Posted on β04-29-2020 10:08 AM
Can anyone help me with the script for removing SEP in JAMF? My script skills are not that good. I'm more of a copy and paste guy.
This link seems to have the best info.
https://knowledge.broadcom.com/external/article?legacyId=TECH103489
I have downloaded the SymantecRemovalTool modification zip provided at the bottom of the page. I then view the command via Xcode copy and paste it into a new script create in Jamf. Next, I create a Policy including the script. The policy fails with a script exit code:4
The below step I don't follow. Is anyone willing to share their Policy? (Pics of Policy would be awesome so I know what is meant by a dummy script)
**Symantec provides support for SymantecRemovalTool/RemoveSymantecMacFiles only when running them locally; it is the customer's responsibility to integrate SymantecRemovalTool with Apple Remote Desktop or other remote deployment tools.
Both of these tools require no arguments. Any arguments they receive are each assumed to be potential installation points for Symantec products. Remote deployment solutions (Casper, JAMF, et al) that automatically populate shell script arguments ($1, $2, etc) with other data may cause the Symantec tool to throw an error. To work around this, the remote deployment solution may be configured to call first a dummy script that in turn calls the removal tool without any extra arguments.**
Posted on β04-29-2020 10:37 AM
Create a package that places the script locally, say in /tmp for example. Then create a policy that installs the package and then executes the following command from the Files and Processes payload...
/private/tmp/SymantecRemovalTool.command
Posted on β04-30-2020 03:57 PM
Thanks for the help. I had issues getting your method to work. I'm sure it was on my end. I ended up using this script using this link.
https://gist.github.com/rderewianko/6aa0032f19e57b595e0fdae4470f6286
Posted on β07-14-2020 08:04 AM
Can anyone tell me if this script(the one provided in the GitHub link) also removes ALL Symantec products or if it just removes SEP? We utilize other Symantec products in our environment like the WSS agent and DLP and need those to remain.
Posted on β08-31-2020 10:36 PM
whats the point having JAMF if we have to go though all this pain by ourselves
Posted on β05-13-2021 07:09 AM
I create a script with
rm -r /private/var/tmp/SymantecRemovalTool
mkdir /private/var/tmp/SymantecRemovalTool
/bin/cat >/private/var/tmp/SymantecRemovalTool/SymantecRemovalTool.command <<"EOF"
<Here goes the SymantecRemovalTool.command script from symantec>
EOF
chmod +x /private/var/tmp/SymantecRemovalTool/SymantecRemovalTool.command
Then create a policy with this script payload with Before option selected, and a File and Process payload with running the command
/private/var/tmp/SymantecRemovalTool/SymantecRemovalTool.command && rm -r /private/var/tmp/SymantecRemovalTool
So this policy creates the Script in a temp folder, then runs as root and then clears its directory.
With Catalina and Later OS, and SEP 14.3 the user has to approve the removal of the system extension.
Also packaging is an option, but sometimes our good old SEP blocks pkg downloads from our https distribution point. So script way is a better option for us.
Posted on β05-13-2021 08:54 AM
Pretty sure my network team got this directly from Symantic. We have just been running the script and it's working like a champ.
Edit - sorry this posted in a full mess. Happy to send you the text file if you would like to give it try.
set -- /
Version=8.0.3
PATH=/bin:/sbin:/usr/bin:/usr/sbin
SymantecCleanupRestartFile="/private/tmp/com.symantec.cleanup.restart"
AbbreviatedScriptName=basename "$0" .command 2>/dev/null
AutoRunScript=true
BackupLogLocationRootDirName="SymantecDiagnosticLogs"
BackupLogLocationRootDir="/private/var/tmp/$BackupLogLocationRootDirName"
CurrentVolumeBeingUsed="/"
DefaultsDomainsToDelete="group.symantec.nortonclean"
ExitCodeWhenSomeFileWasNotRemoved=0
ExitCodeWhenFilesRemain=7
FilesThatDoNotRequireRebootPattern='.log|.txt|.rtf|Caches/com.apple.helpd|/log/|/Logs/|/tmp/'
FilesRemovedList="/private/tmp/${AbbreviatedScriptName}RemovesThese.txt"
FilesRemovedFilesOnlyList="/private/tmp/${AbbreviatedScriptName}RemovesThese-FilesOnly.txt"
FilesRemovedListOfOld="/Users/Shared/${AbbreviatedScriptName}RemovesThese.txt"
FilesWereSaved=false
FinishedExitCode=0
FullScriptName=basename "$0" 2>/dev/null
ItemsThatShouldRemainAfterUninstall="/Library/Application Support/Symantec/Daemon/Data2.chk
/var/tmp/com.symantec.mes.patcher.log"
LANG=""
LaunchLocationGrepPattern='/Library/Application Support/Symantec/Uninstaller|.app/Contents/Resources'
ListOfProgramsThatShouldNotBackUpLogs="RemoveSymantecMacFiles.command
SymantecRemovalTool
SymantecRemovalTool.command"
ListOfProgramsThatShouldNotKillProcesses="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveFSDFolders="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveInstallerLaunchAgents="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveLogs="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveMDMProfile="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveMidDat="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveMigrationFiles="SymantecRemovalTool"
ListOfProgramsThatShouldNotRemoveSymantecIPUA="SymantecRemovalTool"
LogFile="/private/tmp/${AbbreviatedScriptName}Log.txt"
LogFileOfOld="/Users/Shared/${AbbreviatedScriptName}Log.txt"
LoginKeychainPasswordsToDelete="com.norton.NFM.auth Norton Internet Security account info
com.norton.mexico.auth Norton Zone saved sessions"
LogsToBackUpPattern="/Logs/"
LogsToNotBackUpPattern="SymantecTestPatchers.log"
NotRemovedByNIS6Uninstaller='/com.symantec.errorreporting.
/etc/liveupdate.conf'
NotRemovedByNIS6UninstallerText=" [should not be removed by NIS 6 uninstaller]"
NotRemovedBySymantecUninstallerPattern='/Library/LaunchAgents/com.symantec.SCSInstaller.plist
/Library/LaunchDaemons/com.symantec.nis.uninstall.plist
/Library/LaunchDaemons/com.symantec.NWPService.plist
/Library/Logs/SymantecTestPatchers.log
/Library/Preferences/com.norton.WiFiPrivacy.plist
/Library/Preferences/com.symantec.antivirus.special.plist'
NotRemovedBySymantecUninstallerText=" [should not be removed by Symantec Uninstaller.app]"
PrivateLinksPattern='^/etc/|^/tmp/|^/var/'
PrivateDirectoriesPattern='^/private/etc/|^/private/tmp/|^/private/var/'
PublicVersion=true
ReceiptsTable='
CompatibilityCheck.pkg
Decomposer.pkg
DeletionTracking.pkg
FileSaver.pkg
LiveUpdate -a
NATRemoteLock.pkg
NATSDPlugin.pkg
NAVContextualMenu.pkg
NAVcorporate.pkg
NAVDefs.pkg
NAVEngine.pkg
NAVWidget.pkg
navx.pkg
NAV_App -a
NAV_AutoProtect -a
NFSCore.pkg
NISLaunch.pkg
Norton AntiVirus Application.pkg
Norton AntiVirus Product Log.rtf
Norton AntiVirus.pkg
Norton AutoProtect.pkg
Norton Disk Editor X.pkg
Norton Internet Security Log.rtf
Norton Personal Firewall 3.0 Log.rtf
Norton Scheduled Scans.pkg
Norton Scheduler.pkg
Norton SystemWorks 3.0 Log.rtf
Norton Utilities 8.0 Log.rtf
nortonanti-theftPostflight.pkg
nortonantitheftPostflight.pkg
NortonAutoProtect.pkg
NortonAVDefs -a
NortonDefragger.pkg
NortonDiskDoctor.pkg
NortonFirewall -a
NortonInternetSecurity -a
NortonLauncher.pkg
NortonParentalControl.pkg
NortonPersonalFirewall.pkg
NortonPersonalFirewallMenu.pkg
NortonPrivacyControl.pkg
NortonQuickMenu -a
NPC Installer Log
NPC.pkg
NSMCore.pkg
NSMCore.Universal.pkg
NSWLaunch.pkg
NUMCompatibilityCheck.pkg
NumDocs.pkg
NUMLaunch.pkg
PredeleteTool.pkg
SavLog.pkg
Scheduled Scans.pkg
Scheduler.pkg
SDProfileEditor.pkg
SMC.pkg
SNAC.pkg
SpeedDisk.pkg
StuffIt.pkg
Symantec Alerts.pkg
Symantec AntiVirus.pkg
Symantec AutoProtect Prefs.pkg
Symantec AutoProtect.pkg
Symantec Decomposer.pkg
Symantec Endpoint Protection.pkg
Symantec Scheduled Scans.pkg
Symantec Scheduler.pkg
SymantecAVDefs -a
SymantecClientFirewall.pkg
SymantecDecomposer.pkg
SymantecDeepSightExtractor.pkg
SymantecParentalControl.pkg
SymantecQuickMenu.pkg
SymantecSAQuickMenu.pkg
SymantecSharedComponents -a
SymantecUninstaller -a
SymantecURLs.pkg
SymAV10StuffItInstall.pkg
SymAVScanServer.pkg
SymConfidential -a
SymConfidentialData.pkg
SymDaemon -a
SymDC.pkg
SymDiskMountNotify.pkg
SymErrorReporting.pkg
SymEvent.pkg
SymFileSecurity -a
SymFirewall -a
SymFS.pkg
SymHelper.pkg
SymHelpScripts.pkg
SymInstallExtras.pkg
SymInternetSecurity.pkg
SymIntrusionPrevention -a
SymIPS.pkg
SymLicensing -a
SymNCOApplication -a
SymOxygen.pkg
SymOSXKernelUtilities.pkg
SymPersonalFirewallCore -a
SymPersonalFirewallUI -a
SymProtector.pkg
SymPseudoLicensing -a
SymSetupAssistant -a
SymSharedFrameworks -a
SymSharedSettings -a
SymStuffit.pkg
SymSubmission.pkg
SymUIAgent -a
SymWebFraud -a
SymWebKitUtils.pkg
Unerase.pkg
URL.pkg
VolumeAssist.pkg
VolumeRecover.pkg
WCIDEngine.pkg
Wipe Info.pkg
ZoneStandalone.pkg
RequiredPrograms='
awk
basename
cat
cd
chmod
cp
crontab
date
defaults
dirname
echo
egrep
expr
find
grep
head
kill
ls
mkdir
more
printf
ps
pwd
read
rm
sed
sort
sudo
tail
tr
uniq
SavedFilesDir="/private/tmp/${AbbreviatedScriptName}SavedFiles"
AssignVolume()
# Usage: AssignVolume $1
# Argument: $1 = Volume name. The name can begin with "/Volumes/"
# unless it is "/" (boot volume).
# Summary: Assigns the name of the volume passed as $1 to VolumesToUse.
# If volume is assigned, 0 is returned; else, 1 is returned.
# If nothing passed, skip assignment
[ -z "$1" ] && return 1
VolumeToAssign=CheckIfValidVolume "$1"
if [ -z "$VolumeToAssign" ] ; then
VolumeToAssign=CheckIfValidVolume "/Volumes/$1"
[ -z "$VolumeToAssign" ] && return 1
[ "$VolumeToAssign" = "/" ] && BootVolumeWillBeSearched=true
VolumesToUse="$VolumesToUse
$VolumeToAssign"
return 0
BackupLog()
# Usage: BackupLog file
# Summary: Copies file into BackupLogLocationDir.
# BackupLogLocationDir must be defined prior
# to running this function.
local FileToBackUp="$1"
local BackupNumber=0
FileToBackupBase=basename "$FileToBackUp"
local DestinationFileName
if ! $DoBackupLogs ; then
return
elif [ ! -f "$FileToBackUp" ] ; then
return
# Else if this is not a file that should be backed up
elif [ -z "printf "%s" "$FileToBackUp" | egrep -ie "$LogsToBackUpPattern" | egrep -ive "$LogsToNotBackUpPattern"
" ] ; then
return
if [ ! -d "$BackupLogLocationDir" ] ; then
mkdir -p "$BackupLogLocationDir"
chmod 777 "$BackupLogLocationDir" "$BackupLogLocationRootDir"
DestinationFileName="$FileToBackupBase"
while [ -f "$BackupLogLocationDir/$DestinationFileName" ] ; do
let BackupNumber=$BackupNumber+1
# If file name contains a period with a character on each side and no other periods
if [ "printf "%s" "$FileToBackupBase" | grep -e '...' | grep -ve '..*.'
" ] ; then
DestinationFileName=`printf "%s" "$FileToBackupBase" | awk -v NUM="$BackupNumber" '{
# Put hyphen NUM in front of the period
sub(".", "-" NUM ".", $0)
print $0}'`
# Put hyphen NUM at end of the file name
DestinationFileName="$FileToBackupBase-$BackupNumber"
done
ditto "$FileToBackUp" "$BackupLogLocationDir/$DestinationFileName"
chmod 666 "$BackupLogLocationDir/$DestinationFileName"
CheckIfValidVolume()
# Usage: CheckIfValidVolume volume
# Summary: If volume is a valid volume path, the path, with extra
# slashes removed, is written to standard output.
local PathToPrint=""
local VolumePathToCheck="$1"
# If VolumePathToCheck is the boot volume
if [ "$VolumePathToCheck" -ef / ] ; then
PathToPrint=/
# Else if VolumePathToCheck begins with /
elif [ "printf "%s" "$VolumePathToCheck" | grep '^/'
" ] ; then
# If it is a directory and not a link
if [ -d "$VolumePathToCheck" -a ! -L "$VolumePathToCheck" ] ; then
# Strip any extra slashes
VolumePathToCheck=printf "%s" "$VolumePathToCheck" | sed 's|//*|/|g'
if [ "dirname "$VolumePathToCheck"
" = "/Volumes" ] ; then
PathToPrint="/Volumes/basename "$VolumePathToCheck"
[ "$PathToPrint" ] && echo "$PathToPrint"
DeleteCrontabEntries()
# Usage: DeleteCrontabEntries [$1]
# Argument: $1 = Volume name. The name should begin with "/Volumes/"
# unless it is "/" (boot volume). If NULL, then / is
# used as volume name.
# Authors: John Hansen, Corey Swertfager
# Summary: Deletes from / or volume specified the crontab entries
# created by Norton Scheduler and Symantec Scheduler.
# Note: User must be root when calling this function.
if [ "z$1" = z/ ] ; then
VolumeToDeleteCrontabsFrom=""
VolumeToDeleteCrontabsFrom="$1"
CRONDIRNEW="$VolumeToDeleteCrontabsFrom/private/var/at/tabs" # OS 10.5 and later crontab directory
CRONDIROLD="$VolumeToDeleteCrontabsFrom/private/var/cron/tabs" # OS 10.4 and earlier crontab directory
if [ ! -d "$CRONDIRNEW" -a ! -d "$CRONDIROLD" ] ; then
if $CreateFilesRemovedListOnly ; then
if [ -z "$VolumeToDeleteCrontabsFrom" ] ; then
echo "No crontab directory was found on on the current boot volume." >> "$FilesRemovedList"
echo "No crontab directory was found on on the volume "basename "$VolumeToDeleteCrontabsFrom"
"." >> "$FilesRemovedList"
echo "" >> "$FilesRemovedList"
return 1
TEMPFILETEMPLATE="/private/tmp/NortonTemp"
GREP1="^#SqzS"
GREP2="^#SYMANTEC SCHEDULER CRON ENTRIES"
GREP3="^#PLEASE DO NOT EDIT.$"
GREP4="EvType1=.EvType2=.Sched="
GREP5="Norton Solutions Support/Scheduler/schedLauncher"
GREP6="Symantec/Scheduler/SymSecondaryLaunch.app/Contents/schedLauncher"
SymantecCrontabEntryExists=false
CurrentDir="pwd
" # Save initial directory location
# Set IFS to only newline to get all crontabs
IFS='
for CRONDIR in ls -d "$CRONDIRNEW" "$CRONDIROLD" 2>/dev/null
; do
cd "$CRONDIR"
# List each crontab, pipe through grep command and replace
for user in $ComputerUsers ; do
# If there is no crontab file for this user, skip user
[ ! -f "$user" ] && continue
# If deleting from boot volume
# Check to see if there is a Symantec crontab entry
if [ "crontab -u "$user" -l | grep -c "$GREP1|$GREP2|$GREP3|$GREP4|$GREP5|$GREP6"
" != 0 ] ; then
SymantecCrontabEntryExists=true
continue # Nothing to remove, skip user
$CreateFilesRemovedListOnly && break
TEMPFILE="$TEMPFILETEMPLATEdate "%Y%m%d%H%M%S"
crontab -u "$user" -l | grep -v "$GREP1|$GREP2|$GREP3|$GREP4|$GREP5|$GREP6" > $TEMPFILE
# Restore crontab file if it has more entries, else remove
if [ -s "$TEMPFILE" ] ; then
crontab -u "$user" $TEMPFILE &>/dev/null
echo "y" | crontab -u "$user" -r &>/dev/null
if [ "grep -c "$GREP1|$GREP2|$GREP3|$GREP4|$GREP5|$GREP6" "$user"
" != 0 ] ; then
"%Y%m%d%H%M%S"
grep -v "$GREP1|$GREP2|$GREP3|$GREP4|$GREP5|$GREP6" "$user" > $TEMPFILE
cat $TEMPFILE >"$user"
rm -f "$user" 2>/dev/null
/bin/rm "$TEMPFILE" 2>/dev/null
done
[ $CreateFilesRemovedListOnly = true -a $SymantecCrontabEntryExists = true ] && break
done
cd "$CurrentDir" # Return to intial directory
if $SymantecCrontabEntryExists ; then
echo "Symantec crontab entries would be deleted from the current boot volume." >> "$FilesRemovedList"
echo "Symantec crontab entries would be deleted from the volume" >> "$FilesRemovedList"
echo ""basename "$VolumeToDeleteCrontabsFrom"
echo "Symantec crontab entries were deleted from the current boot volume."
echo "Symantec crontab entries were deleted from the volume"
NoFilesToRemove=false
echo "There are no Symantec crontab entries on the current boot volume;" >> "$FilesRemovedList"
echo "no crontab entries would be removed from it." >> "$FilesRemovedList"
echo "There are no Symantec crontab entries on the volume "basename "$VolumeToDeleteCrontabsFrom"
";" >> "$FilesRemovedList"
echo "no crontabs would be adjusted on that volume." >> "$FilesRemovedList"
elif [ -z "$VolumeToDeleteCrontabsFrom" ] ; then
echo "There are no Symantec crontab entries to delete from the current boot volume."
