What facilitates package removal in Jamf Pro?
  • Jul 10, 2017 9:00 PM UTC
  • 33 views
Hey all,
I've used JAMF's built in uninstall option (indexing package in Casper Admin <> selecting Allow package to be uninstalled) but does anyone know how JAMF actually facilitates the uninstall? Is it just looking at the BOM in /private/var/db/receipts and removing the listed items?
1 reply
Stevie
  • Jul 11, 2017 7:10 AM UTC
Hello,
I use a script with each and every install to clean up old receipts. I also use smart groups for application versions so if a user upgrades to the latest version outside of JamfPro this script is run once to clean up any cached packages and old receipts.
I set parameter 4 as "ReceiptName" and parameter 5 as "PackageName"
I sure a few people online can improve on this script.
Steve
if [ "$4" != "" ]; then
    ReceiptName="$4"
    echo "Receipts paramater 4 was empty. This needs to contain the full receipt name. Exiting..."
    #ReceiptName="com.google*"
    exit 1
if [ "$5" != "" ]; then
    PackageName="$5"
    #PackageName="GoogleChrome"
    exit 1
# Remove System Receipts
echo "Removing Receipts"
receipts=$(pkgutil --pkgs=$ReceiptName)
for areceipt in $receipts
do
    pkgutil --forget $areceipt
done
# Remove Jamf Receipts
echo "Removing Casper Packages"
IFS=$'
receipts=`mdfind -onlyin /Library/Application Support/JAMF/Receipts/ "kMDItemContentType == 'com.apple.installer-package-archive'" | grep "$PackageName"`
echo $receipts
do
echo $areceipt
    rm -Rfd $areceipt
done
