Build the VM in Silicon(M1/M2) Mac devices using VMware fusion 13.0.2
  • July 26, 2023
  • 135 views
Does anyone successes to build the VM in Apple Silicon chip devices using VM Ware fusion 13.0,2, If so please guide me to create it successfully.
Best answer by MichielD
Hi, sadly this does not work for us. What we use is UTM (UTM | Virtual machines for Mac (getutm.app)) or VirtualBuddy (GitHub - insidegui/VirtualBuddy: Virtualize macOS 12 and later on Apple Silicon). These work with Apple Silicon and use Apple's virtualisation framework inside macOS.
MichielD
  • July 26, 2023
AJPinto
  • July 26, 2023
I second VirtualBuddy. For a free github project it is very solid.
  • July 27, 2023
Thanks for the reply, Have downloaded UTM And it's working fine to build the VM in M1 device.
