Posted on
11-24-2017
08:31 AM
- last edited on
03-04-2025
02:40 AM
by
kh-richa_mig
Ever since we upgraded to JAMF Pro ... 85% of my iPads Jamf is unable to remove the Activation Lock Bypass Code on Wipe command .... wondering if there would be a way to refresh this code. We also try inputting the code manually on the iPad to no avail.... always invalid code
Posted on 12-04-2017 02:18 PM
I too currently have at least one iPad that is refusing the bypass activation lock code that the device record gives in the JSS when I manually type it into the ipad during the setup process and I am also running Jamf Pro Version 10. Any work arounds or solutions?
Posted on 01-08-2018 01:27 PM
Same problem here and if you choose to wipe the device the bypass code in JAMF doesn't work to release the lock when you go back through the setup of the device.
Posted on 03-08-2018 11:55 AM
there are many, many, many discussions on this and everyone is asking the same question. the more people are commenting and keeping these at the top of the discussions list/in the feed, hopefully if there are 4 about the SAME THING someone at jamf will GET ON THE BALL. especially since i don't see ANY MENTION of activation lock in the list of known issues. this is apparently a known issue to everyone but jamf...
Posted on 07-20-2018 11:57 AM
I am seeing this exact same issue. I am using the JAMF Cloud.
Posted on 07-23-2018 07:05 AM
It seems to be devices that were enrolled a long time ago (not sure on the threshold) that don't work. Recently enrolled devices seem to take the bypass code correctly. It's around 50/50 in my experience.
Posted on 07-23-2018 08:00 AM
Same issue here. Have not tested my 10.4.1 instance but my 9.101 instance does not work at all and it's across the board in so far as the enrollment date. Had a list of about two dozen I sent in for Apple to remove the activation lock this summer.
Posted on 08-13-2018 04:27 PM
I have heard it is a known bug by support, but that may be the new stock response. The problem as I've been told lies with Apple and a disconnect that can occur in the hand off of the bypass code and end users changing their ID. I haven't ever recieved a completely clear explanation, but the latest I've heard is they are actually working on it. At this point I have to unfortunately limit the end user experience by not allowing log in with an Apple ID with a restriction payload.
Posted on 08-15-2018 12:21 PM
@JetJaguar How does your restriction payload look like, not allowing log in with an Apple ID?
