Can someone tell me the process to rebinding a client to JSS please.
Being new to the management of a mac network with JSS i could really do with your help!
Help for a noob!
Best answer by franton
Ok that's not anything to do with a "bind" to the JSS, that's your Active Directory. That error states that the computer is already bound to AD and you're trying to bind it again.
You should now check the following:
1) Is the computer present in your Active Directory? You'll need to check from a PC and the Active Directory Users & Computers application.
2) Does the computer think it's bound? Easiest way is in Users & Groups in System Preferences. Click on Login Options and see if "Network Account Server" is set to anything.
Any mismatch between these two places is bad. You should be in both or neither.
