Hi all,
I've got a problem that I hope should be easy to solve. I have a script that is set to trigger on first time login that configures the dock/wallpaper and various other things.
Problem is, the script triggers ok, but fails to execute commands. I suspect because JAMF seems to be running each command with sudo (which is not explicitly stated in the script itself). This does not happen when triggered manually in Self Service (or physically copy/pasting the code locally and executing in terminal).
I've been trying to look all over the 'Policies' section and cannot find anything which might be inserting the sudo command in the code and what user/pass it might be trying to use on the client to run the script.
These are the errors I'm getting:
sudo: defaults: command not found
But, when I trigger the script manually in Self Service, the script runs just fine.
When it runs automatically on login:
Script result: JAMF Helper launched with informational messaging.
Clearing the Dock of the standard Apple configuration...
Adding Safari...
Safari already exists in dock. Use --replacing 'Safari' to update an existing item
item /Applications/Safari.app was not added to Dock
Adding System Preferences...
System Preferences already exists in dock. Use --replacing 'System Preferences' to update an existing item
item /Applications/System Preferences.app was not added to Dock
Adding iTunes...
iTunes already exists in dock. Use --replacing 'iTunes' to update an existing item
item /Applications/iTunes.app was not added to Dock
Adding Notes...
Notes already exists in dock. Use --replacing 'Notes' to update an existing item
item /Applications/Notes.app was not added to Dock
Adding FileMaker Pro ...
Adding MAXON Cinema 4D ...
When triggered manually in self service:
[STEP 3 of 5]
Running script User Config - Dock & Desktop Picture...
Script exit code: 0
Adding Safari...
Adding iTunes...
Adding Notes...
Adding Adobe After Effects ...
Adding Adobe Photoshop ...
Adding Adobe InDesign ...
Adding Adobe Illustrator ...
Adding Adobe Media Encoder ...
Adding VLC...
Adding Self Service ...
Adding Deadlne Launcher ...
Adding Deadline Monitor ...
Adding Documents folder...
Adding Downloads folder...
Adding FileMaker database shortcut...
No matching processes were found
Make sure everything is in place before coming back...
Snippet of the code I use:
user_short_name=$( /usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
user_home_dir="/Users/$user_short_name"
os_version=$( sw_vers -productVersion | awk -F. '{print $2}' )
dockutil="/usr/local/bin/dockutil"
icon="/Library/PPC/Resources/ppcImage.jpg"
jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper"
SR2=$( /usr/sbin/system_profiler SPDisplaysDataType | awk '/Resolution/{i++}i==2{print $2 $3 $4; exit}' )
# Start populating the dock
echo "Adding Safari..."
$dockutil --add '/Applications/Safari.app' --no-restart "$user_home_dir"
# Firefox
while read fireFox; do
"$dockutil" --add "${fireFox}" --no-restart "$user_home_dir"
echo "Adding Firefox ..."
done < <( find /Applications -maxdepth 1 -iname 'Firefox.app' )
echo "Adding System Preferences..."
$dockutil --add '/Applications/System Preferences.app' --no-restart "$user_home_dir"
echo "Adding iTunes..."
$dockutil --add '/Applications/iTunes.app' --no-restart "$user_home_dir"
echo "Adding Notes..."
$dockutil --add '/Applications/Notes.app' --no-restart "$user_home_dir"
## If installed, add these apps to the Dock
# FileMaker Pro
while read fileMaker; do
"$dockutil" --add "${fileMaker}" --no-restart "$user_home_dir"
echo "Adding FileMaker Pro ..."
done < <( find /Applications -maxdepth 2 -iname 'FileMaker *.app' )
# Avid Media Composer
while read avidMediaComposer; do
"$dockutil" --add "${avidMediaComposer}" --no-restart "$user_home_dir"
echo "Adding Avid Media Composer ..."
done < <( find /Applications -maxdepth 2 -iname 'AvidMedia *.app' )
# MAXON Ciema 4D
while read maxonCinema4D; do
"$dockutil" --add "${maxonCinema4D}" --no-restart "$user_home_dir"
echo "Adding MAXON Cinema 4D ..."
done < <( find /Applications -maxdepth 3 -iname 'CINEMA 4D.app' )
etc...etc...
