Hi there,
At the moment I use a symlink with points /Users to an other Drive(RAID).
everything is working fine, exept the login to Appstore... (AMD Auth.. Error)
I tried everything also with the Shared folder and a ditto -V to copy the existing Shared Folder to the External RAID, but it doesn't help. Only if /Users/Shared is no a symlink.. the login works on Appstore.
I need all Users on my RAID because we use OD with local homes.
Is there a way to change Default /Users to example: /Volumes/Data on every new created account?
Glad for help.
cheers
