Extension attribute script execution
I cannot find the documentation on when exactly extension attribute (by script) are executed. I don't see a way to control it so I am wondering what triggers these scripts?
I have one I would like to run on a timed interval. It is not that important, as in, I don't want to create a script that runs on a loop with a sleep. But if it were possible for me to tell it to run every so often through JSS configuration I would do that. Is that possible?
I am guessing extension attributes by script are run at each inventory collection cycle?
Yep. Each time recon is ran they run. If you do a 'sudo jamf recon' from Terminal, you can see it say 'Finding Extension Attributes'.
stevewood
Forum|alt.badge.img+35
  • Employee
  • 1797 replies
  • August 14, 2013
If you want a script to run at a set interval, your best bet is a LaunchDaemon. You can set the LaunchDaemon to trigger the script at whatever interval you need.
  • 214 replies
  • August 14, 2013
Thank you both for your responses. Both helpful and informative. AJ.
Cookie policy
Cookie settings