echo "There are no Symantec crontab entries to delete from the volume"
return 0
DeleteDefaults()
# Usage: DeleteDefaults
# Summary: Deletes defaults for each domain in DefaultsDomainsToDelete
# for each user in ComputerUsers.
# GetComputerUsers() function must be run before calling this
# function so that ComputerUsers is defined.
local EachDefaultsDomain
local SaveIFS="$IFS"
local User
IFS='
for EachDefaultsDomain in $DefaultsDomainsToDelete ; do
for User in $ComputerUsers ; do
# if there are defaults set for this user and domain
if [ "sudo -u "$User" defaults read "$EachDefaultsDomain" 2>/dev/null
" ] ; then
echo "Deleting defaults for $EachDefaultsDomain for user $User"
sudo -u "$User" defaults delete "$EachDefaultsDomain"
done
done
IFS="$SaveIFS"
DeleteLaunchdPlists()
# Usage: DeleteLaunchdPlists [$1]
# Summary: Deletes from / or volume specified the launchd plists
# created by Symantec Scheduler.
VolumeToDeleteLaunchdPlistsFrom=""
VolumeToDeleteLaunchdPlistsFrom="$1"
LaunchdPlists=ls -d "$VolumeToDeleteLaunchdPlistsFrom/Library/LaunchDaemons/com.symantec.Sched"*.plist 2>/dev/null
if [ "$LaunchdPlists" ] ; then
if [ -z "$VolumeToDeleteLaunchdPlistsFrom" ] ; then
echo "Symantec Scheduler launchd plists would be deleted from the current boot volume." >> "$FilesRemovedList"
echo "Symantec Scheduler launchd plists would be deleted from the volume" >> "$FilesRemovedList"
echo ""basename "$VolumeToDeleteLaunchdPlistsFrom"
IFS='
for EachPlist in $LaunchdPlists ; do
rm -f "$EachPlist" 2>/dev/null
done
echo "Symantec Scheduler launchd plists were deleted from the current boot volume."
echo "Symantec Scheduler launchd plists were deleted from the volume"
echo "There are no Symantec Scheduler launchd plists on the current boot volume," >> "$FilesRemovedList"
echo "so none would be removed from it." >> "$FilesRemovedList"
echo "There are no Symantec Scheduler launchd plists on the volume" >> "$FilesRemovedList"
", so none would be removed from it." >> "$FilesRemovedList"
elif [ -z "$VolumeToDeleteLaunchdPlistsFrom" ] ; then
echo "There are no Symantec Scheduler launchd plists to delete from the current boot"
echo "volume."
echo "There are no Symantec Scheduler launchd plists to delete from the volume"
return 0
DeleteSymantecLoginItems()
# Usage: DeleteSymantecLoginItems [volume]
# Argument: volume - volume from which to remove login items; volume must
# begin with "/Volumes/" unless it is "/" (boot volume); if
# nothing is passed, / is assumed.
# Summary: Deletes Symantec items from all com.apple.loginitems.plist and
# loginwindow.plist files on volume specified.
# If a file is purged on the boot volume, file path defined by
# SymantecCleanupRestartFile is created so that reboot messaging
# can be displayed by scripts that use this function.
# Returns: The number of files purged.
# Note: If this function is run while booted in OS 10.1.x, it will
# not be able to adjust loginwindow.plist files on an OS 10.4
# or later volume because plutil did not ship with OS 10.1.x.
# The com.apple.loginitems.plist files are not purged if
# /usr/libexec/PlistBuddy does not exist (PlistBuddy first
# appeared in OS 10.5).
# function so that ComputerUsersHomeDirsAndRootDir is defined.
# CreateFilesRemovedListOnly and FilesRemovedList variables are
# used only in Symantec Cleanup scripts.
# Version: 3.0.2
local ArrayItem
local Base
local Buffer
local CheckSyntax
local CreateFilesRemovedListOnly="$CreateFilesRemovedListOnly"
local Line
local NameKeyValue
local NumberOfFilesPurged=0
local OriginalPlistFile
local PatternOfKeyNames="Norton WiFi Privacy.app"
local PatternOfKeyNamesToExclude="Norton Solutions|Symantec|SymSecondaryLaunch|Norton"
local PlistBuddyError
local PropertyKeyToUse
local SavedIFS="$IFS"
local StartupPathPatterns="/Applications/Norton AntiVirus.app
/Applications/Norton Internet Security.app
/Applications/Norton Security.app
/Applications/Symantec Cloud Security.app
/Applications/Symantec Unified Endpoint Protection.app
/Library/Application Support/Norton Solutions
/Library/StartupItems/Norton
/Norton Zone.app
Norton WiFi Privacy"
local SymantecLoginItemsWereFound=false
local SymantecLoginItemWasFound
local TargetVolume="$1"
local TempFileTemplate=/private/tmp/Delete_Symantec_Login_Items
local TempScrapFile=${TempFileTemplate}date "%Y%m%d%H%M%S"
-Scrap
local TempPlistFile=${TempFileTemplate}date
"%Y%m%d%H%M%S"
-PlistCopy
[ "$1" -ef / ] && TargetVolume=""
[ "z$CreateFilesRemovedListOnly" != ztrue -o ! -f "$FilesRemovedList" ] && CreateFilesRemovedListOnly=false
[ -z "$SymantecCleanupRestartFile" ] && SymantecCleanupRestartFile="/private/tmp/com.symantec.cleanup.restart"
which plutil &>/dev/null
# If plutil program is not installed
if [ $? != 0 ] ; then
# If running OS 10.4 or later
if [ $OSXmajorVersion -gt 3 ] ; then
# Show message and skip plist adjustments because plists are in binary format in OS 10.4 and later
echo "NOTE: plutil is not installed, so loginwindow.plist files cannot be adjusted." >> "$FilesRemovedList"
return
IFS='
for Line in $StartupPathPatterns ; do
Base=basename "$Line" .app
if [ -z "echo "$Base" | egrep -xe "$PatternOfKeyNamesToExclude"
" ] ; then
PatternOfKeyNames="${PatternOfKeyNames}|$Base"
done
# Remove login items from loginwindow.plist files
for EachHomeDir in $ComputerUsersHomeDirsAndRootDir ; do
if [ "$EachHomeDir" = / ] ; then
OriginalPlistFile="$TargetVolume/Library/Preferences/loginwindow.plist"
OriginalPlistFile="$TargetVolume$EachHomeDir/Library/Preferences/loginwindow.plist"
[ ! -f "$OriginalPlistFile" ] && continue
rm -rf "$TempPlistFile" 2>/dev/null
cp "$OriginalPlistFile" "$TempPlistFile"
CheckSyntax=true
plutil -convert xml1 "$TempPlistFile" 2>/dev/null
# If plutil failed to convert the plist, don't check syntax later
[ $? != 0 ] && CheckSyntax=false
IsBinaryFormat=false
# If original plist is different than converted plist, treat it as a binary file
[ -n "diff "$OriginalPlistFile" "$TempPlistFile" 2>/dev/null
" ] && IsBinaryFormat=true
# If no Symantec login item was found, skip to next file
[ grep -c -F "$StartupPathPatterns" "$TempPlistFile"
= 0 ] && continue
SymantecLoginItemsWereFound=true
echo "Symantec login items would be removed from:" >> "$FilesRemovedList"
echo " "$OriginalPlistFile"" >> "$FilesRemovedList"
continue
# Purge Symantec login item(s)
printf "" > "$TempScrapFile"
Buffer=""
DoWriteBuffer=true
for Line in cat "$TempPlistFile"
; do
# If beginning of a dictionary key
if [ "printf "%s" "$Line" | grep '<dict>$'
" ] ; then
[ "$Buffer" ] && echo "$Buffer" >> "$TempScrapFile"
Buffer="$Line"
DoWriteBuffer=true
if [ "$Buffer" ] ; then
Buffer="$Buffer
$Line"
Buffer="$Line"
# If end of a dictionary key
if [ "printf "%s" "$Line" | grep '</dict>$'
" ] ; then
$DoWriteBuffer && echo "$Buffer" >> "$TempScrapFile"
Buffer=""
DoWriteBuffer=true
# Else if Symantec path was found
elif [ "printf "%s" "$Line" | grep -F "$StartupPathPatterns"
" ] ; then
DoWriteBuffer=false
done
# If some login item information is missing
if [ grep -c '<dict>$' "$TempScrapFile"
!= grep -c '</dict>$' "$TempScrapFile"
] ; then
echo "ERROR: Could not remove Symantec login items from:"
echo " $OriginalPlistFile"
# Else if syntax is to be checked and plist contains bad syntax
elif [ $CheckSyntax = true -a -n "plutil -s "$TempScrapFile" 2>/dev/null
" ] ; then
echo "ERROR: Could not remove Symantec login items (plutil conversion failed) from:"
echo "Removing Symantec login items from:"
cat "$TempScrapFile" > "$OriginalPlistFile"
$IsBinaryFormat && plutil -convert binary1 "$OriginalPlistFile" 2>/dev/null
let NumberOfFilesPurged=$NumberOfFilesPurged+1
done
rm -f "$TempScrapFile" 2>/dev/null
# Remove login items from com.apple.loginitems.plist files if PlistBuddy is installed
if [ -f /usr/libexec/PlistBuddy ] ; then
OriginalPlistFile="$TargetVolume/Library/Preferences/com.apple.loginitems.plist"
OriginalPlistFile="$TargetVolume$EachHomeDir/Library/Preferences/com.apple.loginitems.plist"
PropertyKeyToUse=':privilegedlist:CustomListItems'
NameKeyValue=/usr/libexec/PlistBuddy "$TempPlistFile" -c "print ${PropertyKeyToUse}:0:Name" 2>/dev/null
if [ -z "$NameKeyValue" ] ; then
PropertyKeyToUse=':SessionItems:CustomListItems'
[ -z "$NameKeyValue" ] && continue
PlistBuddyError=0
SymantecLoginItemWasFound=false
ArrayItem=0
while [ "$NameKeyValue" ] ; do
# If this is a Symantec login item that should be deleted
if [ "printf "%s" "$NameKeyValue" | egrep -xe "$PatternOfKeyNames"
" ] ; then
SymantecLoginItemWasFound=true
/usr/libexec/PlistBuddy "$TempPlistFile" -c "delete ${PropertyKeyToUse}:$ArrayItem" 2>/dev/null
PlistBuddyError=$?
[ $PlistBuddyError != 0 ] && break
let ArrayItem=$ArrayItem+1
NameKeyValue=/usr/libexec/PlistBuddy "$TempPlistFile" -c "print ${PropertyKeyToUse}:$ArrayItem:Name" 2>/dev/null
done
$SymantecLoginItemWasFound && SymantecLoginItemsWereFound=true
if $SymantecLoginItemWasFound ; then
# Else if some login item could not be deleted
elif [ $PlistBuddyError != 0 ] ; then
elif $SymantecLoginItemWasFound ; then
cp "$TempPlistFile" "$OriginalPlistFile"
done
rm -f "$TempPlistFile" 2>/dev/null
if ! $SymantecLoginItemsWereFound ; then
echo "No Symantec login items were found." >> "$FilesRemovedList"
$CreateFilesRemovedListOnly && echo "" >> "$FilesRemovedList"
# If some Symantec items were purged from files on boot volume, trigger restart
[ $NumberOfFilesPurged -gt 0 -a -z "$TargetVolume" ] && touch "$SymantecCleanupRestartFile"
IFS="$SavedIFS"
return $NumberOfFilesPurged
DetermineAction()
# Usage: DetermineAction
# Summary: Determines which action to take based on user input.
clear
echo
ShowVersion
echo "
WARNING: This script will remove all files and folders created by Symantec
OS X products (except Symantec Adminstration Console for Macintosh
files) and any files within those folders. Therefore, you will
lose ALL files that reside in those folders, including any that
you have created.
echo "1 - Remove all Symantec files/folders."
echo
echo "2 - Quit. Do not remove any files."
echo
printf "Enter choice (1 or 2): "
read choice
echo
case "echo "z$choice" | awk '{print tolower(substr($0,2))}'
" in
1) # Remove files
2|q|quit) # Quit
echo "Program cancelled. No files were removed."
ExitScript 0
*) # Show choices again
DetermineAction
esac
DisableBrowserExtensionHostAssignment()
# Usage: DisableBrowserExtensionHostAssignment
# Summary: Comments out browser extension host assignment in /etc/hosts.
local BrowserExtensionHost="macplugin.norton.com"
local BrowserExtensionHostPattern=echo "$BrowserExtensionHost" | sed 's/././g'
local BrowserExtensionHostCommentedOutPattern
local HostsContent=""
local HostsFile="/etc/hosts"
local Line
BrowserExtensionHostPattern="[[:space:]]$BrowserExtensionHostPattern[[:space:][:cntrl:]]$"
BrowserExtensionHostCommentedOutPattern="^[[:space:]]#.*$BrowserExtensionHostPattern"
# If host assignment was found in hosts file that wasn't already commented out
if [ "grep "$HostsFile" -e "$BrowserExtensionHostPattern" 2>/dev/null | egrep -ve "$BrowserExtensionHostCommentedOutPattern"
" ] ; then
echo "Commenting out $BrowserExtensionHost host assignment in $HostsFile"
for Line in cat "$HostsFile" 2>/dev/null
; do
# If line is a host assignment that has not been commented out
if [ "printf "%s" "$Line" | egrep -e "$BrowserExtensionHostPattern" | egrep -ve "$BrowserExtensionHostCommentedOutPattern"
" ] ; then
# Comment it out
HostsContent="$HostsContent
# Leave it as is
$Line"
done
echo "$HostsContent" | grep . > "$HostsFile"
ExitScript()
# Usage: ExitScript [-b] [-e] [exit_number [error_string]]
# Summary: Checks to see if ShowQuitMessage and RunScriptAsStandAlone
# variables are set to true. If so, a message is displayed;
# otherwise, no message is displayed. The script is then
# exited and passes exit_number to exit command. If no
# exit_number is passed, then 0 is passed to exit command. If
# a non-integer is passed as exit_number, 255 is passed to
# exit command. If error_string is passed, it is printed to
# to standard out before exiting and is padded by blank lines
# if error_string is not "". Pass -b before exit_number to
# suppress beginning padding line, -e to suppress ending
# padding line, both to suppress both. Also removes temp
# files and kills Terminal if need be.
local PadBeginning=true
local PadEnd=true
while [ "$1" ] ; do
case "$1" in
-b)
PadBeginning=false
-e)
PadEnd=false
break
esac
shift
done
rm -f "$FilesRemovedList" "$FilesRemovedFilesOnlyList" "$LogFile" 2>/dev/null 1>&2
if $QuitTerminalForcefully ; then
KillTerminal
if [ $# -gt 1 ] ; then
if [ -z "$2" ] ; then
PadBeginning=false
PadEnd=false
$PadBeginning && echo
printf "%s
" "$2"
$PadEnd && echo
if [ "z$ShowQuitMessage" = ztrue -a "z$RunScriptAsStandAlone" = ztrue ] ; then
[ $# -lt 2 -o ( $PadEnd = false -a -n "$2" ) ] && echo
echo "NOTE: If you double-clicked this program, quit Terminal application now."
[ $PadEnd = true -o -z "$2" ] && echo
[ -z "$1" ] && exit 0
[ -z "expr "$1" / 1 2>/dev/null
" ] && exit 255 || exit $1
FinishCleanup()
# Usage: FinishCleanup
# Summary: Displays then deletes the file named by LogFile, a log
# of files not removed by RemoveItem function, if ErrorOccurred
# is true. If NoFilesToRemove is true, a message is shown
# and the function is exited. If RemoveInvisibleFilesOnly
# is true, a message is shown and the function is exited;
# otherwise, a message is shown. Returns value assigned to
# ExitCodeWhenSomeFileWasNotRemoved if ErrorOccurred is true,
# 0 otherwise.
local ContainingFolder
local EachItemFound
local EachItemToPurge
local FilesThatRemain
if $DoShowOnlyFilesThatShouldHaveBeenUninstalled ; then
# Translate [ into [ to avoid text in between [ and ] being treated as a bracket expression
PatternForOmission=echo "$NotRemovedByNIS6UninstallerText|$NotRemovedBySymantecUninstallerText" | sed 's|[|[|g'
FilesThatRemain=cat "$FilesRemovedList" 2>/dev/null | grep '^/' | egrep -ve "$PatternForOmission"
IFS=$'
' # Set IFS to newlines
# For each item that should remain after uninstall, with periods escaped
for EachItemToPurge in echo "$ItemsThatShouldRemainAfterUninstall" | sed 's|.|.|g'
; do
# For each item found in the list of remaining files, with or without /Volume/* prefix
for EachItemFound in echo "$FilesThatRemain" | egrep -xe "$EachItemToPurge|/Volumes/[^/]+$EachItemToPurge"
; do
# Remove it from the list
FilesThatRemain=echo "$FilesThatRemain" | grep -vxe "$EachItemFound"
ContainingFolder=dirname "$EachItemFound"
# While containing folder is in list
while [ "echo "$FilesThatRemain" | grep -xe "$ContainingFolder"
" ] ; do
# If the containing folder contains another file in the list
if [ "echo "$FilesThatRemain" | grep -e "^$ContainingFolder/."
