Adding a Wireless Profile using a script
  • September 10, 2018
  • 0 replies
  • 3 views
We have a Wireless Profile in the Enterprise which i need to automate to push it out to all the systems in the environment.
I already have a script which after installing the .config profile, installs the certs and grant it 'Trust Access' in the key chain.
It also add the profile in the W-Fi 'advanced Settings with the following parameters.
Network Name - abcd
Security - WPA/WPA2 enterprise
Mode - EAP-TLS
Identity - Ad Certificate.
The issue is here in selecting the correct certificate in 'Identity'. Currently what the script is doing is it is selecting the 1st option from the Drop-Down , where as i want to select the last option from the 'Identity' Drop-Down which i am unable to do.
Here is my Script. Any help/Suggestion to select the last option from the drop-down will be really helpful.
sudo security add-trusted-cert -d -r trustAsRoot -k /Library/Keychains/System.keychain /Library/Certificate/certs.mobileconfig
Cert="$compname.xxx.xxx.com" security set-identity-preference -c "$Cert" -s "com.apple.network.eap.user.identity.wlan.ssid.3apt1s" /Library/Keychains/System.keychain wservice=/usr/sbin/networksetup -listallnetworkservices | grep -Ei '(Wi-Fi|AirPort)' wirelessnw=networksetup -getairportnetwork $hwports | cut -d " " -f 4 # Grab the names of the adapters. We assume here that any ethernet connection name ends in "Ethernet" eth_names=networksetup -listnetworkserviceorder | sed -En 's|^(Hardware Port: .*LAN, Device: (en.))$|1|p' air_name=networksetup -listnetworkserviceorder | sed -En 's/^(Hardware Port: (Wi-Fi|AirPort), Device: (en.))$/2/p' # Set Wifi On
/usr/sbin/networksetup -setairportpower $air_name on sleep 10 if [[ $wirelessnw == "abcd" ]]; then echo "Connected to abcd" else echo "Machine is not connected to abcd. Checking identity preference" security get-identity-preference -s "com.apple.network.eap.user.identity.wlan.ssid.abcd" /Library/Keychains/System.keychain fi
sudo rm -rf /Library/Certificate
