Hello all
I am running into an issue where some machines do not have Securetoken, I have a script that seems to be working with M1 machines but not Intel machines. I tried uploading the script but it didn't show up right so its posed below
Script to assign SecureTokens:
START OF SCRIPT
###Admin credentials###
adminUser=$4
adminPassword=$5
###This will store the logged in user's name to a variable.###
userName=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "\\n");')
###This will prompt the user for their password and store it in a variable.###
userPassword=$(osascript -e '
tell application "Finder"
display dialog "Please enter your Computer password." with hidden answer default answer ""
set userPassword to the (text returned of the result)
end tell')
###Store the output of the sysadminctl command into a variable to use it for error handling later.###
output=$(sudo sysadminctl -adminUser "$adminUser" -adminPassword "$adminPassword" -secureTokenOn $userName -password $userPassword 2>&1)
###Error handling to see if the password entered is the same password used to log into the machine.###
###Searches for the output "Done". If this exist then the sysadminctl command will run.###
if [[ $output == *"Done"* ]]; then
###Command used to provide the user a secureToken. The admin user must have a secure token or this command will not work.###
###You can always check the JAMF policy logs to see if the user is experiencing an issue.###################################
###GUI dialog for the user.###
title='MacOS Secure Token'
osascript -e "display dialog \\"SecureToken has been assigned!\\" buttons {\\"OK\\"} default button \\"OK\\" with title \\"$title\\""
osascript -e "display dialog \\"The password entered did not match your password on this computer! Please quit and re-run the Self-Service policy to try again.\\" buttons {\\"Quit (Your password was not synced!)\\"} default button \\"Quit (No SecureToken Assigned!)\\" with title \\"$title\\""
END OF SCRIPT
I ran it on 5 M1 machines and it ran successfully and we were able to assign a secure-token to the user. But when I just tried on two intel machines and ran into this error, has anyone seen this error. Or does anyone know of a good way to assign secure-token to M1 and Intel machines
Error: "Script result: 0:274: execution error: Specified button does not exist. (-50)"