" ] ; then
# Don't remove the containing folder from list
break
# Remove the containing folder from the list
FilesThatRemain=echo "$FilesThatRemain" | grep -vxe "$ContainingFolder"
ContainingFolder=dirname "$ContainingFolder"
done
# If nothing is left in the list, stop processing
[ -z "$FilesThatRemain" ] && break
done
done
IFS="$SavedIFS"
if [ "$FilesThatRemain" ] ; then
return $ExitCodeWhenFilesRemain
return 0
elif $CreateFilesRemovedListOnly ; then
clear >&2
if $UseMore ; then
ShowContents "$FilesRemovedList"
echo "" >&2
echo "NOTE: No files have been removed." >&2
echo "" >&2
/bin/rm -rf "$FilesRemovedList" "$FilesRemovedFilesOnlyList" 2>/dev/null 1>&2
return 0
elif $ErrorOccurred ; then
echo
# Display LogFile
ShowContents "$LogFile"
# Remove LogFile
/bin/rm -rf "$LogFile" 2>/dev/null 1>&2
echo
if $RemoveInvisibleFilesOnly ; then
echo "NOTE: Not all of the invisible Symantec files were removed."
echo " Make sure each volume passed is unlocked and accessible."
echo "NOTE: Not all folders/files were removed."
echo " Perhaps a file or folder listed above is in use or a folder"
echo " listed above is not empty."
if $RestartMayBeNeeded ; then
echo
echo "Some Symantec product files have been removed from the boot volume."
if $SomeFileWasRemoved ; then
echo
echo "Some folders or files have been removed."
return $ExitCodeWhenSomeFileWasNotRemoved
if $NoFilesToRemove ; then
echo "There were no invisible Symantec files to be removed."
echo "AntiVirus QuickScan and/or Symantec FS files have been removed."
return 0
echo "There were no files that needed to be removed. No files were removed."
return 0
$RemoveCrontabEntriesOnly && return 0
echo
printf "Symantec product files have been removed from the boot volume"
if $SomeFileWasRemovedFromNonBootVolume ; then
echo
echo "and from other volume(s) listed above."
echo "."
echo "Symantec product files have been removed from the above volume(s)."
return 0
GetAdminPassword()
# Usage: GetAdminPassword [$1]
# Argument: $1 - Prompt for password. If true is passed, a user that
# is not root will always be asked for a password. If
# something other than true is passed or if nothing is
# passed, then a user that is not root will only be
# prompted for a password if authentication has lapsed.
# Summary: Gets an admin user password from the user so that
# future sudo commands can be run without a password
# prompt. The script is exited with a value of 1 if
# the user enters an invalid password or if the user
# is not an admin user. If the user is the root user,
# then there is no prompt for a password (there is
# no need for a password when user is root).
# NOTE: Make sure ExitScript function is in the script.
# If root user, no need to prompt for password
[ "whoami
" = "root" ] && return 0
echo >&2
# If prompt for password
if [ "$1" = "true" ] ; then
ShowVersion >&2
echo >&2
sudo -k >&2 # Make sudo require a password the next time it is run
echo "You must be an admin user to run this script." >&2
# A dummy sudo command to get password
sudo -p "Please enter your admin password: " date 2>/dev/null 1>&2
if [ ! $? = 0 ] ; then # If failed to get password, alert user and exit script
echo "You entered an invalid password or you are not an admin user. Script aborted." >&2
ExitScript 1
GetComputerUsers()
# Usage: GetComputerUsers [-r] [volume]
# Version: 1.0.1
# Summary: Defines the following variables:
# ComputerUsers
# ComputerUsersHomeDirs
# ComputerUsersHomeDirsAndRootDir
# ComputerUsersTable
# Omitted are users whose home directories contain no Library
# directory and users that are not root whose home directory is
# /var/root. If volume is passed and there is no /Users on that
# volume, variables are all set to "". ComputerUsersTable is a
# list of users and their home directories, separated by tabs.
# Note: This function must be run as root to find all users. When an
# OS X volume other than / is passed or if the dscl program fails
# or does not exist, non-root users that do not have their home
# directories in /Users are not included and root's home directory
# is assumed to be /var/root.
# History: 1.0.1 - 08/11/2014 - Corey Swertfager:
# Added ComputerUsersTable variable assignment.
# Now always includes root user in case this function
# is not run as root.
# Added volume argument.
local CurrentDir
local GCUHomeDir
local CGLibraryDir
local CGLibraryDirs
local GCUUser
local GCUUsers
local VolumePassed="$1"
ComputerUsers=""
ComputerUsersHomeDirs=""
ComputerUsersHomeDirsAndRootDir=""
ComputerUsersTable=""
# If a directory other than / is passed
if [ -d "$VolumePassed" -a ! "$VolumePassed" -ef / ] ; then
# If not an OS X volume, skip it
[ ! -d "$VolumePassed/Users" ] && return
CurrentDir=pwd
cd "$VolumePassed"
CGLibraryDirs=ls -d Users/
/Library 2>/dev/null | grep -v 'Users/Shared'
cd "$CurrentDir"
# If no Library folders were found, skip
[ -z "$CGLibraryDirs" ] && return
CGLibraryDirs="$CGLibraryDirs
var/root/Library"
IFS='
for CGLibraryDir in $CGLibraryDirs ; do
GCUHomeDir="/dirname "$CGLibraryDir"
GCUUser=basename "$GCUHomeDir"
ComputerUsersHomeDirs="$ComputerUsersHomeDirs
$GCUHomeDir"
ComputerUsers="$ComputerUsers
$GCUUser"
ComputerUsersTable="$ComputerUsersTable
$GCUUser $GCUHomeDir"
done
GCUUsers=dscl . list /Users 2>/dev/null | egrep '^[[:alnum:]]' | egrep -vx 'daemon|nobody'
if [ -z "$GCUUsers" ] ; then
GCUUsers="ls /Users | egrep '^[[:alnum:]]' | grep -vx Shared
root"
IFS='
for GCUUser in $GCUUsers ; do
GCUHomeDir=echo $(eval echo ~"$GCUUser")
# If home directory could not be evaluated
if [ "printf "%s" "$GCUHomeDir" | grep '^~'
" ] ; then
continue
elif [ "$GCUUser" != root ] ; then
if [ ! -d "$GCUHomeDir/Library" ] ; then
continue
elif [ "$GCUHomeDir" = /var/root ] ; then
continue
$GCUUser"
$GCUHomeDir"
done
IFS="$SavedIFS"
ComputerUsers=echo "$ComputerUsers" | grep . | sort -f | uniq
ComputerUsersHomeDirs=echo "$ComputerUsersHomeDirs" | grep / | sort -f | uniq
ComputerUsersHomeDirsAndRootDir="/
ComputerUsersTable=echo "$ComputerUsersTable" | grep / | sort -f | uniq
KillNortonZone()
$CreateFilesRemovedListOnly && return
ZoneProcesses=ps -axww | grep "Norton Zone.app/Contents/MacOS/Norton Zone" | grep -v grep | awk '{print $1}'
for EachZoneAppPID in $ZoneProcesses ; do
kill -9 "$EachZoneAppPID"
done
[ "$ZoneProcesses" ] && killall Finder
KillSymantecProcesses()
# Usage: KillSymantecProcesses [-n] [ProcessPattern [ProductName]]
# Kills Symantec processes that match extended regular expression
# ProcessPattern. If ProcessPattern is not passed, all processes
# that match those in ProcessPatternDefault are used. If ProductName
# is passed, that name is shown when kill attempt is made; otherwise
# "Symantec" is shown.
# If -n is passed as the first argument, no kill is attempted and no
# output is shown.
# Returns 1 if there remains some matching process in memory, 0 if not.
# Version: 1.0.2
# History: 1.0.1 - 07/24/2014 - Corey Swertfager:
# Added ProcessPattern and ProductName arguments.
# Added definitions of ProcessesToSkipPattern and
# ProcessPatternDefault.
# Added -n option.
# 1.0.2 - 08/27/2014 - Corey Swertfager:
# Now uses egrep instead of grep for process matching.
# Now excludes process that include the name of the
# script that is running this function.
# Now excludes Symantec Uninstaller.app and SymantecRemovalTool
# when no ProcessPattern is passed.
# Changed -c to -n in Usage.
local aUID
local DoKill=true
local ExclusionPattern
local NoKillOption="-n"
local ProcessesToSkipPattern="/LiveUpdateAdminUtility/|/RemoveSymantecMacFiles.command|/RemoveSymantecMacFiles.command|/Symantec Uninstaller.app|/SymantecRemovalTool"
local ProcessPattern
local ProcessPatternDefault="/Application Support/Norton|/Application Support/Symantec|/Applications/Norton|/Applications/Symantec|PrivateFrameworks/NPF|PrivateFrameworks/Sym|/StartupItems/.Norton|/StartupItems/NUMCompatibilityCheck|/StartupItems/SMac Client|/StartupItems/Sym|/StartupItems/TrackDelete|/StartupItems/VolumeAssist"
local ProductName
local UIAGENT_USERS
if [ "z$1" = "z$NoKillOption" ] ; then
shift
DoKill=false
ProcessPattern="$1"
ProductName="$2"
ExclusionPattern=basename "$0" 2>/dev/null | sed 's/././g'
# If script name was successfully obtained
if [ "$ExclusionPattern" ] ; then
# Add / + current script name to ExclusionPattern
ExclusionPattern=" egrep -|/$ExclusionPattern$|/$ExclusionPattern "
ExclusionPattern=" egrep -"
if [ -z "$ProcessPattern" ] ; then
ProcessPattern="$ProcessPatternDefault"
ProcessesToSkipPattern="$ExclusionPattern|$ProcessesToSkipPattern"
ProcessesToSkipPattern="$ExclusionPattern"
if [ -z "$ProductName" ] ; then
ProductName="Symantec"
Processes=ps -wwax | egrep -i "$ProcessPattern" | egrep -v "$ProcessesToSkipPattern" | sort -f | uniq
if [ $DoKill = true -a -n "$Processes" ] ; then
IFS='
# If launchctl program exists, unload SymUIAgent
if which launchctl &>/dev/null ; then
# Code by Haridharan Nattamaig to unload SymUIAgent
UIAGENT_USERS=ps -aef | grep SymUIAgent | grep -v grep | awk '{print $1}' | sort | uniq
for aUID in ${UIAGENT_USERS} ; do
id -u ${aUID} >& /dev/null
if [ $? -eq 0 ] ; then
echo "Unloading SymUIAgent for UID $aUID"
sudo -u #${aUID} launchctl unload /Library/LaunchAgents/com.symantec.uiagent.application.plist >& /dev/null
done
echo "Ending $ProductName processes..."
for TheProcess in $Processes ; do
echo "$TheProcess"
kill -9 echo "z $TheProcess" | awk '{print $2}'
done
IFS="$SavedIFS"
if [ "$Processes" ] ; then
if $DoKill ; then
echo " $ProductName processes still in memory:"
echo "$Processes"
return 1
if $DoKill ; then
echo " There are no $ProductName processes in memory"
return 0
KillTerminal()
ProcessLines=ps -axww | grep -e "/Applications/Utilities/Terminal.app" | grep -v grep | sort -f
if [ -z "$ProcessLines" ] ; then
return
elif [ echo "$ProcessLines" | grep . -c
-gt 1 -a $QuitTerminalForcefullyForAll = false ] ; then
echo "NOTE: Terminal was launched more than once so it could not be quit."
echo " Use the -QQ option to force Terminal to be quit for all users."
return
echo "WARNING: Quitting Terminal."
IFS='
for ProcessLine in $ProcessLines ; do
ProcessID=printf "%s" "$ProcessLine" | awk '{print $1}'
kill -9 "$ProcessID"
done
ProcessAppRemoval()
# Usage: ProcessAppRemoval
# Summary: If OS 10.15 or later is running, a Symantec app for 8.5 or later
# is installed in /Applications, MES silo exists, and this script
# is not just generating a list of installed files: prompts user to
# drag app to the trash and quits; if no options were passed, also
# prompts user to press return to open the /Applications folder,
# and then once return is pressed quits.
local AppDir="/Applications"
local SEPAppPattern="^Symantec.Protection..app"
local AppPattern="^Norton.(360|AntiVirus|Security)..app|$SEPAppPattern"
local App
local Apps
local Dummy
local MESSilo="/Library/Application Support/Symantec/Silo/MES"
local OSXmajorVersionMinimum=15
local ProductName
local SymantecSolutionsDir="$AppDir/Symantec Solutions"
# If OS version is less than 10.15, there is no MES silo, or only generating a list of installed files
if [ $OSXmajorVersion -lt $OSXmajorVersionMinimum -o ! -d "$MESSilo" -o $CreateFilesRemovedListOnly = true ] ; then
# Allow script to continue
return
Apps=ls "$AppDir" 2>/dev/null | egrep -ie "$AppPattern" | sort -f
# If no Symantec or Norton apps were found in the /Applications folder
if [ -z "$Apps" ] ; then
# Check for SEP in Symantec Solutions
App=ls "$SymantecSolutionsDir" 2>/dev/null | egrep -ie "$SEPAppPattern" | sort -f | head -n 1
# If SEP is not installed there
if [ -z "$App" ] ; then
return
ProductName=basename "$App" .app
clear
# We must remove the .app to trigger the system extension removal.
# Directly remove the /Applications/Symantec Solutions won't work.
if RemoveApp "$SymantecSolutionsDir/$App"; then
return
echo
echo "ATTENTION: You must use the uninstall option in your product's"
echo " "$ProductName" menu."
echo
if $RunScriptAsStandAlone ; then
echo "Press return to open $ProductName."
read Dummy
open "$SymantecSolutionsDir/$App"
ExitScript 2
clear
if RemoveApp "$AppDir/$Apps"; then
return
echo
echo "ATTENTION: To uninstall you must drag the following from the"
echo " "$AppDir" folder to the trash:"
echo
echo "$Apps" | awk '{print " " $0}'
echo
echo "Press return to open the "$AppDir" folder."
read Dummy
open "$AppDir"
ExitScript 2
RemoveApp()
# Usage: RemoveApp $1
# Argument: $1 = App to remove.
# Summary: Use AppleScript to move app to Trash so that system extension
# will be uninstalled after reboot.
local app="$1"
if [ -z "$app" ] | [ ! -d "$app" ]; then
return 1
echo "Removing $app" osascript -e "tell application "Finder" to delete POSIX file "${app}""
if [ -d "$app" ]; then
echo Failed to remove $app.
return 1
echo $app was successfully removed.
return 0
ProcessArguments()
# Usage: ProcessArguments [ --OptionTakesUnparsedArgument=string ] [ --OptionIsOneArgument=string ] "$@"
# Version: 1.0.1
# Summary: Processes arguments passed to script. Arguments beginning with a
# single hyphen (-) are parsed into separate options except when an
# argument is negative integer. Arguments beginning with two hypens
# are treated as one argument; if the argument contains is an equals
# sign (=), the string after the first "=" is treated as a separate
# argument (i.e., the value assigned to the double-hyphen argument).
# For each --OptionTakesUnparsedArgument passed before "$@", the string
# after "=" is used as an option that takes the next argument in full
# without parsing it (see examples below); string must be a hyphen
# followed by a single character.
# For each --OptionIsOneArgument passed before "$@", the string after
# "=" is used as an option that should be treated as a single argument.
# This is useful when processing an argument that begins with a single
# hyphen to avoid having that argument parsed into separate options.
# The referenced option cannot be embedded within other options (see
# final example below).
# "$@" must be the last argument passed to ProcessArguments. Put all custom
# option handling between "--- Customized argument handling begins here ---"
# and "--- Customized argument handling ends here ---".
# Note: ProcessArgumentsNextArgument may be called to verify and obtain the
# next argument after or before a given option; see that function's usage
# for more details. OriginalArgumentNumber can be used to determine if
# two arguments were originally passed within the same string of options.
# Examples: These examples have expanded the arguments passed as "$@".
# ProcessArguments -ab -c
# Would process three arguments: -a, -b, and -c
# ProcessArguments --ab -c
# Would process two arguments: --ab and -c
# ProcessArguments --equation=a=b+c
# Would process two arguments: --equation and a=b+c
# ProcessArguments -10
# Would process one argument: -10
# ProcessArguments -10a
# Would process three arguments: -1, -0, -a
# ProcessArguments --OptionTakesUnparsedArgument=-e -e -ger
# Would process two arguments: -e and -ger
# ProcessArguments --OptionTakesUnparsedArgument=-e -peer
# Would process three arguments: -p, -e, and er
# ProcessArguments --OptionTakesUnparsedArgument=-e --OptionTakesUnparsedArgument=-t -eter -ter
# Would process four arguments: -e, ter, -t, and er
# ProcessArguments --OptionIsOneArgument=-hi -hi
# Would process one argument: -hi
# ProcessArguments --OptionIsOneArgument=-hi -his
# Would process three arguments: -h, -i, and -s
# History: 1.0.1 - 06/23/2013 - Corey Swertfager:
# Added processing of options within a string that begins
# with a single hyphen.
# Added --OptionTakesUnparsedArgument option.
# Added --OptionIsOneArgument option.
local ArgList=""
local ArgsToAdd
local ArgWasAdded=false
local CurrentArgNumber=1
local CurrentArgument
local CurrentCharacter
local DoNotParseNextArgument=false
local NextArgument=""
local NumberOfArgumentsPassed
local NumberOfArgumentsToUse=0
local OptionToAdd
local OriginalArgumentNumber=0
local OriginalArgumentNumberList=""
local RemainingOptionsInString
local TableOfOptionsWithoutParsing=" Each option in this table will have its succeeding argument left unparsed. "
local TableOfUndividedArguments=" Each item in this table should each be treated as single argument. "
while [ "$1" ] ; do
case "$1" in
--OptionIsOneArgument)
ExitScript 99 "WARNING: Bad use of --OptionIsOneArgument passed to ProcessArguments:
"$1""
--OptionIsOneArgument=)
OptionToAdd=printf "%s" "$1" | awk '{match($0,"=") ; print substr($0,RSTART+1)}'
[ -z "$OptionToAdd" ] && ExitScript 99 "WARNING: Bad use of --OptionIsOneArgument passed to ProcessArguments:
"$1""
TableOfUndividedArguments="$TableOfUndividedArguments
$OptionToAdd"
--OptionTakesUnparsedArgument|--OptionTakesUnparsedArgument=)
[ -z "printf "%s" "$OptionToAdd" | grep -xe '-.'
" ] && ExitScript 99 "WARNING: Bad use of --OptionTakesUnparsedArgument passed to ProcessArguments:
"$1""
TableOfOptionsWithoutParsing="$TableOfOptionsWithoutParsing
$OptionToAdd"
break
esac
shift
done
NumberOfArgumentsPassed=$#
while [ $# != 0 ] ; do
let OriginalArgumentNumber=$OriginalArgumentNumber+1
# If argument is in the list of arguments whose next argument should not be parsed
if [ "printf "%s" "$1" | grep -xF "$TableOfOptionsWithoutParsing"
" ] ; then
ArgsToAdd="$1"
OriginalArgumentNumberList="$OriginalArgumentNumberList
$OriginalArgumentNumber"
DoNotParseNextArgument=true
# Else if argument is in the list of arguments that should be treated as one argument
elif [ "printf "%s" "$1" | grep -xF "$TableOfUndividedArguments"
" ] ; then
ArgsToAdd="$1"
case "$1" in
# If argument was a hyphen or a hyphen followed by a single character
ArgsToAdd="$1"
# If a value was passed to the option that begins with --
if [ "printf "%s" "$1" | grep =
" ] ; then
# Add the option and its value as separate arguments
ArgsToAdd="printf "%s" "$1" | awk -F = '{print $1}'
ArgsToAdd="$1"
# If argument should not be parsed or is a negative integer
if [ $DoNotParseNextArgument = true -o -z "printf "%s" "$1" | awk '{print substr($0,2)}' | tr -d '[:digit:]'
" ] ; then
# Treat argument as a single argument
ArgsToAdd="$1"
# Parse string into separate arguments
ArgsToAdd=""
RemainingOptionsInString=printf "%s" "$1" | awk '{print substr($0,2)}'
while [ "$RemainingOptionsInString" ] ; do
CurrentCharacter=printf "%s" "$RemainingOptionsInString" | awk '{print substr($0,1,1)}'
# Prefix the character with a hyphen and add as an argument
if [ "$ArgsToAdd" ] ; then
ArgsToAdd="$ArgsToAdd
-$CurrentCharacter"
ArgsToAdd="-$CurrentCharacter"
RemainingOptionsInString=printf "%s" "$RemainingOptionsInString" | awk '{print substr($0,2)}'
# If this is an option whose next string should not be parsed
if [ "printf "%s" "$TableOfOptionsWithoutParsing" | grep -xe "-$CurrentCharacter"
" ] ; then
# If string has characters remaining after that option
if [ "$RemainingOptionsInString" ] ; then
# Add remainder of string as the unparsed string argument
# Use next argument passed as unparsed string argument
break
done
ArgsToAdd="$1"
esac
if $ArgWasAdded ; then
ArgList="$ArgList
$ArgsToAdd"
ArgList="$ArgsToAdd"
ArgWasAdded=true
shift
done
if [ $NumberOfArgumentsPassed -gt 0 ] ; then
# Add a non-blank line to ArgList in case last argument passed was ""
ArgList="$ArgList
TheEnd"
OriginalArgumentNumberList=echo "$OriginalArgumentNumberList" | grep .
