Hi all,
I wanted to see if this is even possible, and thank you for any help or insight!
We have 3 main departments that I am managing devices for: Pharmacy, Physical Therapy, and Physician Assistants. I would to use our renaming scheme so that I can get it automated and get us closer to my ideal Zero Touch Deployment configuration.
We rename the computers based on: DEPT-USER-DEVICE
example: RX-JSMITH-IMAC, PA-JSMITH-MBP, PT-JSMITH-MBA, etc
I would love to see if we could present a user with a popup or alert that contains a dropdown box for them to select their department. This would then determine the Department part, then obviously we can get the User with $3, then I care less about the device type.
So I throw this out there, can it be done?
