We are imaging 10.8.4 onto new machines via NetInstall and have attempted to use Casper Netboot Automator Action (https://jamfnation.jamfsoftware.com/viewProduct.html?id=140&view=info) with the System Imaging Utility. Our resulting NBI does not have the expected results.
First, when the NBI is booted to, the user is prompt to sign in to an Apple ID (so we hit skip), then when the OS loads, Casper Imaging never opens. What's the deal? Is Casper Netboot Automator Action no longer supported? Is there a new version in the works? Do I have to manually install imaging and manually force it to open? How does one disable the Apple ID prompt?