NumberOfArgumentsToUse=printf "%s" "$ArgList" | grep "" -c
let NumberOfArgumentsToUse=$NumberOfArgumentsToUse-1
# --- Customized argument handling begins here ---
BootVolumeWillBeSearched=false
DoBackupLogs=true
DoKillProcesses=true
DoRemoveFSDFolders=true
DoRemoveInstallerLaunchAgents=true
DoRemoveIPUA=true
DoRemoveLogs=true
DoRemoveMDMProfile=true
DoRemoveMidDat=true
DoRemoveMigrationFiles=true
DoRunPredeleteScripts=true
DoShowOnlyFilesThatShouldHaveBeenUninstalled=false
FindOption1=""
FindOption2=""
ListOnlyFilesThatExist=false
NoFilesToRemove=true
PauseBeforeRestarting=true
QuitTerminalForcefully=false
QuitTerminalForcefullyForAll=false
QuitWithoutRestarting=false
$AutoRunScript && QuitWithoutRestarting=true
RemoveCrontabEntries=true
RemoveCrontabEntriesOnly=false
RemoveInvisibleFiles=true
RemoveInvisibleFilesOnly=false
RemoveFromAllVolumes=false
RemoveFromOtherVolumes=false
RestartAutomatically=false
RestartMayBeNeeded=false
ShowFilesAsRemoved=true
ShowOnlyRegularFiles=false
ShowPredeleteErrors=true
ShowQuitMessage=true
SomeFileWasRemoved=false
SomeFileWasRemovedFromNonBootVolume=false
SomeFileWasRemovedFromBootVolume=false
UseMore=false
while [ $CurrentArgNumber -le $NumberOfArgumentsToUse ] ; do
CurrentArgument=printf "%s" "$ArgList" | head -n $CurrentArgNumber | tail -n 1
OriginalArgumentNumber=echo "$OriginalArgumentNumberList" | head -n $CurrentArgNumber | tail -n 1
case "$CurrentArgument" in
-A)
RemoveFromAllVolumes=true
-c)
RemoveCrontabEntriesOnly=true
RemoveInvisibleFiles=false
-C)
RemoveCrontabEntries=false
-d)
DoRunPredeleteScripts=false
-E)
ShowPredeleteErrors=false
-e)
-F)
CreateFilesRemovedListOnly=true
ListOnlyFilesThatExist=true
ShowOnlyRegularFiles=true
FindOption1=-type
FindOption2=f
-f)
ShowFilesAsRemoved=false
-g)
DoRemoveLogs=false
-H)
ShowUsage 0
-h)
ShowHelp 0
-i)
RemoveInvisibleFilesOnly=true
-I)
-k)
DoKillProcesses=false
-l|-R)
-L)
-m)
UseMore=true
-p)
PauseBeforeRestarting=false
-q)
-Q)
# If -Q was previously passed, treat as -QQ
# Treat as if -QQ was passed
QuitTerminalForcefullyForAll=true
QuitTerminalForcefully=true
-QQ)
-r|-re)
RestartAutomatically=true
-u)
DoShowOnlyFilesThatShouldHaveBeenUninstalled=true
-V)
echo $Version
ExitScript 0
AssignVolume "$CurrentArgument" # Assign it to a Volume variable
# If not a valid volume
if [ $? = 1 ] ; then
ShowUsage 4 "ERROR: Invalid option or volume name: "$CurrentArgument"."
RemoveFromOtherVolumes=true
esac
let CurrentArgNumber=$CurrentArgNumber+1
done
[ "echo "$ListOfProgramsThatShouldNotBackUpLogs" | grep -x "$FullScriptName"
" ] && DoBackupLogs=false
[ "echo "$ListOfProgramsThatShouldNotKillProcesses" | grep -x "$FullScriptName"
" ] && DoKillProcesses=false
[ "echo "$ListOfProgramsThatShouldNotRemoveFSDFolders" | grep -x "$FullScriptName"
" ] && DoRemoveFSDFolders=false
[ "echo "$ListOfProgramsThatShouldNotRemoveInstallerLaunchAgents" | grep -x "$FullScriptName"
" ] && DoRemoveInstallerLaunchAgents=false
[ "echo "$ListOfProgramsThatShouldNotRemoveLogs" | grep -x "$FullScriptName"
" ] && DoRemoveLogs=false
[ "echo "$ListOfProgramsThatShouldNotRemoveMDMProfile" | grep -x "$FullScriptName"
" ] && DoRemoveMDMProfile=false
[ "echo "$ListOfProgramsThatShouldNotRemoveMidDat" | grep -x "$FullScriptName"
" ] && DoRemoveMidDat=false
[ "echo "$ListOfProgramsThatShouldNotRemoveMigrationFiles" | grep -x "$FullScriptName"
" ] && DoRemoveMigrationFiles=false
[ "echo "$ListOfProgramsThatShouldNotRemoveSymantecIPUA" | grep -x "$FullScriptName"
" ] && DoRemoveIPUA=false
# --- Customized argument handling ends here ---
ProcessArgumentsNextArgument()
# Usage: ProcessArgumentsNextArgument [exit_code] [-F | -P] [-p | -r ] [operator]
# Version: 1.0.0
# Arguments: exit_code Pass integer in range 0-255 to ShowUsage when next
# argument is missing or invalid. If exit_code is not
# specified, 0 is assumed.
# -F Assign the full logical path to NextArgumentFullPath.
# This is the default. ShowFullFilePath function must
# be included in script. If no operator was passed, -E
# is the assumed operator.
# -P Assign the full physical path to NextArgumentFullPath.
# ShowFullFilePath function must be included in script.
# If no operator was passed, -e is the assumed operator.
# -p Get previous argument instead of next argument. If
# there is no previous argument, sets NextArgument to ""
# and returns 1.
# -r Return 1 instead of exiting script if there is no next
# argument. Sets NextArgument to "".
# operator Operator used to test next argument:
# -d Folder
# -E File, folder, or link
# -e File, folder, or link to an existing file/folder
# -f File
# -i [min [max]]
# Integer in range min-max; pass "" to min and
# an integer to max if there is no minimum but
# a maximum is desired; pass "" to to both min
# and max if passing another option after the -i
# option. Also tests to see if the value of the
# next argument is out of range for the currently
# running version of Mac OS.
# -L Link; does not check to see if link is broken
# unless -P option was also passed
# -l Link to an existing file/folder
# -n Non-null string
# Summary: Called by ProcessArguments 1.0.1 or later to assign values to:
# CurrentArgNumber
# NextArgument
# NextArgumentFullPath
# NextArgumentOriginalArgumentNumber
# using pre-existing values of:
# ArgList
# CurrentArgNumber
# CurrentArgument
# OriginalArgumentNumberList
# NumberOfArgumentsToUse
# Returns 0 if next or previous argument was assigned to NextArgument,
# CurrentArgNumber was incremented (or decremented if -p was passed),
# and NextArgumentOriginalArgumentNumber was assigned.
# Assigns "" to NextArgument and NextArgumentFullPath and returns 1 if
# -p is passed and there is no previous argument, or if -r is passed
# and there is no next argument; otherwise, calls ShowUsage to show
# error message and exit script if operator test fails or if there is
# no next or previous argument.
# Note: ShowFullFilePath function must be included in script in order to
# assign a value to NextArgumentFullPath.
# Examples: ProcessArgumentsNextArgument
# Returns 0 if there was a next argument; otherwise, passes 0 to
# ShowUsage and displays error message about missing argument.
# ProcessArgumentsNextArgument -r
# Returns 0 if there was a next argument; otherwise, assigns "" to
# NextArgument and NextArgumentFullPath, then returns 1.
# ProcessArgumentsNextArgument 2 -d
# Returns 0 if NextArgument was set to a folder; otherwise, passes
# 2 to ShowUsage and displays error message if the next argument is
# missing or is not a folder.
# ProcessArgumentsNextArgument 3 -r -d
# Returns 0 if NextArgument was set to a folder. If the next argument
# is missing, assigns "" to NextArgument and NextArgumentFullPath,
# then returns 1. If next argument is not a folder, passes 3 to
# ShowUsage and displays error message.
# ProcessArgumentsNextArgument 4 -i 1
# Returns 0 if NextArgument was set to an integer; otherwise, passes
# 4 to ShowUsage and displays error message if the next argument is
# missing, is not an integer, or is less than 1.
# ProcessArgumentsNextArgument -i "" 100 5
# 5 to ShowUsage and displays error message if the next argument is
# missing, is not an integer, or is greater than 100.
# ProcessArgumentsNextArgument -i "" "" 6
# 6 to ShowUsage and displays error message if the next argument is
# missing or is not an integer.
local DoShowMissingError=true
local DirectionText=after
local ExitCode=0
local ErrorText=""
local GoToPreviousArgument=false
local Max
local Min
local NextArgumentOriginal
local PathOption=""
local TestOperator=""
NextArgumentFullPath=""
while [ "$1" ] ; do
case "$1" in
-d)
ErrorText="folder"
TestOperator="$1"
-E)
ErrorText="file, folder, or link"
TestOperator="$1"
-e)
ErrorText="file or folder"
TestOperator="$1"
-F)
PathOption="$1"
if [ -z "$ErrorText" ] ; then
TestOperator="-E"
-f)
ErrorText="file"
TestOperator="$1"
-i)
ErrorText="integer"
TestOperator="$1"
Min="$2"
Max="$3"
shift 2
-L)
ErrorText="link"
TestOperator="$1"
[ "z$PathOption" = "z-P" ] && ErrorText="unbroken link"
-l)
TestOperator="-L"
-n)
ErrorText="non-null string"
TestOperator="$1"
-P)
PathOption="$1"
TestOperator="-e"
elif [ "$ErrorText" = "link" ] ; then
-p)
GoToPreviousArgument=true
DirectionText=before
-r)
DoShowMissingError=false
ExitCode=printf "%s" "$1" | tr -d -c "[:digit:]"
[ -z "$ExitCode" ] && ExitCode=0
esac
shift
done
if $GoToPreviousArgument ; then
if [ $CurrentArgNumber -gt 1 ] ; then
let CurrentArgNumber=$CurrentArgNumber-1
NextArgument=printf "%s" "$ArgList" | head -n $CurrentArgNumber | tail -n 1
NextArgumentOriginalArgumentNumber=echo "$OriginalArgumentNumberList" | head -n $CurrentArgNumber | tail -n 1
NextArgument=""
return 1
# Else if there are no more arguments in ArgList
elif [ $CurrentArgNumber = $NumberOfArgumentsToUse ] ; then
if $DoShowMissingError ; then
ShowUsage $ExitCode "ERROR: Nothing was passed after $CurrentArgument" >&2
NextArgument=""
return 1
NextArgumentFullPath=ShowFullFilePath $PathOption "$NextArgument"
if [ "z$ErrorText" = zinteger ] ; then
NextArgumentOriginal="$NextArgument"
if [ -z "$NextArgument" ] ; then
ShowUsage $ExitCode "ERROR: Argument passed $DirectionText $CurrentArgument is not an integer: "$NextArgumentOriginal"" >&2
# Else if argument contains something other than a hyphen or digits
elif [ "printf "%s" "$NextArgument" | tr -d "[:digit:]-"
" ] ; then
# Else if argument contains a hyphen that is not at the beginning
elif [ "printf "%s" "$NextArgument" | grep '..
" ] ; then
NextArgument=expr "$NextArgument" / 1 2>/dev/null
test "$NextArgumentOriginal" -eq "$NextArgument" 2>/dev/null
ShowUsage $ExitCode "ERROR: Value passed $DirectionText $CurrentArgument is out of range for this OS:
$NextArgumentOriginal" >&2
# If minimum value was specified
if [ "$Min" ] ; then
[ $NextArgument -lt $Min ] && ShowUsage $ExitCode "ERROR: Value passed $DirectionText $CurrentArgument ($NextArgumentOriginal) is less than
minimum value ($Min)." >&2
# If maximum value was specified
if [ "$Max" ] ; then
[ $NextArgument -gt $Max ] && ShowUsage $ExitCode "ERROR: Value passed $DirectionText $CurrentArgument ($NextArgumentOriginal) is greater than
maximum value ($Max)." >&2
elif [ "z$ErrorText" = "zfile, folder, or link" ] ; then
[ ! -e "$NextArgument" -a ! -L "$NextArgument" ] && ShowUsage $ExitCode "ERROR: Argument passed $DirectionText $CurrentArgument is not a $ErrorText:
"$NextArgument"" >&2
elif [ "z$ErrorText" = "zunbroken link" ] ; then
if [ ! -L "$NextArgument" ] ; then
ShowUsage $ExitCode "ERROR: Argument passed $DirectionText $CurrentArgument is not a link:
# Else if link is broken
elif [ ! -e "$NextArgument" ] ; then
ShowUsage $ExitCode "ERROR: The target of the link passed $DirectionText $CurrentArgument does not exist:
elif [ "$ErrorText" ] ; then
[ ! $TestOperator "$NextArgument" ] && ShowUsage $ExitCode "ERROR: Argument passed $DirectionText $CurrentArgument is not a $ErrorText:
if [ "$PathOption" ] ; then
if [ -z "$NextArgumentFullPath" ] ; then
if [ -L "$NextArgument" ] ; then
ExitScript $ExitCode "WARNING: ShowFullFilePath function could not resolve path for:
return 0
RemoveAllSymantecFiles()
# Usage: RemoveAllSymantecFiles $1
# Summary: Removes all OS X Symantec products' files and folders
# from volume named by $1 if RemoveInvisibleFilesOnly
# equals false; otherwise, removes only the invisible Symantec
# files. Removes the invisible Symantec files from other
# volumes that are passed to the script. Symantec crontab
# entries are removed if RemoveCrontabEntries = true.
# If not a valid volume, return 1
[ -z "CheckIfValidVolume "$1"
" ] && return 1
CurrentVolumeBeingUsed="$1"
GetComputerUsers "$CurrentVolumeBeingUsed"
printf "" > "$FilesRemovedFilesOnlyList"
if [ echo "$ListOfVolumesToUse" | grep -c .
