Extension attribute script works locally but not via Jamf
Hi Everyone,
I'm working on an EA to check for the presence of a particular cert in the user's Login keychain.:
currentUser=`stat -f '%Su' /dev/console`
echo "Current username is $currentUser"
fullName=$(dscl . read /Users/`whoami` RealName | grep -v RealName | cut -c 2-)
echo "Full Name is: $fullName"
firstName=$(echo $fullName | awk '{print $1;}')
echo "First Name is: $firstName"
CERTNAME=$firstName
echo "Cert Name is $CERTNAME"
if [[ `security find-certificate -c $CERTNAME /Users/$currentUser/Library/Keychains/login.keychain` ]]; then
   echo "<result>Installed</result>"
  echo "<result>Not Installed</result>"
Basically, the certificate we're looking for always has the user's first name. The script returns the proper result (Installed) when I run the script locally on my Mac, but always returns "Not Installed" when deployed as an EA. Has anyone else ran in to this behavior before? At first I thought it was the "currentUser" variable not setting correctly, but even when I plug in a defined user folder in the if statement , the EA returns "Not Installed"
-Mike
Best answer by thoule
Well, you've got 'whoami' in there, so that's going to return 'root' when run via jamf. Perhaps you meant to put currentUser in there?
I'd also recommend you use a full path when calling applications such as security ('/usr/bin/security')
Forum|alt.badge.img+15
  • 589 replies
  • May 14, 2018
  • 120 replies
  • May 14, 2018
Does the script work if you run the script locally while logged in as a different user than the user who you are trying to inventory the certificate for? My thought is it will also fail in that scenario. I think the only reason it is succeeding in your local test is that your login keychain is already unlocked so you can read from it without any issues. To be able to search within another user's login keychain you need to unlock that keychain with their login keychain password. I'm assuming you don't (and should not) know the login keychain passwords of your users, so you cannot unlock their login keychains and search within them. It is my understanding that this is by design even with root privileges.
  • 37 replies
  • May 14, 2018
There are dark forces at work with keychains. It's not enough to run it as a given user, and it's not enough to run it in the user's context. It takes multiple steps of contortions to go from the headless root environment of the Jamf client into proper userland where the security command will actually work.
This is how I solved a very similar problem, and I suspect it will work for you as well:
currentUser=`python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
uid=`id -u $currentUser`
launchctl asuser $uid su $currentUser -c "/usr/bin/security find-certificate -c $CERTNAME /Users/$currentUser/Library/Keychains/login.keychain"
Tested in Sierra and High Sierra.
  • 135 replies
  • May 14, 2018
@michaelherrick I got this to work - hope it helps.
consoleuser=$(ls -l /dev/console | cut -d " " -f4)
firstName=$(dscl . read /Users/$consoleuser RealName | grep -v RealName | cut -c 2- | awk '{ print $1 }')
echo $firstName
if [[ `security find-certificate -c $firstName /Users/$consoleuser/Library/Keychains/login.keychain` ]]; then
Cookie policy
Cookie settings
