I want to be able to auto-deploy Chrome to new computers that get enrolled in our system. I've been deploying Chrome via a package I made with Composer, but I'm getting issues where it's deploying an older version. So after some searching around, I found a better way to deploy Chrome with this: https://support.google.com/chrome/a/answer/9020580?hl=en&ref_topic=7650028. I'm stuck at the mcxToProfile step, as even when I enter the command, nothing happens. How do I get this to work? Keep in mind, I usually try to avoid the Command Line. Tried to use ProfileCreator for a GUI method, but I'm not sure if what I'm doing is right or not compared to the seemingly dead simple mcxToProfile Terminal process. Thanks!