-gt 1 ] ; then
if [ "$1" = / ] ; then
echo "------ Volume: / (current boot volume) ------" >> "$FilesRemovedList"
echo "------ Volume: "basename "$1"
" ------" >> "$FilesRemovedList"
$RemoveCrontabEntries && DeleteCrontabEntries "$1"
$RemoveCrontabEntries && DeleteLaunchdPlists "$1"
! $RemoveInvisibleFilesOnly && DeleteSymantecLoginItems "$1"
if ! $RemoveInvisibleFilesOnly ; then
RunPredeleteScripts "$1"
if $ListOnlyFilesThatExist ; then
echo "The following files/folders currently exist and would be removed unless" >> "$FilesRemovedList"
echo "otherwise noted:" >> "$FilesRemovedList"
echo "$FullScriptName would attempt to find and remove the following:" >> "$FilesRemovedList"
RemoveInvisibleFilesFromVolume "$1"
$RemoveInvisibleFilesOnly && return 0
# If not just creating a list of removed files
if ! $CreateFilesRemovedListOnly ; then
# If removing files from the boot volume
if [ "z$CurrentVolumeBeingUsed" = z/ ] ; then
DeleteDefaults
if $DoRemoveMDMProfile ; then
echo "Removing system profile if it exists: com.symc.enroll"
profiles -R -p com.symc.enroll &>/dev/null
# 7.0.55: If Norton WiFi Privacy Service is installed
if [ -e "/Library/LaunchDaemons/com.symantec.NWPService.plist" ] ; then
# Unload it
launchctl unload /Library/LaunchDaemons/com.symantec.NWPService.plist
# Kill Symantec processes before attempting to remove visible files (Etrack 3442959)
$DoKillProcesses && KillSymantecProcesses
# If not an OS X volume, return 1
[ ! -d "$1/Library/Application Support" ] && return 1
$DoShowOnlyFilesThatShouldHaveBeenUninstalled || echo "Finding visible Symantec files on: $1" >&2
elif $ShowFilesAsRemoved ; then
echo "Locating visible Symantec files in: $1"
echo "Removing visible Symantec files from: $1"
cd "$1"
if [ "pwd
" = "/" ] ; then
VolumePrefix=""
VolumePrefix="pwd
KillNortonZone
RemoveItem "/.com_symantec_symfs_private"
RemoveItem "/.symSchedScanLockxz"
RemoveItem "/Applications/ApplicationNorton.app"
RemoveItem "/Applications/Firefox.app/Contents/MacOS/extensions/{0e10f3d7-07f6-4f12-97b9-9b27e07139a5}" -u
RemoveItem "/Applications/Firefox.app/Contents/MacOS/extensions/{29dd9c80-9ea1-4aaf-9305-a0314aba24e3}" -u
RemoveItem "/Applications/Firefox.app/Contents/MacOS/extensions/nortonsafetyminder@symantec.com" -u
RemoveItem "/Applications/GatherSymantecInfo"
RemoveItem "/Applications/Late Breaking News"
RemoveItem "/Applications/LiveUpdate"
RemoveItem "/Applications/LiveUpdate Folder"
RemoveItem "/Applications/LiveUpdate Folder (OS X)"
RemoveItem "/Applications/navx"
# 7.0.55: Exclude NWP so that it doesn't show up when -u script option is used
RemoveItem "/Applications/Norton " "*" -x "Norton WiFi Privacy.app"
# 7.0.55: Remove NWP app
RemoveItem "/Applications/Norton WiFi Privacy.app" -u
RemoveItem "/Applications/Symantec AntiVirus"
RemoveItem "/Applications/Symantec Cloud Security.app"
RemoveItem "/Applications/Symantec Endpoint Protection.app"
RemoveItem "/Applications/Symantec Endpoint Protection Cloud.app"
RemoveItem "/Applications/Symantec Solutions"
RemoveItem "/Applications/Symantec Unified Endpoint Protection.app"
RemoveItem "/Applications/Symantec/LiveUpdate.app"
RemoveItem "/Applications/Symantec/Read Me Files"
RemoveItem "/Applications/Symantec" -e
RemoveItem "/Applications/Trash Running Daemons"
RemoveItem "/Applications/uDelete Preferences"
RemoveItem "/Applications/Register Your Software"
RemoveItem "/etc/liveupdate.conf"
RemoveItem "/etc/mach_init.d/SymSharedSettings.plist"
RemoveItem "/etc/Symantec.conf"
RemoveItem "/Firewall" -e -u
RemoveItem "/Library/Application Support/com.symantec.NWPService" -u
RemoveItem "/Library/Application Support/NAVDiagnostic.log"
RemoveItem "/Library/Application Support/NAV.history"
RemoveItem "/Library/Application Support/nat_" "" -u
RemoveItem "/Library/Application Support/nat" "" -u
RemoveItem "/Library/Application Support/nav" "" -u
RemoveItem "/Library/Application Support/nis" "" -u
RemoveItem "/Library/Application Support/nsm" "" -u
RemoveItem "/Library/Application Support/Norton Application Aliases"
RemoveItem "/Library/Application Support/Norton Solutions Support"
RemoveItem "/Library/Application Support/norton" "" -u
RemoveItem "/Library/Application Support/o2spy.log"
RemoveItem "/Library/Application Support/regid.1992-12.com.symantec" ""
RemoveItem "/Library/Application Support/Symantec"
$DoRemoveIPUA && RemoveItem "/Library/Application Support/Symantec_IPUA"
RemoveItem "/Library/Application Support/symantec_uninstalldashboard" ""
RemoveItem "/Library/Application Support/SymRun"
RemoveItem "/Library/Authenticators/SymAuthenticator.bundle"
RemoveItem "/Library/CFMSupport/Norton Shared Lib"
RemoveItem "/Library/CFMSupport/Norton Shared Lib Carbon"
RemoveItem "/Library/Contextual Menu Items/NAVCMPlugIn.plugin"
RemoveItem "/Library/Contextual Menu Items/SAVCMPlugIn.plugin"
RemoveItem "/Library/Contextual Menu Items/SymFileSecurityCM.plugin"
RemoveItem "/Library/Documentation/Help/LiveUpdate Help"
RemoveItem "/Library/Documentation/Help/LiveUpdate-Hilfe"
RemoveItem "/Library/Documentation/Help/Norton AntiVirus Help"
RemoveItem "/Library/Documentation/Help/Norton AntiVirus-Hilfe"
RemoveItem "/Library/Documentation/Help/Norton Help"
RemoveItem "/Library/Documentation/Help/Norton Help Scripts"
RemoveItem "/Library/Documentation/Help/Norton Help Scripts Folder"
RemoveItem "/Library/Documentation/Help/Norton Utilities Help"
RemoveItem "/Library/Extensions/FileSecurity.kext"
RemoveItem "/Library/Extensions/ndcengine.kext"
RemoveItem "/Library/Extensions/NortonForMac.kext"
RemoveItem "/Library/Extensions/SymAPComm.kext"
RemoveItem "/Library/Extensions/SymFirewall.kext"
RemoveItem "/Library/Extensions/SymInternetSecurity.kext"
RemoveItem "/Library/Extensions/SymIPS.kext"
RemoveItem "/Library/Extensions/SymPersonalFirewall.kext"
RemoveItem "/Library/Extensions/SymXIPS.kext"
RemoveItem "/Library/Frameworks/mach_inject_bundle.framework"
RemoveItem "/Library/InputManagers/Norton Confidential for Safari"
RemoveItem "/Library/InputManagers/Norton Safety Minder"
RemoveItem "/Library/InputManagers/SymWebKitUtils"
RemoveItem "/Library/Internet Plug-Ins/Norton Confidential for Safari.plugin"
RemoveItem "/Library/Internet Plug-Ins/Norton Family Safety.plugin"
RemoveItem "/Library/Internet Plug-Ins/Norton Safety Minder.plugin"
RemoveItem "/Library/Internet Plug-Ins/NortonFamilyBF.plugin"
RemoveItem "/Library/Internet Plug-Ins/NortonInternetSecurityBF.plugin"
RemoveItem "/Library/Internet Plug-Ins/NortonSafetyMinderBF.plugin"
RemoveItem "/Library/LaunchDaemons/com.norton" ""
RemoveItem "/Library/LaunchDaemons/com.symantec" "" -x 'com.symantec.saturn.plist'
RemoveCrashReporterLogs
RemoveItem "/Library/Plug-ins/DiskImages/NUMPlugin.bundle"
RemoveItem "/Library/Plug-ins/DiskImages/VRPlugin.bundle"
RemoveItem "/Library/Plug-ins/DiskImages" -e -u
RemoveItem "/Library/Plug-ins" -e -u
RemoveItem "/Library/PreferencePanes/APPrefPane.prefPane"
RemoveItem "/Library/PreferencePanes/FileSaver.prefPane"
RemoveItem "/Library/PreferencePanes/Norton Family Safety.prefPane"
RemoveItem "/Library/PreferencePanes/Norton Safety Minder.prefPane"
RemoveItem "/Library/PreferencePanes/Ribbon.Norton.prefPane"
RemoveItem "/Library/PreferencePanes/SymantecQuickMenu.prefPane"
RemoveItem "/Library/PreferencePanes/SymAutoProtect.prefPane"
RemoveItem "/Library/PrivateFrameworks/NPF.framework"
RemoveItem "/Library/PrivateFrameworks/NPFCoreServices.framework"
RemoveItem "/Library/PrivateFrameworks/NPFDataSource.framework"
RemoveItem "/Library/PrivateFrameworks/PlausibleDatabase.framework"
RemoveItem "/Library/PrivateFrameworks/SymAppKitAdditions.framework"
RemoveItem "/Library/PrivateFrameworks/SymAVScan.framework"
RemoveItem "/Library/PrivateFrameworks/SymBase.framework"
RemoveItem "/Library/PrivateFrameworks/SymConfidential.framework"
RemoveItem "/Library/PrivateFrameworks/SymDaemon.framework"
RemoveItem "/Library/PrivateFrameworks/SymFirewall.framework"
RemoveItem "/Library/PrivateFrameworks/SymInternetSecurity.framework"
RemoveItem "/Library/PrivateFrameworks/SymIPS.framework"
RemoveItem "/Library/PrivateFrameworks/SymIR.framework"
RemoveItem "/Library/PrivateFrameworks/SymLicensing.framework"
RemoveItem "/Library/PrivateFrameworks/SymNetworking.framework"
RemoveItem "/Library/PrivateFrameworks/SymOxygen.framework"
RemoveItem "/Library/PrivateFrameworks/SymPersonalFirewall.framework"
RemoveItem "/Library/PrivateFrameworks/SymScheduler.framework"
RemoveItem "/Library/PrivateFrameworks/SymSEP.framework"
RemoveItem "/Library/PrivateFrameworks/SymSharedSettings.framework"
RemoveItem "/Library/PrivateFrameworks/SymSubmission.framework"
RemoveItem "/Library/PrivateFrameworks/SymSystem.framework"
RemoveItem "/Library/PrivateFrameworks/SymUIAgent.framework"
RemoveItem "/Library/PrivateFrameworks/SymUIAgentUI.framework"
if [ ! -e "$VolumePrefix/Library/PrivateFrameworks/SymWebKitUtils.framework/Versions/A/Resources/SymWKULoader.dylib"
-o ( $CreateFilesRemovedListOnly = true -a $ListOnlyFilesThatExist = false ) ] ; then
RemoveItem "/Library/PrivateFrameworks/SymWebKitUtils.framework"
RemoveItem "/Library/PrivilegedHelperTools/com.symantec" "" -x "com.symantec.NWPService"
RemoveItem "/Library/PrivilegedHelperTools/com.symantec.NWPService" -u
RemoveItem "/Library/PrivilegedHelperTools/NATRemoteLock.app"
IFS='
for EachReceiptLine in echo "$ReceiptsTable" | grep . | grep -v '^#'
; do
ReceiptName=echo "$EachReceiptLine" | awk -F " " '{print $1}'
ReceiptArg=echo "$EachReceiptLine" | awk -F " " '{print $2}'
if [ "z$ReceiptArg" = z-a ] ; then
RemoveItem "/Library/Receipts/$ReceiptName" ""
RemoveItem "/Library/Receipts/$ReceiptName"Dev ""
if [ "z$ReceiptName" = zSymWebKitUtils.pkg -o "z$ReceiptName" = zSymWebKitUtilsDev.pkg ] ; then
# If SymWKULoader exists and CleanUpSymWebKitUtils does not, skip deletion of SymWebKitUtils receipt
[ -e "$VolumePrefix/Library/PrivateFrameworks/SymWebKitUtils.framework/Versions/A/Resources/SymWKULoader.dylib" -a ! -e /Library/StartupItems/CleanUpSymWebKitUtils ] && continue
if [ "echo "$ReceiptName" | grep '.pkg$'
" ] ; then
ReceiptName="basename "$ReceiptName" .pkg
Dev.pkg"
done
RemoveItem "/Library/ScriptingAdditions/SymWebKitUtils.osax"
RemoveItem "/Library/ScriptingAdditions/SymWebKitUtilsSL.osax"
RemoveItem "/Library/Services/Norton for Mac.service"
RemoveItem "/Library/Services/NortonDocktile.bundle"
RemoveItem "/Library/Services/ScanService.service"
RemoveItem "/Library/Services/Symantec" "*"
RemoveItem "/Library/Services/SymSafeWeb.service"
RemoveItem "/Library/Services" -e -u
RemoveItem "/Library/StartupItems/NortonAutoProtect"
RemoveItem "/Library/StartupItems/NortonAutoProtect.kextcache"
RemoveItem "/Library/StartupItems/NortonLastStart"
RemoveItem "/Library/StartupItems/NortonMissedTasks"
RemoveItem "/Library/StartupItems/NortonPersonalFirewall"
RemoveItem "/Library/StartupItems/NortonPrivacyControl"
RemoveItem "/Library/StartupItems/NUMCompatibilityCheck"
RemoveItem "/Library/StartupItems/SMC"
RemoveItem "/Library/StartupItems/SymAutoProtect"
RemoveItem "/Library/StartupItems/SymAutoProtect.kextcache"
RemoveItem "/Library/StartupItems/SymDCInit"
RemoveItem "/Library/StartupItems/SymMissedTasks"
RemoveItem "/Library/StartupItems/SymProtector"
RemoveItem "/Library/StartupItems/SymQuickMenuOSFix"
RemoveItem "/Library/StartupItems/SymWebKitUtilsOSFix"
RemoveItem "/Library/StartupItems/TrackDelete"
RemoveItem "/Library/StartupItems/VolumeAssist"
RemoveItem "/Library/Symantec/tmp"
RemoveItem "/Library/Symantec" -E -u
RemoveItem "/Library/Widgets/NAV.wdgt"
RemoveItem "/Library/Widgets/Symantec Alerts.wdgt"
RemoveItem "/Library/Widgets" -E -u
RemoveItem "/Norton AntiVirus Installer Log"
RemoveItem "/opt/Symantec"
RemoveItem "/opt" -E -u
RemoveItem "/Personal" -e -u
RemoveItem "/Solutions" -e -u
RemoveItem "/Support/Norton" -e -u
RemoveItem "/Support" -e -u
RemoveItem "/symaperr.log"
RemoveItem "/symapout.log"
RemoveItem "/SymAppKitAdditions.framework"
RemoveItem "/SymBase.framework"
RemoveItem "/SymNetworking.framework"
RemoveItem "/SymSystem.framework"
RemoveItem "/System/Library/Authenticators/SymAuthenticator.bundle"
RemoveItem "/System/Library/CFMSupport/Norton Shared Lib Carbon"
RemoveItem "/System/Library/CoreServices/NSWemergency"
RemoveItem "/System/Library/CoreServices/NUMemergency"
RemoveItem "/System/Library/Extensions/DeleteTrap.kext"
RemoveItem "/System/Library/Extensions/KTUM.kext"
RemoveItem "/System/Library/Extensions/ndcengine.kext"
RemoveItem "/System/Library/Extensions/NortonForMac.kext"
RemoveItem "/System/Library/Extensions/NPFKPI.kext"
RemoveItem "/System/Library/Extensions/SymDC.kext"
RemoveItem "/System/Library/Extensions/SymEvent.kext"
RemoveItem "/System/Library/Extensions/symfs.kext"
RemoveItem "/System/Library/Extensions/SymInternetSecurity.kext"
RemoveItem "/System/Library/Extensions/SymIPS.kext"
RemoveItem "/System/Library/Extensions/SymOSXKernelUtilities.kext"
RemoveItem "/System/Library/Extensions/SymPersonalFirewall.kext"
RemoveItem "/System/Library/Extensions/SymXIPS.kext"
RemoveItem "/System/Library/StartupItems/NortonAutoProtect"
RemoveItem "/System/Library/StartupItems/SymMissedTasks"
RemoveItem "/System/Library/Symantec"
RemoveItem "/System/Library/SymInternetSecurity.kext"
RemoveItem "/SystemWorks Installer Log"
RemoveItem "/tmp/com.symantec.liveupdate.reboot"
RemoveItem "/tmp/com.symantec.liveupdate.restart"
RemoveItem "/tmp/com.symantec.MES.liveupdate.reboot"
RemoveItem "/tmp/com.symantec.NFM.liveupdate.reboot"
RemoveItem "/tmp/jlulogtemp"
RemoveItem "/tmp/LiveUpdate." ""
RemoveItem "/tmp/liveupdate"
RemoveItem "/tmp/lulogtemp"
RemoveItem "/tmp/O2Spy.log"
RemoveItem "/tmp/SymSharedFrameworks" ""
RemoveItem "/tmp/symask"
RemoveItem "/Users/dev/bin/smellydecode"
RemoveItem "/Users/dev/bin" -E -u
RemoveItem "/Users/dev" -E -u
RemoveItem "/Users/Shared/NAV Corporate"
RemoveItem "/Users/Shared/NIS Corporate"
RemoveItem "/Users/Shared/RemoveSymantecMacFilesRemovesThese.txt"
RemoveItem "/Users/Shared/RemoveSymantecMacFilesLog.txt"
RemoveItem "/Users/Shared/SymantecRemovalToolRemovesThese.txt"
RemoveItem "/Users/Shared/SymantecRemovalToolLog.txt"
RemoveItem "/usr/bin/nortonscanner"
RemoveItem "/usr/bin/nortonsettings"
RemoveItem "/usr/bin/MigrateQTF"
RemoveItem "/usr/bin/navx"
RemoveItem "/usr/bin/npfx"
RemoveItem "/usr/bin/savx"
RemoveItem "/usr/bin/scfx"
RemoveItem "/usr/bin/symsched"
RemoveItem "/usr/lib/libsymsea." "dylib"
RemoveItem "/usr/lib/libwpsapi.dylib"
RemoveItem "/usr/local/bin/CoreLocationProviderTest"
RemoveItem "/usr/local/bin/KeyGenerator"
RemoveItem "/usr/local/bin/LocationProviderInterfaceTest"
RemoveItem "/usr/local/bin/LocationProviderTest"
RemoveItem "/usr/local/bin/MigrateQTF"
RemoveItem "/usr/local/bin/navx"
RemoveItem "/usr/local/bin/nortonscanner"
RemoveItem "/usr/local/bin/nortonsettings"
RemoveItem "/usr/local/bin/npfx"
RemoveItem "/usr/local/bin/SkyhookProviderTest"
RemoveItem "/usr/local/bin" -E -u
RemoveItem "/usr/local/lib/libAPFeature.a"
RemoveItem "/usr/local/lib/libcx_lib.so"
RemoveItem "/usr/local/lib/libecomlodr.dylib"
RemoveItem "/usr/local/lib/libgecko3parsers.dylib"
RemoveItem "/usr/local/lib/liblux.so." ""
RemoveItem "/usr/local/lib/libnlucallback.dylib"
RemoveItem "/usr/local/lib/libNUCoverFlow" ""
RemoveItem "/usr/local/lib/libsymsea." "dylib"
RemoveItem "/usr/local/lib" -E -u
RemoveItem "/usr/share/man/man1/NAVScanIDs.h"
RemoveItem "/var/db/NATSqlDatabase.db"
RemoveItem '/var/db/receipts/$(SYM_SKU_REVDOMAIN).install.bom'
RemoveItem '/var/db/receipts/$(SYM_SKU_REVDOMAIN).install.plist'
RemoveItem "/var/db/receipts/com.symantec" "" -x "com.symantec-it.."
RemoveItem "/var/db/receipts/com.Symantec" "" -x "com.Symantec-it.."
