There's multiple discussions on JAMF Nation and outside on how to do this, but I can't seem to figure out if it's possible through JSS itself in 8.63 without having to write a custom mobileconfig file
I can see the option for "Use as a Login Window configuration" and "Use Directory Authentication" but I never see the option. I'm also having weird issues not being able to edit the XML that's being spit out from the mobileconfig files that are generated from JSS.
Thoughts?
