Wifi and Configuration Profiles auto-join
  • Jun 16, 2020 5:14 PM UTC
  • 5 replies
  • 155 views
So I have a provisioning sequence that happens to all mac enrolled via DEP. The issue is once the configuration profiles that installs the WiFi 802.1X certificate is also set to auto-join and it breaks the continuation of the installation of the reset of the applications. I was wondering if any one has any suggestion that could assist me. I need to auto-join at some point to the WiFi network. Thanks
  • Oct 26, 2020 9:10 AM UTC
Yup i've run into a similar issue especially on device we are re-enrolling that have existing JAMF computer records. JAMF is applying configuration profiles based on the old inventory data of the device, so even though i have the 802.1X profile scoped to smart group so it doesn't occur during enrolment it still gets applied. The funny thing is we don't see this is a more heavily loaded JAMF instance due to the performance of the platform.
  • Oct 26, 2020 11:49 AM UTC
https://www.jamf.com/jamf-nation/feature-requests/9840/802-1x-auto-join-profiles-break-jamf-enrolment-process
  • Nov 3, 2020 1:43 PM UTC
I found a workflow that works! extension attributes can be cleared at re-enrolment, i excluded all devices which had the specific attribute as blank. This bought enough time for that first recon to run and the correct scoping to apply!
krcbi2022
  • Nov 2, 2023 4:07 PM UTC
Hello @Key1, I know this is a very old post but I'm curious what you ended up using for a workflow to get around this issue.  We are seeing the same issue when our wifi profile is applied while enrollment and breaks delivery of jamf binary and self service etc.
  • Nov 2, 2023 6:50 PM UTC
I believe it was just as simple setting the re-enrollment setting to clear ext attributes and then if a ext attribute i know is never blank is blank excluded it from the profile this allows the first recon to run first before devices become in scope of the profile.