RemoveItem "/var/log/du.log" ""
RemoveItem "/var/log/dulux.log" ""
RemoveItem "/var/log/lut.log" ""
RemoveItem "/var/log/lux.log" ""
RemoveItem "/var/log/luxtool.log" ""
RemoveItem "/var/log/mexd.log" ""
RemoveItem "/var/log/microdef.log" ""
RemoveItem "/var/log/nortondns.log"
RemoveItem "/var/log/Npfkernel.log.fifo"
RemoveItem "/var/root/Applications/Norton Internet Security.app"
RemoveItem "/var/root/Applications" -E
RemoveItem "/var/root/Library/Bundles/NAVIR.bundle"
RemoveItem "/var/root/Library/Bundles" -E -u
RemoveItem "/var/root/Library/Contextual Menu Items/NAVCMPlugIn.plugin"
RemoveItem "/var/root/Library/Contextual Menu Items" -E -u
RemoveItem "/var/tmp/com.symantec" ""
RemoveItem "/var/tmp/com.Symantec" ""
$DoRemoveMigrationFiles && RemoveItem "/var/tmp/NFM"
RemoveItem "/var/tmp/Data2.chk" -u
RemoveItem "/var/tmp/nis" "Data2.chk" -u
RemoveItem "/var/tmp/symantec_error_report" ""
# Delete logs listed in logging conf files within /etc/symantec
IFS='
for LUXLogFile in cat "/Library/Application Support/Symantec/Silo/""/LiveUpdate/Conf/lux.logging.conf" /etc/symantec/dulux.logging.conf /etc/symantec/lux.logging.conf /etc/symantec/microdef.logging.conf 2>/dev/null | tr '15' '12' | grep logger.sink.file.filePath= | awk -F = '{print $2}' | sort -f | uniq
; do
RemoveItem "$LUXLogFile" ""
done
if [ -f /etc/symantec/defutils.conf ] ; then
DefUtilsLogContents=cat /etc/symantec/defutils.conf 2>/dev/null | tr '15' '12'
DefUtilsLogDir=printf "%s" "$DefUtilsLogContents" | grep defutillog_dir= | awk -F = '{print $2}'
if [ "$DefUtilsLogDir" ] ; then
DefUtilsLogBaseName=printf "%s" "$DefUtilsLogContents" | grep defutillog_name= | awk -F = '{print $2}'
[ "$DefUtilsLogBaseName" ] && RemoveItem "$DefUtilsLogDir/$DefUtilsLogBaseName".log "*"
if $DoRemoveMidDat ; then
RemoveItem "/etc/symantec/mid.dat" -u
RemoveItem "/etc/symantec" -d -x "saturn|mid.dat"
RemoveItem "/etc/symantec" -E -u
if [ -f "$VolumePrefix/etc/syslog.conf" -a $CreateFilesRemovedListOnly = false ] ; then
# Remove Norton Personal Firewall entries from /etc/syslog.conf
sed -e "/Norton Personal Firewall/d" -e "/Npfkernel.log.fifo/d" "$VolumePrefix/etc/syslog.conf" > /tmp/NPF.syslog.conf
if [ -s /tmp/NPF.syslog.conf ] ; then
/bin/cp -f /tmp/NPF.syslog.conf "$VolumePrefix/etc/syslog.conf"
/bin/rm -f /tmp/NPF.syslog.conf
RemoveFilesFromLibraryAndUserDirectories "$1"
RemoveItem /Library/Preferences/Network -E -u
if [ -s "$FilesRemovedFilesOnlyList" ] ; then
sort -f "$FilesRemovedFilesOnlyList" | uniq | grep . >> "$FilesRemovedList"
RemoveLoginKeychainPasswords "$CurrentVolumeBeingUsed"
if [ $CreateFilesRemovedListOnly = false -a "z$CurrentVolumeBeingUsed" = z/ ] ; then
# Kill Symantec processes and attempt to remove Symantec folder again in case Symantec
# folder was re-created with incorrect permissions (Etrack 3442959) while other files
# were removed
$DoKillProcesses && KillSymantecProcesses &>/dev/null
RemoveCrashReporterLogs()
# Usage: RemoveCrashReporterLogs
# Summary: Removes CrashReporter logs. GetComputerUsers function must be run
# and VolumePrefix must be defined before running this function.
# CrashLogGrepPattern will match visible or invisible (name begins with a period) Symantec files
local CrashLogGrepPattern='/.?com.norton|/.?com.symantec|/.?LiveUpdate|.?/LUTool|/.?NFM|/.?Norton|/.?Sym'
local LogsToDelete=""
local LogToDelete
local UserDir
IFS='
for UserDir in $ComputerUsersHomeDirsAndRootDir ; do
[ "$UserDir" = / ] && UserDir=""
LogsToDelete="$LogsToDeletefind "$VolumePrefix$UserDir/Library/Application Support/CrashReporter" "$VolumePrefix$UserDir/Library/Application Support/DiagnosticReports" "$VolumePrefix$UserDir/Library/Logs/CrashReporter" "$VolumePrefix$UserDir/Library/Logs/DiagnosticReports" "$VolumePrefix$UserDir/Library/Logs/Crashes" -type f 2>/dev/null | egrep -i "$CrashLogGrepPattern"
done
LogsToDelete=echo "$LogsToDelete" | grep / | sort -f
if [ "$VolumePrefix" ] ; then
# Remove VolumePrefix from beginning of paths
LogsToDelete=echo "$LogsToDelete" | awk -v VOLUME="$VolumePrefix" '{print substr($0,length(VOLUME)+1)}'
if [ "$LogsToDelete" ] ; then
for LogToDelete in $LogsToDelete ; do
RemoveItem "$LogToDelete" -u
done
RemoveEmptyDirectory()
# Usage: RemoveEmptyDirectory $1
# Argument: $1 = Full path name of directory
# Summary: Removes directory $1 if it is empty or if it contains
# only .DS_Store and/or .localized (the next best thing
# to being empty).
# If $1 is a directory and not a link
if [ -d "$1" -a ! -L "$1" ] ; then
# If folder contains only .DS_Store and/or .localized, or is empty
if [ -z "ls "$1" 2>/dev/null | grep -v "^.DS_Store|^.localized"
" ] ; then
$ShowFilesAsRemoved && echo " Removing: "$1""
# Clear immutable bit to remove any Finder lock
chflags -R nouchg "$1" 2>/dev/null 1>&2
/bin/rm -rf "$1" 2>/dev/null 1>&2 # Remove folder
RemoveFilesFromLibraryAndUserDirectories()
# Usage: RemoveFilesFromLibraryAndUserDirectories $1
# Argument: $1 = Name of volume from which to remove preferences.
# The name must begin with "/Volumes/"
# unless it is "/" (boot volume).
# Summary: Removes all Symantec files & folders from each user's
# preferences, /Library/Caches, and /Library/Preferences.
# Removes help files from /Library/Documentation. Removes
# folders incorrectly created by NAV 7.0.2 from each
# user's home directory.
local FSDDir
local FSDDirs
local InstallerAppsToRemove
local InstallerAppToRemove
local UserDownloadsDir
local UserHomeDir
local UserLibraryDir
if [ "$1" = "/" ] ; then
VolumeToCheck=""
VolumeToCheck="$1"
# set IFS to only newline to get all user names
IFS='
for UserHomeDir in $ComputerUsersHomeDirsAndRootDir ; do
if [ "$UserHomeDir" = "/" ] ; then
UserHomeDir=""
UserLibraryDir="$UserHomeDir/Library"
# If UserLibraryDir is not a directory, skip to the next name
[ ! -d "$VolumeToCheck$UserLibraryDir" ] && continue
cd "$VolumeToCheck/"
# If a user's home directory, delete folders from user's home directory
# that were incorrectly created by NAV 7.0.2
if [ "$UserHomeDir" ] ; then
RemoveItem "$UserHomeDir/Applications/LiveUpdate Folder (OS X)"
RemoveItem "$UserHomeDir/Applications/Norton AntiVirus (OS X)"
RemoveItem "$UserHomeDir/Applications" -e -u
FirefoxExtensions=find "$UserLibraryDir/Application Support/Firefox/Profiles/"/extensions/"@symantec.com.xpi" 2>/dev/null
for FirefoxExtension in $FirefoxExtensions ; do
RemoveItem "$FirefoxExtension" -u # no longer removed via product uninstaller
done
RemoveItem "$UserLibraryDir/Application Support/Norton" ""
# If a user directory
RemoveItem "$UserLibraryDir/Application Support/Symantec"
RemoveItem "$UserHomeDir/Application Support/Symantec"
RemoveItem "$UserHomeDir/Application Support" -E -u
# If .fsd folders should be removed
if $DoRemoveFSDFolders ; then
UserDownloadsDir="$UserHomeDir/Downloads"
# Remove Symantec/Norton installer/package tool apps found within
# user's Downloads folder
InstallerAppsToRemove="find "$UserDownloadsDir" -type d -name "Install Norton
" 2>/dev/null
find "$UserDownloadsDir" -type d -name "Install Symantec" 2>/dev/null
find "$UserDownloadsDir" -type d -name "SEP
RedistributableInstallerPackageTool" 2>/dev/null
for InstallerAppToRemove in $InstallerAppsToRemove ; do
RemoveItem "$InstallerAppToRemove" -u
done
# Remove any remaining .fsd folders in user's Downloads folder
FSDDirs=find "$UserDownloadsDir" -type d -name ".fsd" 2>/dev/null
for FSDDir in $FSDDirs ; do
RemoveItem "$FSDDir" -u
FolderContainingFSDDir=dirname "$FSDDir"
# If folder that contained .fsd folder is not the user's Downloads folder
if [ ! "$FolderContainingFSDDir" -ef "$UserDownloadsDir" ] ; then
# Remove the containing folder if it's empty
RemoveItem "$FolderContainingFSDDir" -e -u
done
elif ! $CreateFilesRemovedListOnly ; then
# Make second attempt to remove "/Application Support/Symantec/ErrorReporting"
RemoveItem "$UserLibraryDir/Application Support/Symantec/ErrorReporting"
RemoveItem "$UserLibraryDir/Documentation/Help/Norton Privacy Control Help"
RemoveItem "$UserLibraryDir/Documentation/Help/Norton Personal Firewall Help"
RemoveItem "$UserLibraryDir/Caches/com.apple.Safari/Extensions/Norton" "" -u
RemoveItem "$UserLibraryDir/Caches/com.apple.Safari/Extensions/Symantec" "" -u
RemoveItem "$UserLibraryDir/Caches/com.norton" "" -u
RemoveItem "$UserLibraryDir/Caches/com.symantec" "" -u
RemoveItem "$UserLibraryDir/Caches/Norton" "" -u
RemoveItem "$UserLibraryDir/Caches/Symantec" "" -u
if $DoRemoveIPUA ; then
# If not a user directory
if [ -z "$UserHomeDir" ] ; then
RemoveItem "$UserLibraryDir/LaunchAgents/com.symantec" ""
elif $DoRemoveInstallerLaunchAgents ; then
RemoveItem "$UserLibraryDir/LaunchAgents/com.symantec" "" -x 'com.symantec..Installer.plist'
RemoveItem "$UserLibraryDir/LaunchAgents/com.symantec" "" -x 'com.symantec.ipua.plist'
RemoveItem "$UserLibraryDir/LaunchAgents/com.symantec" "" -x 'com.symantec..Installer.plist' -x 'com.symantec.ipua.plist'
RemoveItem "$UserLibraryDir/Logs/.ipuaint"
RemoveItem "$UserLibraryDir/Logs/.ipualog"
RemoveItem "$UserLibraryDir/Logs/EPMPTestLogs.log" -u
RemoveItem "$UserLibraryDir/Logs/LUTool.txt"
RemoveItem "$UserLibraryDir/Logs/Norton" ""
RemoveItem "$UserLibraryDir/Logs/o2spy.log"
RemoveItem "$UserLibraryDir/Logs/Symantec" ""
RemoveItem "$UserLibraryDir/Logs/SymaIpua" ""
RemoveItem "$UserLibraryDir/Logs/SymAPErr.log"
RemoveItem "$UserLibraryDir/Logs/SymAPOut.log"
RemoveItem "$UserLibraryDir/Logs/SymBfw_NFM.log"
RemoveItem "$UserLibraryDir/Logs/SymCommP" ""
RemoveItem "$UserLibraryDir/Logs/SymDebugLeaks.log"
RemoveItem "$UserLibraryDir/Logs/SymDeepsight" ""
RemoveItem "$UserLibraryDir/Logs/SymFWDeepSightTrie.txt"
RemoveItem "$UserLibraryDir/Logs/SymFWLog.log"
RemoveItem "$UserLibraryDir/Logs/SymFWRules.log" ""
RemoveItem "$UserLibraryDir/Logs/SymHTTPSubmissions.txt"
RemoveItem "$UserLibraryDir/Logs/SymInstall" ""
RemoveItem "$UserLibraryDir/Logs/SymIpua" ""
RemoveItem "$UserLibraryDir/Logs/SymMigration.log"
RemoveItem "$UserLibraryDir/Logs/SymOxygen" ""
RemoveItem "$UserLibraryDir/Logs/SymQual" ""
RemoveItem "$UserLibraryDir/Logs/SymScanServerDaemon.log"
RemoveItem "$UserLibraryDir/Logs/SymSharedSettingsd.log"
RemoveItem "$UserLibraryDir/Logs/SymUninstall" ""
RemoveItem "$UserLibraryDir/Logs/UIAgent" ""
RemoveItem "$UserLibraryDir/Preferences/ByHost/com.symantec" ""
RemoveItem "$UserLibraryDir/Preferences/com.norton" ""
RemoveItem "$UserLibraryDir/Preferences/com.symantec" "" -x 'com.symantec.sacm.' -x 'com.symantec.smac.'
RemoveItem "$UserLibraryDir/Preferences/com.symantec" "" -x 'com.symantec.sacm.' -x 'com.symantec.smac.' -x 'com.symantec.ipua.plist'
RemoveItem "$UserLibraryDir/Preferences/group.com.symantec" "" -u
RemoveItem "$UserLibraryDir/Preferences/group.symantec" "" -u
RemoveItem "$UserLibraryDir/Preferences/LiveUpdate Preferences"
RemoveItem "$UserLibraryDir/Preferences/LU Admin Preferences"
RemoveItem "$UserLibraryDir/Preferences/LU Host Admin.plist"
RemoveItem "$UserLibraryDir/Preferences/NAV8.0.003.plist"
RemoveItem "$UserLibraryDir/Preferences/Network/com.symantec" ""
RemoveItem "$UserLibraryDir/Preferences/Norton AntiVirus Prefs Folder"
RemoveItem "$UserLibraryDir/Preferences/Norton Application Aliases"
RemoveItem "$UserLibraryDir/Preferences/Norton Personal Firewall Log"
RemoveItem "$UserLibraryDir/Preferences/Norton Scheduler OS X.plist"
RemoveItem "$UserLibraryDir/Preferences/Norton Utilities Preferences"
RemoveItem "$UserLibraryDir/Preferences/Norton Zone"
RemoveItem "$UserLibraryDir/Preferences/wcid"
RemoveItem "$UserLibraryDir/Safari/Extensions/Norton" "" -u
RemoveItem "$UserLibraryDir/Safari/Extensions/Symantec" "" -u
RemoveItem "$UserLibraryDir/Saved Application State/com.symantec" "" -u
done
RemoveInvisibleFilesFromVolume()
# Usage: RemoveInvisibleFilesFromVolume $1
# Argument: $1 = Volume name. The name should begin with "/Volumes/"
# Summary: Removes the invisible Symantec for OS X files - Symantec FS
# and AntiVirus QuickScan files - from $1.
! $RemoveInvisibleFiles && return
cd "$1"
$DoShowOnlyFilesThatShouldHaveBeenUninstalled || echo "Finding invisible Symantec files on: $1" >&2
echo "Locating invisible Symantec files in: $1"
echo "Removing invisible Symantec files from: $1"
RemoveItem "/.SymAVQSFile"
RemoveItem "/NAVMac800QSFile"
RemoveItem "/Norton FS Data"
RemoveItem "/Norton FS Index"
RemoveItem "/Norton FS Volume"
RemoveItem "/Norton FS Volume 2"
RemoveItem()
# Usage: RemoveItem ["private_was_added"] FilePath [-d] [-e | -E] [-u] [-x <pattern>] [FileExtension]
# Summary: Deletes the file or folder passed, FilePath, from the
# current directory. FilePath should be full path beginning
# with /.
# Options:
# -d Treat FilePath as a directory in which to match FileExtension
# or when using the -x option. See FileExtension and -x option
# below. The -d must be passed prior to passing the -x option.
# FilePath itself will not be deleted, only the matching items
# within it will be deleted. If no FileExtension is passed, ""
# is assumed.
# -e Delete FilePath only if it is a directory that is empty or
# that contains only ".DS_Store" and/or ".localized" files.
# If the folder could not be deleted, error message is shown.
# -E Same as the -e option, except no error message is shown if
# the folder could not be deleted.
# -u Item is not removed by Symantec Uninstaller.app.
# -x <Pattern>
# Pattern to exclude from file list. Pattern will become
# ^FilePathPattern$ (or ^FilePath/Pattern$ if -d was passed
# before -x was passed) so add wildcards as needed. Make sure
# to prefix special characters you wish to match with
# (example: to match a period, .). You may pass several
# -x <pattern> groupings. Pattern is an extended regular
# expression. Letter case is ignored.
# <FileExtension>
# All files are deleted that match FilePath.FileExtension or
# if -d was passed that match FilePath/.FileExtension.
# To match any files that begin with FilePath, pass "" as
# FileExtension (don't pass unquoted). Only the last
# FileExtension passed will be used. Periods will be escaped
# (i.e., each . will become .).
# "private_was_added"
# This gets passed as the first argument by RemoveItem() when
# FilePath is a link in PrivateLinksPattern. This option is
# only to be passed by RemoveItem() itself.
# Note: Make sure to run the SetupCleanup function before the
# first run of this function and run the FinishCleanup
# function before exiting the script.
# Make sure to change directory to root of the volume you
# want the file or folder removed from before calling this
# function.
# FilePath must be the first argument unless "private_was_added"
# was passed as the first. The other options may appear after
# FilePath in any order.
local ExclusionPattern=""
local FilePath="$1"
shift
# If / or no file name passed
if [ "z$FilePath" = z/ -o -z "$FilePath" ] ; then
return
# Else if this is a call by RemoveItem() with /private added to original path
elif [ "z$FilePath" = zprivate_was_added ] ; then
FilePath="$1"
shift
# Else if original path begins with /private/ and is targeted by a link in /
elif [ "echo "$FilePath" | egrep -e "$PrivateDirectoriesPattern"
" ] ; then
# Remove /private from beginning of path
FilePath=echo "$FilePath" | awk '{print substr($0,9)}'
VolumeFromWhichToRemove="pwd
# If path passed begins with /etc/, /tmp/, or /var/
if [ "echo "$FilePath" | egrep -e "$PrivateLinksPattern"
" ] ; then
PrivateLinkName=echo "$FilePath" | awk -F / '{print $2}'
PrivateLinkRoot="$VolumeFromWhichToRemove/$PrivateLinkName"
PrivateDirRoot="$VolumeFromWhichToRemove/private/$PrivateLinkName"
# If path does not point to the same file as "/private/" + path
if [ ! "$PrivateLinkRoot" -ef "$PrivateDirRoot" ] ; then
FilePathOriginal="$FilePath"
# Attempt to remove path from within /private first
RemoveItem "private_was_added" "/private$FilePath" "$@"
# Then attempt to remove path itself
FilePath="$FilePathOriginal"
if [ "$VolumeFromWhichToRemove" = "/" ] ; then
FullFilePath="$FilePath"
FullFilePath="$VolumeFromWhichToRemove$FilePath"
# If logs should not be removed
if ! $DoRemoveLogs ; then
# If file path contains "/Library/Logs/", skip removal
if [ "echo "$FullFilePath" | egrep '/Library/Logs/'
" ] ; then
return
PathDir=dirname "$FullFilePath"
