Hello,
I have a bit of a conundrum here and I'll give a scenario:
A user that has an iOS device, managed via JAMF through DEP, forgets their password on the device.
In some attempt to 'fix' it, they reboot the device before calling support to wipe the passcode.
After the device is rebooted, it will NOT not attach to a wireless network until the user logs in.
But, if the user can't remember the password to log in, the device won't attach to the WiFi to talk to the MDM server and have it's passcode reset. As far as I know, nothing can be done until the device is manually wiped completely using Configurator. Is there any other way to get around this? Ideally, I'd like to have the device attach to a WiFi network after reboot BEFORE a user logs in.
As per this example, it's an iPad with iOS 10.3.2 on JSS 9.98
