Hey Guys,
is there a way to build a smart group for "not used" Apps in the last (maybe) 10 days?
We want to shorten our Browser List and remove Firefox, but first to all Devices that don't use Firefox.
I checked the box for "Collect Application Usage" and we see the Usage Information in the Computer Objects. I just need a way to collect all information into one Group to scope the removal script.
Thanks for some Advice!
Application Usage Smart Group
Best answer by sdagley
@MathiasO The Application Usage data isn't available as a Smart Group criteria. You could create an EA for each of the apps you're interested to see when it was last launched, and use that as the criteria for a Smart Group to target your removal script policy. Here's an example EA that returns the last time VMware Fusion was launched (make sure to set the EA data type as Date):
AppToCheck="/Applications/VMware Fusion.app"
Result="2000-01-01 00:00:01"
if [ -d "${AppToCheck}" ]; then
Result=$(mdls -name kMDItemLastUsedDate "${AppToCheck}" | cut -f 3,4 -d \\ )
echo "<result>$Result</result>"
