Having an issue getting new device to work using Remote access
  • January 20, 2015
  • 0 views
When I image a new device, the Self Service app is not installing, so have to enroll, completes but cannot Remotely manage with casper Remote.
Log:
Sending Wake On LAN command...
Opening SSH Connection to x.x.x.x
Authenticating...
Authenticating...
Authenticating...
Is there a Security setting change needed here?
1 reply
davidacland
  • 1811 replies
  • January 20, 2015
SSH can be enabled in a few different places. In Casper imaging its in the main configuration. You can also check the box in Computer Management Settings > Check-In Settings in the JSS "Ensure SSH is enabled".
If your not sure if SSH is responding at all on the Mac you can test it with nc:
nc -z ip.or.dns.name 22
If its up you should be getting a "Connection to ip.or.dns.name port 22 [tcp/ssh] succeeded!"
Cookie policy
Cookie settings
