Back at it again with a (potentially) useful script.
This script is designed to extract all of the system scripts from your JAMF server. Why do you want to do this?
- Make a backup of your scripts in case your existing backup files is missing/corrupted (or you don't have one!)
- You inhereited a JAMF server from another person, and this can do a "brain dump" so you can review the scripts.
- Why not? It is another example of what you can do with API scripts..
Source: https://github.com/ScottEKendall/JAMF-Pro-Scripts/tree/main/BackupJAMFScripts
Welcome screen
Process screen
Errors screen if problems found:
