auto joining a wireless network via a script
  • August 2, 2011
  • 8 replies
  • 43 views
Eyoung
I am having issues with the resource kit script to join a machine to a wireless network. I've used the script in the past with a mixture of old Airport and cisco access points. We just installed campus wide cisco wireless and the script in the kit does not seem to work. I can join a machine manually with no issues.
I am looking to script joining a machine to a closed WPA2 personal network. Anyone happen to know why the resource kit script is not working? or have something similar hanging around that will work? the thought of joining a couple hundred laptops to this new network by hand is depressing me :-)
thanks
Man is a credulous animal, and must believe something; in the absence of good grounds for belief, he will be satisfied with bad ones. - Bertrand Russell
Eric Young
eyoung at thayer.org
Forum|alt.badge.img+31
  • August 2, 2011
this is what I use post image in a script
/usr/sbin/networksetup -addpreferredwirelessnetworkatindex Airport usd500_wpa 0 WPA2 mypassword
rob_potvin
  • Employee
  • August 3, 2011
I just started using it yesterday from the new resource kit and it working for me. I am joining a WPA2 network
Eyoung
  • August 3, 2011
this looks like the thing. One question though... I want to make sure I am parsing this correctly.
usd500_wpa is the SSID of the network your joining correct?
I wrote it out as: /usr/sbin/networksetup -addpreferredwirelessnetworkatindex Airport TA_Faculty 0 WPA2 mypassword
thanks for the help :-)
the really odd thing is it looks like the resource kit script should work.... I wonder if adding the script to my configuration at time of imaging is the wrong approach.
My life has no purpose, no direction, no aim, no meaning, and yet I'm happy. I can't figure it out. What am I doing right? --Charles M. Schulz (1922 - 2000)
Eric Young
Eyoung
  • August 3, 2011
here's a pro tip. a wireless network has to actually be there for a script joining a machine to it to work.
Through a series of miscues with a vendor I was doing my re-imaging in a building that had not gone live yet :-
Conscience is the inner voice which warns us that someone may be looking.
- H.L. Mencken
Eric Young
  • August 3, 2011
Yeah it is, the SSID. I literally copy/pasted it from my script and changed the password only
  • March 6, 2012
Hi all,
Is there a way to add your 80211x profile info user name into this script? I currently have an exported config file (.networkconnect) from 10.6 with all the right settings for 80211x saved but it requires you to click on a few buttons to install properly. I had made an automator script to make it happen relatively easily by clicking and waiting for it to join then quit and throw itself away but I can't find an easy way to make it run during the imaging process.
Gabe Shackney
Instructional Technology Specialist
Princeton Regional Schools
stevewood
Forum|alt.badge.img+38
  • March 6, 2012
Not sure if this will help you, but the method I used is outlined in this post:
https://jamfnation.jamfsoftware.com/discussion.html?id=2208
With that method once you login, or turn on wi-fi, you are prompted to enter your credentials. Not sure if that's what you are looking for or not.
Steve
  • March 6, 2012
I filed a bunch of bugs (and burned one of our engineering incidents) with Apple regarding regressions in 802.1x support in 10.6 that were not fixed until 10.7.
Be very careful esp. with Login Profiles.
What I ended up doing for 10.6 is effectively adding a user to AD whose only permission/right is authenticating to the 8021x network.
I created a System Profile with this user and exported that from the GUI including the cert. when prompted.
Then I copy that to the machine at imaging time and I have a script that merely does this...
networksetup -import8021xProfiles Airport "/Airport.networkConnect" && rm "/Airport.networkConnect"
For deployment to a machine that is already on a non 8021x SSID I came up with this. I would make some changes to it now that I have learned a bit more about scripting but it worked. ;)
# I found a better way to do this with importing and exporting network settings in 10.6
# Set variable to the interface that 'AirPort' lives on
INTERFACE=`networksetup -listallhardwareports | grep -A 1 AirPort | grep Device | awk {'print $2'}`
# Turn AirPort card on if off
while [ `networksetup -getairportpower $INTERFACE | awk {'print $4'}` = "Off" ]; do
    networksetup -setairportpower $INTERFACE on
    sleep 5
done
NETWORK=`networksetup -getairportnetwork $INTERFACE | awk {'print $4'}`
ADDRESS=`ipconfig getifaddr $INTERFACE`
if [ -a /AirPort.networkConnect ]; then # Look for config file
    CONFIG_FILE=/AirPort.networkConnect
    echo -e "/Airport.networkConnect was not found"
    if [ "$NETWORK" = "GBHSD" ]; then   # Check if 802.1x is already setup
        if [ `echo "$ADDRESS"| grep -c 169.254.` -eq 0 ]; then
            if [ `echo "$ADDRESS"| grep -c failed` -eq 0 ]; then
                echo "802.1x looks like it is setup!"
    jamf policy -trigger 8021x
    sleep 10
        echo "The config file did not come down from Casper in 10 seconds or less!"
        exit 3
networksetup -removeallpreferredwirelessnetworks $INTERFACE
networksetup -import8021xProfiles AirPort $CONFIG_FILE
networksetup -setairportnetwork $INTERFACE GBHSD
rm "$CONFIG_FILE"
/usr/bin/osascript << EOF
tell application "Finder"
        activate
        display dialog "We have just set up a new wireless network for increased security. Please logout and login again at your earliest convenience to take advantage of this new service." & return & "x4555" buttons {"OK"} with icon caution
end tell
EOF
EDIT: minor changes ---
replace all `` Command Substitutions with $()
make all variables lower case
fix the big pipeline for assigning $interface at beginning
switch from [ to [[ to clean up some then unneeded quoting
