I'd like to start preparing to upgrade our computers to Sierra and one of the major no no's is allowing the user to enable iCloud Desktop & Documents. Currently there is not a way (that I know of) to turn this off, but keep iCloud drive off. While I don't think that many of our users use iCloud Drive, I would like to set up an EA that could tell me how many users currently use it. Because I will be completely turning iCloud Drive off when users upgrade.
The Plist that shows this is MobileMeAccounts.plist in ~/Library/Preferences/
The trouble is how to identify that it is enabled via a script. The key that shows if it is enabled is above the string. I can't seem to figure out how to look for it. Or maybe there is an easier way!
<dict>
<key>Enabled</key>
<false/>
<key>Name</key>
<string>MOBILE_DOCUMENTS</string>
<key>ServiceID</key>
<string>com.apple.Dataclass.Ubiquity</string>
<key>apsEnv</key>
<string>production</string>
<key>authMechanism</key>
<string>token</string>
<key>iCloudHomeShouldEnable</key>
<false/>
<key>url</key>
<string>https://p48-ubiquity.icloud.com:443</string>
<key>wsUrl</key>
<string>https://p48-ubiquityws.icloud.com:443</string>
</dict>
I realize that this might be a tough question, but I am hoping someone is better than I am at using pListBuddy, awk, grep, etc..
