’re already a MS shop, a “cost effective” way is to host your PKI on site. Keep in mind, this is just up front cost. Maintenance costs over time will rat you alive.
Also certificate distribution using this method is only valid on premise. If you have a modern workforce and need to distribute certificates for other things, then I’m still going to recommend a cloud PKI that will “cost you more” up front.
You have to weigh cost against product AND support. Not just product. Hopefully that makes sense.
… and I hope soon (very soon?) we will be moving to a mTLS world where there will be no more passwords, only certificates.
  • Mar 21, 2026 4:18 PM UTC
+1 to what Chubs said — Jamf’s built-in CA is great for Jamf-to-device trust, but it’s a pretty painful CA to base 802.1X/EAP-TLS Wi‑Fi access on (shorter cert lifetimes, renewal/"what happens when it expires" workflows, etc.).
Typical “Jamf-friendly” pattern for cert-based Wi‑Fi is:
1) Pick a real PKI/SCEP source (on‑prem AD CS, or a cloud option like SCEPman / Smallstep / managed CA).
2) Deploy the **issuing chain / root CA** to devices.
3) Use **SCEP** to issue a client cert (per user or per device).
4) Push the Wi‑Fi payload configured for **EAP‑TLS**, referencing that client cert + trusted RADIUS server cert/CA.
If it helps, this write-up shows the moving pieces for macOS + SCEP (and where the Wi‑Fi bits fit in): [Configuring a RADIUS Policy for macOS (with SCEP)](https://help.swif.ai/en/articles/10872835-configuring-a-radius-policy-for-macos-with-scep)
If you share what you’re using for RADIUS (NPS, ISE, Aruba/ClearPass, etc.) and whether you want user certs vs device certs, people can usually point you at the least-painful option.