[ -z "$PathDir" ] && return
# Set PathBasePattern = basename of path with each . translated to .
PathBasePattern=basename "$FullFilePath" | sed s/"."/"\."/g
[ -z "$PathBasePattern" ] && return
DeleteOnlyIfEmptyDir=false
ExtensionPassed=""
PathIsDirectory=false
SkipErrorMessageIfEmptyDirNotFound=false
ShouldNotBeRemovedBySymantecUninstaller=false
while [ "$1" ] ; do
case "$1" in
-d)
PathDir="$FullFilePath"
PathBasePattern=""
PathIsDirectory=true
-e)
DeleteOnlyIfEmptyDir=true
-E)
SkipErrorMessageIfEmptyDirNotFound=true
-u)
ShouldNotBeRemovedBySymantecUninstaller=true
-x)
if [ "$2" ] ; then
shift
ExclusionPattern="$ExclusionPattern|^$PathDir/$1$"
ExclusionPattern="^$PathDir/$1$"
ExtensionPassed="$1"
esac
shift
done
if [ "z$ExtensionPassed" = "z" ] ; then
ListOfPaths=find "$PathDir" -mindepth 1 -maxdepth 1 2>/dev/null | grep -i "^$PathDir/$PathBasePattern" | sort -f
PathToShow="$FullFilePath$PathIsDirectory && echo /
elif [ "$ExtensionPassed" ] ; then
ExtensionPassedPattern=printf "%s" "$ExtensionPassed" | sed s/"."/"\."/g
ListOfPaths=find "$PathDir" -mindepth 1 -maxdepth 1 2>/dev/null | grep -i "^$PathDir/$PathBasePattern.$ExtensionPassedPattern$" | sort -f
PathToShow="$FullFilePath$ExtensionPassed"
elif $PathIsDirectory ; then
ListOfPaths=find "$FullFilePath" -mindepth 1 -maxdepth 1 2>/dev/null | sort -f
PathToShow="$FullFilePath/*"
ListOfPaths=ls -d "$FullFilePath" 2>/dev/null
PathToShow="$FullFilePath"
# If there are items to exclude from the list and there are matching items
if [ "z$ExclusionPattern" != z -a -n "$ListOfPaths" ] ; then
ListOfPaths=printf "%s" "$ListOfPaths" | egrep -i -v -e "$ExclusionPattern"
if $CreateFilesRemovedListOnly ; then
# If -E passed, then don't list the item
$SkipErrorMessageIfEmptyDirNotFound && return
if ! $ListOnlyFilesThatExist ; then
echo "$PathToShow$DeleteOnlyIfEmptyDir && echo " [folder deleted only if empty]"
# Else if file exists
elif [ "$ListOfPaths" ] ; then
ItemsToAddToList=""
IFS='
if $DeleteOnlyIfEmptyDir ; then
$ShowOnlyRegularFiles || ItemsToAddToList="$ListOfPaths"
for EachItemListed in $ListOfPaths ; do
if [ -f "$EachItemListed" ] ; then
ItemsToAddToList="$ItemsToAddToList
$EachItemListed"
elif [ -L "$EachItemListed" -a $ShowOnlyRegularFiles = false ] ; then
$EachItemListed"
ItemsToAddToList="$ItemsToAddToListfind "$EachItemListed" $FindOption1 $FindOption2 2>/dev/null
done
for EachItemFound in $ItemsToAddToList ; do
if $ShouldNotBeRemovedBySymantecUninstaller ; then
AddedText="$NotRemovedBySymantecUninstallerText"
elif [ "echo "$EachItemFound" | grep -F "$NotRemovedByNIS6Uninstaller"
" ] ; then
AddedText="$NotRemovedByNIS6UninstallerText"
elif [ "echo "$EachItemFound" | grep -F "$NotRemovedBySymantecUninstallerPattern"
" ] ; then
AddedText=""
if $ShowOnlyRegularFiles ; then
# If would be an empty folder or would not be removed by Symantec Uninstaller, don't add item to the list
[ $DeleteOnlyIfEmptyDir = true -o -n "$AddedText" ] && continue
echo "$EachItemFound$DeleteOnlyIfEmptyDir && echo " [folder deleted only if empty]"
$AddedText" >> "$FilesRemovedFilesOnlyList"
done
NoFilesToRemove=false
FilesFoundOnThisVolume=true
return
IFS='
for EachFullPath in $ListOfPaths ; do
# If -e or -E was passed
# remove directory only if empty
RemoveEmptyDirectory "$EachFullPath"
# If -E passed, then skip error reporting
$SkipErrorMessageIfEmptyDirNotFound && continue
$ShowFilesAsRemoved && echo " Removing: "$EachFullPath""
chflags -R nouchg "$EachFullPath" 2>/dev/null 1>&2
BackupLog "$EachFullPath"
/bin/rm -rf "$EachFullPath" 2>/dev/null 1>&2 # Remove file/folder
# If file still exists
if [ "ls -d "$EachFullPath" 2>/dev/null
" ] ; then
TheFileWasRemoved=false
TheFileWasRemoved=true
SomeFileWasRemoved=true
# If the file/folder was not removed
if ! $TheFileWasRemoved ; then
if ! $ErrorOccurred ; then
# Create LogFile
echo "Symantec files/folders not removed:" >"$LogFile"
chmod a=rw "$LogFile"
ErrorOccurred=true
echo " $EachFullPath" >>"$LogFile"
# Else if boot volume
elif [ "$CurrentVolumeBeingUsed" = "/" ] ; then
RestartMayBeNeeded=true
# If it's not a file that does not require a restart (Etrack 3925328)
if [ -z "printf "%s" "$EachFullPath" | egrep -ie "$FilesThatDoNotRequireRebootPattern"
" ] ; then
touch "$SymantecCleanupRestartFile"
SomeFileWasRemovedFromBootVolume=true
SomeFileWasRemovedFromNonBootVolume=true
done
RemoveLoginKeychainPasswords()
# Usage: RemoveLoginKeychainPasswords volume
# Summary: Removes items from login keychains.
# If volume is not / (current boot volume), removal is skipped.
# If volume is not specified, / is assumed.
local VolumeBeingPurged="$1"
local ComputerUserEntry
local EachLoginKeychain
local HelpTextToShow
local LoginKeychainPasswordToDelete
local LoginKeychainPasswordToDeleteLine
local UserDir
local UserOfKeychain
# If volume not specified, assume it is boot volume
[ -z "$VolumeBeingPurged" ] && VolumeBeingPurged=/
# If volume being cleaned up is not the boot volume, skip purge
[ "z$VolumeBeingPurged" != z/ ] && return
$DoShowOnlyFilesThatShouldHaveBeenUninstalled || echo "Looking for Symantec login keychain items" 2>/dev/null
IFS='
for ComputerUserEntry in $ComputerUsersTable ; do
UserOfKeychain=echo "$ComputerUserEntry" | awk -F ' ' '{print $1}'
UserDir=echo "$ComputerUserEntry" | awk -F ' ' '{print $2}'
EachLoginKeychain="$UserDir/Library/Keychains/login.keychain"
[ ! -f "$EachLoginKeychain" ] && continue
for LoginKeychainPasswordToDeleteLine in $LoginKeychainPasswordsToDelete ; do
LoginKeychainPasswordToDelete=echo "$LoginKeychainPasswordToDeleteLine" | awk -F ' ' '{print $1}'
HelpTextToShow=echo "$LoginKeychainPasswordToDeleteLine" | awk -F ' ' '{print $2}'
/usr/bin/security find-generic-password -s "$LoginKeychainPasswordToDelete" "$EachLoginKeychain" 2>/dev/null 1>&2
if [ $? = 0 ] ; then
echo "$HelpTextToShow ($LoginKeychainPasswordToDelete) would be removed" >> "$FilesRemovedList"
echo "from $UserOfKeychain's login keychain" >> "$FilesRemovedList"
echo "" >> "$FilesRemovedList"
echo "Removing $HelpTextToShow ($LoginKeychainPasswordToDelete)"
/usr/bin/security delete-generic-password -s "$LoginKeychainPasswordToDelete" "$EachLoginKeychain" 2>/dev/null 1>&2
done
done
RemoveNortonZoneDirectories()
# Usage: RemoveNortonZoneDirectories user_home_directory
# Summary: Removes Norton Zone paths listed in zoneDirectoryManagerRegistryKey in
# user_home_directory/Preference/com.symantec.nds.Norton-Zone.plist
local UserHomeDir="$1"
local ZonePath
local ZonePaths
[ ! -d "$UserHomeDir" ] && return
ZonePaths=defaults read "$UserHomeDir/Library/Preferences/"com.symantec.nds.Norton-Zone zoneDirectoryManagerRegistryKey 2>/dev/null | grep = | awk -F '"' '{print $2}'
IFS='
for ZonePath in $ZonePaths ; do
RemoveItem "$ZonePath"
done
RemoveItem "$UserHomeDir/Norton Zone" "*"
RestartComputer()
# Usage: RestartComputer
# Summary: Prompts to see if user would like to restart. Restarts
# computer using 'reboot' command if 'yes' or 'y' is
# entered; exits the script otherwise.
# Note: User must be root or an admin for reboot to work, so this
# function should only be used in scripts run as root or
# admin user. OSXmajorVersion should be defined prior to
# calling this function.
echo
# If OSXmajorVersion is not a number
if [ -z "expr "$OSXmajorVersion" / 1 2>/dev/null
" ] ; then
# Assume that osascript can be used to restart the computer - osascript
# in OS 10.2 and later provided restart option for system events
OSXmajorVersion=2
if $RunningFromWithinAppBundleOrSupportFolder ; then
ExitScript $FinishedExitCode
elif $QuitWithoutRestarting ; then
echo "Exited the script without restarting the computer."
elif ! $RestartAutomatically ; then
# If OS version is less that 10.2
if [ $OSXmajorVersion -lt 2 ] ; then
echo "Do you wish to restart the computer now (WARNING: Unsaved changes"
printf "in other open applications will be lost if you do!) (y/n)? "
printf "Do you wish to restart the computer now (y/n)? "
if YesEntered
; then
echo
if $RestartAutomatically ; then
if $PauseBeforeRestarting ; then
printf "Computer will restart in 3 seconds (ctrl-C to cancel restart)..."
sleep 1 &>/dev/null
printf " 3"
sleep 1 &>/dev/null
printf " 2"
sleep 1 &>/dev/null
printf " 1"
sleep 1 &>/dev/null
echo
echo
echo "Restarting the computer..."
reboot
osascript -e 'tell application "System Events" to restart'
RunPredeleteScripts()
# Usage: RunPredeleteScripts [$1]
# Argument: $1 = Path of current volume.
# Summary: If $1 is "" or /, predelete scripts in receipts listed in
# ReceiptsTable are run.
RunPredeleteScript()
local OptionToPassToPredelete=""
local PredeleteScriptProgram
if [ -x "$PredeleteScript" ] ; then
echo "--- Running $PredeleteScript ---"
export SYMANTEC_SAVED_DATA_DIR
echo ">>>>>>>>>>>> Predelete run BEGAN at: date "%Y-%m-%d %H:%M:%S"
# If predelete script processes --skip-symquald as an option
if [ "grep -e "--skip-symquald" "$PredeleteScript"
" ] ; then
# Pass --skip-symquald to the predelete script to skip symquald submission
OptionToPassToPredelete="--skip-symquald"
if $ShowPredeleteErrors ; then
PredeleteScriptProgram=head -n 1 "$PredeleteScript" | grep '^#!'
PredeleteScriptProgram=basename "$PredeleteScriptProgram"
# If predelete script is a bash or sh script
if [ "z$PredeleteScriptProgram" = zbash -o "z$PredeleteScriptProgram" = zsh ] ; then
# Pass -vx to script interpreter to show verbose output
echo "$PredeleteScriptProgram -vx "$PredeleteScript"" $OptionToPassToPredelete
"$PredeleteScriptProgram" -vx "$PredeleteScript" $OptionToPassToPredelete
echo "$PredeleteScript $OptionToPassToPredelete"
"$PredeleteScript" $OptionToPassToPredelete 2>/dev/null 1>&2
echo "Predelete script exited with $?"
echo ">>>>>>>>>>>> Predelete run ENDED at: date
"%Y-%m-%d %H:%M:%S"
local EachReceiptLine
local EachReceiptMatchingAll
local ReceiptList
local ReceiptListMatchingAll=""
local VolumePathPassed="$1"
[ "z$VolumePathPassed" = z/ ] && VolumePathPassed=""
if [ "$VolumePathPassed" ] ; then
echo "Receipt predelete scripts would not be run on that volume." >> "$FilesRemovedList"
elif $DoRunPredeleteScripts ; then
echo "Receipt predelete scripts would be run as they are found." >> "$FilesRemovedList"
echo "Receipt predelete scripts would not be run because the -d option was specified." >> "$FilesRemovedList"
return
elif [ "$VolumePathPassed" ] ; then
echo "Receipt predelete scripts were not run on that volume."
return
elif ! $DoRunPredeleteScripts ; then
echo "Receipt predelete scripts were not run because the -d option was specified."
return
SYMANTEC_SAVED_DATA_DIR="/private/tmp/$FullScriptName-SYMANTEC_SAVED_DATA_DIR-date +"%Y%m%d%H%M%S"
mkdir -p "$SYMANTEC_SAVED_DATA_DIR" 2>/dev/null
IFS='
echo "Looking for predelete scripts in Symantec uninstaller's Receipts folder"
for PredeleteScript in find "/Library/Application Support/Symantec/Uninstaller" 2>/dev/null | grep -E 'predelete$|pre_delete$'
; do
RunPredeleteScript
done
echo "Looking for predelete scripts in /Library/Receipts"
ReceiptList=echo "$ReceiptsTable" | grep '.pkg' | grep -v '^#'
for EachReceiptMatchingAll in echo "$ReceiptsTable" | grep ' -a' | grep -v '^#' | awk -F ' ' '{print $1}'
; do
ReceiptListMatchingAll="$ReceiptListMatchingAllls -d "/Library/Receipts/$EachReceiptMatchingAll"* 2>/dev/null
done
for EachReceiptMatchingAll in $ReceiptListMatchingAll ; do
ReceiptList="$ReceiptListbasename "$EachReceiptMatchingAll"
done
for EachReceiptLine in $ReceiptList ; do
[ "z$ReceiptArg" = z-s ] && continue
[ -z "echo "$ReceiptName" | grep '.pkg$'
" ] && continue
if [ -d "/Library/Receipts/$ReceiptName" ] ; then
for PredeleteScript in find "/Library/Receipts/$ReceiptName" 2>/dev/null | grep -E 'predelete$|pre_delete$'
; do
RunPredeleteScript
done
Dev.pkg"
; do
RunPredeleteScript
done
done
rm -rf "$SYMANTEC_SAVED_DATA_DIR" 2>/dev/null
SetupCleanup()
# Usage: SetupCleanup
# Summary: Initializes variables needed for the RemoveItem function.
BackupLogLocationDir="$BackupLogLocationRootDir/date +"%Y-%m-%d_%H-%M-%S"
ErrorOccurred=false
/bin/rm -rf "$FilesRemovedList" "$FilesRemovedFilesOnlyList" 2>/dev/null 1>&2
echo "Summary of what $FullScriptName would do, based on files" > "$FilesRemovedList"
echo "$RemoveCrontabEntries && echo "and crontab entries "
that currently exist:" >> "$FilesRemovedList"
echo "Summary of what $FullScriptName would attempt to do:" > "$FilesRemovedList"
ShowContents()
# Usage1: ShowContents [-c] [-w] File [TextToShow]
# Usage2: ShowContents [-c] [-w] -s String [TextToShow]
# Summary: Displays contents of File or String. If there are more than
# $LINES or 23 lines, more command is used, using TextToShow as
# the name of the file; if TextToShow is not passed, "....." is
# used. If -c is specified, screen is cleared beforehand.
# If -w is specified, then width of strings will be factored
# into the line count (this option makes output slower when
# the number of lines is less than $LINES or 23).
local SCLineCount
local SCCurrentDir
local SCTempFolder
local SCTempFile
local SCColumns
local SCColumnsMax
local SCColumnsMaxDefault=80
local SCColumnsRemainder
local CSDoAdjustForWidth=false
local CSDoUseString=false
local SCEachLine
local SCGrepPattern='.'
local SCLineFactor
local SCLines
local SCLinesMax
local SCLinesMaxDefault=23
local SCText
while [ "$1" ] ; do
if [ "z$1" = z-c ] ; then
clear
elif [ "z$1" = z-s ] ; then
CSDoUseString=true
elif [ "z$1" = z-w ] ; then
CSDoAdjustForWidth=true
break
shift
done
[ "$COLUMNS" ] && SCColumnsMax=expr "$COLUMNS" - 0 2>/dev/null
[ -z "$SCColumnsMax" ] && SCColumnsMax=$SCColumnsMaxDefault
[ "$LINES" ] && SCLinesMax=expr "$LINES" - 1 2>/dev/null
[ -z "$SCLinesMax" ] && SCLinesMax=$SCLinesMaxDefault
[ $SCColumnsMax -ge $SCColumnsMaxDefault ] && SCGrepPattern='.................................................................................'
if $CSDoUseString ; then
SCLineCount=printf "%s
" "$1" | grep -c ""
$CSDoAdjustForWidth && SCText=printf "%s
" "$1" | grep "$SCGrepPattern"
elif [ -f "$1" ] ; then
SCLineCount=grep -c "" "$1"
$CSDoAdjustForWidth && SCText=grep "$SCGrepPattern" "$1"
return 1
if $CSDoAdjustForWidth ; then
if [ $SCLineCount -le $SCLinesMax ] ; then
IFS='
for SCColumns in printf "%s" "$SCText" | awk '{print length($0)}'
; do
[ $SCLineCount -gt $SCLinesMax ] && break
SCLineFactor=expr $SCColumns / $SCColumnsMax
[ expr $SCColumns % $SCColumnsMax
-gt 0 ] && let SCLineFactor=$SCLineFactor+1
[ $SCLineFactor -gt 1 ] && let SCLineCount=$SCLineCount+$SCLineFactor-1
done
if [ $SCLineCount -gt $SCLinesMax ] ; then
SCCurrentDir=pwd
SCTempFolder="/private/tmp/$FullScriptName-SC-date "%Y%m%d%H%M%S"
mkdir "$SCTempFolder" 2>/dev/null
[ ! -d "$SCTempFolder" ] && return 1
cd "$SCTempFolder" 2>/dev/null
[ "$2" ] && SCTempFile="$2" || SCTempFile="....."
printf "%s
" "$1" >"$SCTempFile"
more -E "$SCTempFile"
cd "$SCCurrentDir" 2>/dev/null
rm -rf "$SCTempFolder" 2>/dev/null
printf "%s
" "$1"
SCCurrentDir=pwd
"%Y%m%d%H%M%S"
cat "$1" >"$SCTempFolder/$SCTempFile"
cat "$1"
return 0
ShowFullFilePath()
# Usage: ShowFullFilePath [-a] [-P | -L] [-e] Path [[-e] Path]
# Version: 1.0.2
# Summary: Prints the full path starting at / of Path if Path exists
# and Path is accessible by the user calling this function.
# Run this function as root to ensure full path displaying.
# If there is more than one existing file that matches the
# name, then only the first path that the shell matches is
# printed unless -a or more than one path is specified.
# You can specify wild card characters ? and and other
# argument operators in the Path (e.g., "../", "a?.txt",
# "[ab]").
# Options: -a Show all matching paths, sorted alphanumerically. If
# -P is not passed, the same file may be shown multiple
# times if there is more than one matching link that
# points to it.
# -e <Path>
# Treat argument after -e as a path. Use -e to treat
# -a, -e, -L, or -P as a path.
# -L Show logical path, even if a file pointed to by a link
# doesn't exist. This is the default.
# -P Show physical path. If a link points to a file that
# does not exist, the path won't be shown.
# History: 1.0.1 - Added -e option and ability to pass multiple paths.
# Arguments can now be passed in any order.
# Fixed error that could occur when resolving links
# with long paths.
# 1.0.2 - Modified for case-sensitive volume compatibility.
# Made temporary file names more distinctive.
local SFFPArgCount=$#
local SFFPCurrentDir
local SFFPCurrentDirTranslated
local SFFPEachLine
local SFFPEachPath
local SFFPFile
local SFFPLDir
local SFFPLLinkLS
local SFFPLLinkPath
local SFFPLPath
local SFFPPathOption=-L
local SFFPSaveIFS="$IFS"
local SFFPShowAll=false
local SFFPTempBase=/private/tmp/ShowFullFilePath-/usr/bin/basename "$0"
-/bin/date +"%Y%m%d%H%M%S"
local SFFPTempFile="$SFFPTempBase.tmp"
local SFFPTempFile2="$SFFPTempBase-2.tmp"
/bin/rm -f "$SFFPTempFile" 2>/dev/null
while [ $SFFPArgCount != 0 ] ; do
case "$1" in
-a)
SFFPShowAll=true
-L|-P)
SFFPPathOption="$1"
[ "z$1" = z-e ] && shift
if [ "$1" ] ; then
[ -s "$SFFPTempFile" ] && SFFPShowAll=true
/usr/bin/printf "%s
" "$1" >>"$SFFPTempFile"
esac
shift
let SFFPArgCount=$SFFPArgCount-1
done
[ ! -s "$SFFPTempFile" ] && return
SFFPCurrentDir=/bin/pwd
SFFPCurrentDirTranslated=/bin/pwd $SFFPPathOption 2>/dev/null
if [ ! -d "$SFFPCurrentDirTranslated" ] ; then
return
cd "$SFFPCurrentDirTranslated" 2>/dev/null
if [ $? != 0 ] ; then
return
/usr/bin/printf "" >"$SFFPTempFile2"
IFS='
for SFFPEachLine in /bin/cat "$SFFPTempFile" 2>/dev/null
; do
[ $? != 0 ] && break
if [ "z$SFFPPathOption" = z-P ] ; then
SFFPLPath="$SFFPEachLine"
while [ -L "$SFFPLPath" ] ; do
[ ! -e "$SFFPLPath" ] && break
cd "/usr/bin/dirname "$SFFPLPath" 2>/dev/null
" 2>/dev/null
SFFPLDir=/bin/pwd -P 2>/dev/null
[ ! -d "$SFFPLDir" ] && break
SFFPLLinkLS=/bin/ls -ld "$SFFPLPath" 2>/dev/null
[ -z "$SFFPLLinkLS" ] && break
# If link or link target contains " -> " in its name
if [ "echo "z$SFFPLLinkLS" | grep ' -> .* -> '
" ] ; then
SFFPLLinkPath=/usr/bin/printf "%s" "$SFFPLLinkLS" | /usr/bin/awk -v THESTR="$SFFPLPath -> " '{ match($0,THESTR) ; print substr($0,RSTART+RLENGTH)}'
SFFPLLinkPath=echo "$SFFPLLinkLS" | awk -F " -> " '{print $2}'
# If link target begins with /
if [ "/usr/bin/printf "%s" "$SFFPLLinkPath" | grep '^/'
" ] ; then
SFFPLPath="$SFFPLLinkPath"
SFFPLPath="$SFFPLDir/$SFFPLLinkPath"
[ "/usr/bin/printf "%s" "$SFFPLPath" | grep '^//'
" ] && SFFPLPath=echo "$SFFPLPath" | /usr/bin/awk '{print substr($0,2)}'
done
if [ ! -e "$SFFPLPath" ] ; then
$SFFPShowAll && continue || break
SFFPEachPath="$SFFPLPath"
SFFPEachPath="$SFFPEachLine"
if [ -d "$SFFPEachPath" ] ; then
cd "$SFFPEachPath" 2>/dev/null
SFFPFile=""
elif [ -d "/usr/bin/dirname "$SFFPEachPath" 2>/dev/null
" ] ; then
cd "/usr/bin/dirname "$SFFPEachPath" 2>/dev/null
" 2>/dev/null
SFFPFile=basename "$SFFPEachPath" 2>/dev/null
[ "z$SFFPFile" = z/ -o "z$SFFPFile" = z. -o "z$SFFPFile" = z.. ] && SFFPFile=""
elif $SFFPShowAll ; then
continue
break
SFFPDir=/bin/pwd $SFFPPathOption 2>/dev/null
if [ ! -d "$SFFPDir" ] ; then
SFFPPath="$SFFPDir[ "z$SFFPFile" != z -a "z$SFFPDir" != z/ -a "z$SFFPDir" != z// ] && echo /
$SFFPFile"
if [ ! -e "$SFFPPath" -a ! -L "$SFFPPath" ] ; then
[ "echo "$SFFPPath" | grep '^//'
" ] && SFFPPath=echo "$SFFPPath" | /usr/bin/awk '{print substr($0,2)}'
echo "$SFFPPath" >>"$SFFPTempFile2"
# If neither option -a nor more than one path was passed, don't show any more names
! $SFFPShowAll && break
done
IFS=$SFFPSaveIFS
[ -s "$SFFPTempFile2" ] && /usr/bin/sort -f "$SFFPTempFile2" | /usr/bin/uniq
/bin/rm -f "$SFFPTempFile" "$SFFPTempFile2" 2>/dev/null
cd "$SFFPCurrentDir" 2>/dev/null
ShowHelp()
# Usage: ShowHelp [$1]
# Argument: $1 = Exit code.
# Summary: Displays script usage and help then exits script.
# If a number is passed to $1, then script exits with
# that number; else, script is not exited.
TEMPFILETEMPLATE="/private/tmp/SymantecTemp"
TEMPFILE="$TEMPFILETEMPLATEdate +"%Y%m%d%H%M%S"
-1"
ShowVersion >>"$TEMPFILE"
$AutoRunScript && echo "
Note: This script requires no user interaction if run as root. You can
run this script on several machines at once by using Symantec
Endpoint Protection to push this script to client Macs." >>"$TEMPFILE"
echo "
WARNING: This script will remove all files and folders created by Symantec
Mac OS X products any files within those folders. Therefore, you will
lose ALL files that reside in those folders, including any that you
have created.
Usage: $FullScriptName [-CcdeFfghIikLlmpQqRrV] [-QQ] [-re] [volume ...]
Summary: If no option or volume is specified, then all Symantec files are removed from the current boot volume, including the invisible Symantec files (i.e., AntiVirus QuickScan and Symantec FS files), and Symantec crontab entries are removed from all users' crontabs; otherwise, for each volume specified, all Symantec files and Symantec crontab entries will be removed from that volume if no options are specified. If files are removed from the current boot volume, receipt predelete scripts are run unless -d is passsed and Symantec processes are killed unless -k is passed.
If a volume does not have OS X installed on it, then only the invisible Symantec files are removed from that volume.
Each volume name may begin with "/Volumes/", unless it is "/". The easiest way to specify a volume is to drag the volume onto the Terminal window.
Note: The Terminal application does not support high ASCII or double-byte character entry via keyboard or via drag-and-drop. If you want to have files removed from a volume that is not the current boot volume and that has a name containing high ASCII or double-byte characters, use the -A option.
Options: -A Remove all Symantec files from all mounted volumes. Crontab entries are also removed from the current boot volume, but not from other volumes. If a volume does not have OS X installed on it, then only the invisible Symantec files are removed from that volume. -C Do not remove crontab entries. -c Only remove crontab entries from all users' crontabs. Nothing is removed from any volume. -d Bypass the running of receipt predelete scripts. It is best to have predelete scripts run for more thorough uninstalls. -E Suppress errors and other output when predelete scripts are run. Predelete scripts are run only when removing files from the current boot volume. -e Show errors and other output when predelete scripts are run. Predelete scripts are run only when removing files from the current boot volume. This is the default as of verion 7.0.73. -F List only regular files that are currently installed and that would be deleted. No note is added if a file is not supposed to be removed by product uninstaller. -f Do not show files as they are removed. If -f is not specified, file names are shown as files are removed. -g Do not remove items located within: /Library/Logs {each user's home}/Library/Logs -h Display help. -I Do not remove invisible Symantec files. -i Only remove invisible Symantec files. -k Do not attempt to kill Symantec processes. -l List only files that are currently installed and that would be deleted. As of version 6.0.0, contents of folders are also shown. Nothing is deleted by this option. -L List all files that $FullScriptName will attempt to find and delete. Nothing is deleted by this option. -m Show output from -l, -L, or -R options using more program. This is no longer the default action as of version 5.52 of $FullScriptName. -p Eliminate pause before restarting computer. If option -p is not specified, then there is a three second delay before the restart occurs. -q Quit script without restarting. This also suppresses the prompt to restart. -Q Quits Terminal application when script is done. If Terminal is being run by more than one user at once, Terminal is not quit. If passed a second time, it is the same as -QQ option. -QQ Quits Terminal application for all users when script is done. -R This option is equivalent to the -l option. -r Automatically restart computer when script is done if there are Symantec processes and/or kexts in memory and there were non-invisible files removed from /. -re Same as -r option. Though -re is deprecated, it remains for backwards compatibility. -u Only output files that are installed that should have been removed by the UI uninstaller. If there are files found, exit with $ExitCodeWhenFilesRemain; otherwise, exit with 0. No progress is shown and nothing is deleted. -V Show version only.
Examples: $FullScriptName Deletes all Symantec files and Symantec crontab entries from the boot volume.
$FullScriptName /Volumes/OS 10.2 Deletes all Symantec files and Symantec crontab entries from the volume named "OS 10.2". Nothing is deleted from the boot volume.
$FullScriptName Runner / Deletes all Symantec files and Symantec crontab entries from the volume named "Runner" and from the boot volume.
$FullScriptName -i "Test Disk" Deletes only invisible Symantec files from the volume named "Test Disk".
$FullScriptName -A -r Deletes all Symantec files and Symantec crontab entries from all mounted volumes that have OS X installed on them. Deletes only invisible Symantec files from volumes that do not have OS X installed on them. Computer is restarted automatically if necessary.
$FullScriptName -Ai Deletes only invisible Symantec files from all volumes.
$FullScriptName -I Deletes all but the invisible Symantec files from the boot volume. Crontab entries are removed from the boot volume.
$FullScriptName -C Deletes all Symantec files from the boot volume. No crontab entries are removed.
$FullScriptName -L -A Lists all the files that $FullScriptName looks for on all volumes. The files may or may not be currently installed. Nothing is deleted.
$FullScriptName -R -A Lists only the Symantec files that are currently installed on all volumes. Files within existing folders will also be shown. Nothing is deleted.
$FullScriptName -l -i Lists the invisible Symantec files that are currently installed on the boot volume. Nothing is deleted.
Note: You must be root or an admin user to run this script. You can
simply double-click on $FullScriptName to remove all
Symantec files and crontab entries from the boot volume.
" >>"$TEMPFILE"
ShowContents "$TEMPFILE"
/bin/rm "$TEMPFILE" 2>/dev/null
[ "$1" ] && exit $1
ShowUsage()
# Usage: ShowUsage [$1 [$2]]
# Arguments: $1 = Exit code.
# $2 = Error message to display before showing usage.
# Summary: Displays script usage. If an exit code is passed,
# script is exited with that value.
if [ "$2" ] ; then
echo
echo "$2"
echo
ShowHelp | grep "^Usage.*:"
[ "$2" ] && echo
[ -n "$1" ] && exit "$1"
ShowVersion()
# Usage: ShowVersion
# Summary: Displays the name and version of script.
echo " $FullScriptName $Version **"
SymantecIsInMemory()
# Usage: SymantecIsInMemory
# Summary: If a Symantec process or kext is in memory,
# 0 is returned; 1 is returned.
local SymantecIsInMemoryResult=1
# If there are no more Symantec processes in memory
if KillSymantecProcesses -n ; then
: # 7.0.49: Commented out the following to avoid potential hang of kextstat (Etrack 3925328)
kmodstat | grep -i Symantec | grep -v " grep -"
2>/dev/null" ] ; thenkextstat | grep -i Symantec | grep -v " grep -"
" ] ; then else
SymantecIsInMemoryResult=0
return $SymantecIsInMemoryResult
YesEntered()
# Usage: YesEntered
# Summary: Reads a line from standard input. If "y" or "yes"
# was entered, true is shown and 0 is returned; otherwise,
# false is shown and 1 is returned. The case of letters is
# ignored. Sample call:
# if YesEntered
read YesEnteredString
YesEnteredString=echo "z$YesEnteredString" | awk '{print tolower(substr($0,2))}'
if [ "'$YesEnteredString" = "'y" -o "'$YesEnteredString" = "'yes" ] ; then
echo true
return 0
echo false
return 1
which which &>/dev/null
MissingRequiredPrograms=""
SavedIFS="$IFS"
IFS='
for RequiredProgram in $RequiredPrograms ; do
which "$RequiredProgram" &>/dev/null
[ $? != 0 ] && MissingRequiredPrograms="$MissingRequiredPrograms
$RequiredProgram"
done
IFS="$SavedIFS"
which"
if [ "$MissingRequiredPrograms" ] ; then
echo
echo "WARNING: Could not continue because the following program(s) could not be found:"
echo "$MissingRequiredPrograms"
echo
exit 2
ScriptPath=ShowFullFilePath "$0" -P
ScriptDir=dirname "$ScriptPath"
if [ $# -eq 0 ] ; then # If no arguments were passed to script
# Run script as if it was double-clicked in Finder so that
# screen will be cleared and quit message will be displayed.
RunScriptAsStandAlone=true
# Run script in command line mode so that
# screen won't be cleared and quit message won't be displayed.
RunScriptAsStandAlone=false
if [ "echo "$ScriptDir" | grep -e "$LaunchLocationGrepPattern"
" ] ; then
RunningFromWithinAppBundleOrSupportFolder=true
RunningFromWithinAppBundleOrSupportFolder=false
if $RunScriptAsStandAlone ; then
clear >&2
ProcessArguments --OptionIsOneArgument="-QQ" --OptionIsOneArgument="-re" "$@"
OSXVersion=defaults read /System/Library/CoreServices/SystemVersion.plist ProductVersion
OSXmajorVersion=printf "%s" "$OSXVersion" | awk -F . '{print $2}'
ProcessAppRemoval
if [ -d /Users/corey_swertfager -a -L /Volumes/SOE -a $CreateFilesRemovedListOnly = false ] ; then
ExitScript 0
if [ "whoami
" != "root" ] ; then # If not root user,
if $PublicVersion ; then
GetAdminPassword true # Prompt user for admin password
elif ! $DoShowOnlyFilesThatShouldHaveBeenUninstalled ; then
ShowVersion >&2
echo >&2
# Run this script again as root
sudo -p "Please enter your admin password: " "$0" "$@"
ErrorFromSudoCommand=$?
# If unable to authenticate
if [ $ErrorFromSudoCommand -eq 1 ] ; then
echo "You entered an invalid password or you are not an admin user. Script aborted." >&2
ExitScript 1
sudo -k # Make sudo require a password the next time it is run
exit $ErrorFromSudoCommand # Exit so script doesn't run again
if [ -z "$VolumesToUse" ] ; then
BootVolumeWillBeSearched=true
if [ $PublicVersion = true -a $CreateFilesRemovedListOnly = false -a
$RemoveCrontabEntriesOnly = false -a $RemoveInvisibleFilesOnly = false -a
$AutoRunScript = false -a $RunningFromWithinAppBundleOrSupportFolder = false ] ; then
DetermineAction
if [ $RemoveFromAllVolumes = true -a $CreateFilesRemovedListOnly = false -a $RemoveCrontabEntriesOnly = false -a $RemoveInvisibleFilesOnly = false -a $AutoRunScript = false -a $RunningFromWithinAppBundleOrSupportFolder = false ] ; then
echo
printf "Are you sure you want to remove Symantec files from ALL mounted volumes (y/n)? "
if YesEntered
; then
echo
echo
echo "Script aborted. No files were removed."
ExitScript 0
SetupCleanup
WillTense=will
echo "Generating a list of files that would be removed by" >&2
echo " $FullScriptName (no files will be removed at this time)..." >&2
WillTense=would
elif $RemoveInvisibleFilesOnly ; then
echo "Removing AntiVirus QuickScan files and Symantec FS files..."
if $BootVolumeWillBeSearched ; then
if [ $RestartAutomatically = true -a $RemoveCrontabEntriesOnly = false ] ; then
echo
echo "Note: Computer will be restarted automatically if necessary."
echo
echo
echo "Note: This script will automatically quit when finished."
echo
echo "Removing Symantec files..."
! $RemoveInvisibleFiles && echo "Invisible Symantec files will not be deleted."
if $RemoveCrontabEntriesOnly ; then
echo "Only crontab entries $WillTense be removed."
! $RemoveCrontabEntries && echo "Symantec crontab entries $WillTense not be removed."
! $RemoveInvisibleFiles && echo "AntiVirus QuickScan and Symantec FS files $WillTense not be removed."
if $RemoveFromAllVolumes ; then
VolumesToUse="/
"ls -d /Volumes/*
elif ! $RemoveFromOtherVolumes ; then
VolumesToUse=/
ListOfVolumesToUse=echo "$VolumesToUse" | sort -f | uniq
IFS='
for EachVolume in $ListOfVolumesToUse ; do
[ -L "$EachVolume" ] && continue
FilesFoundOnThisVolume=false
RemoveAllSymantecFiles "$EachVolume"
if [ $CreateFilesRemovedListOnly = true -a $FilesFoundOnThisVolume = false -a $ListOnlyFilesThatExist = true ] ; then
echo "No matching files were found on "basename "$EachVolume"
"." >> "$FilesRemovedList"
done
FinishCleanup
FinishedExitCode=$?
if [ $BootVolumeWillBeSearched = true -a $CreateFilesRemovedListOnly = false ] ; then
# If some Symantec process or kext is in memory, touch restart file
if SymantecIsInMemory ; then
# touch of Extensions folders may not be necessary, since restart is triggered (Etrack 3925328)
touch "$SymantecCleanupRestartFile" # /Library/Extensions /System/Library/Extensions
# May run kextcache in a future release:
# echo "Rebuilding kext caches"
# kextcache -u /
if [ -f "$SymantecCleanupRestartFile" ] ; then
echo
echo "NOTE: You should now restart the computer to get Symantec processes"
echo " and kexts out of memory and/or to remove login items."
RestartComputer
elif [ -e /Library/StartupItems/CleanUpSymWebKitUtils ] ; then
echo
echo "NOTE: You should now restart the computer to have CleanUpSymWebKitUtils"
echo " finish removing SymWebKitUtils.framework."
RestartComputer
Posted on β03-09-2022 04:58 AM
Can you please send me a txt file so I can try this script? Thank you so much!
Posted on β03-10-2022 06:17 PM
If you'll send me an email, I'm happy to attach it. I can't fit it in the source code box here. swallace@mckinneyisd.net
Posted on β03-10-2022 04:58 PM
Yuk !! where is the txt file ?
Posted on β03-10-2022 06:16 PM
Shoot me an email and I can attach it. It's too many characters to fit in the source code box. swallace@mckinneyisd.net
Posted on β09-06-2022 12:01 PM
you you please send me the text file also. tony.cisneros@eastwestbank.com
Posted on β09-06-2022 12:13 PM
