I am trying to automate the creation of an Outlook signature and I have most of the parts down except I can't find a way to pass values from User and Location to the script. I thought passing $FULLNAME or $POSITION as script parameters would work but all it does is literally pass the string "$FULLNAME" to the script.
How to pass User and Location values to script
Best answer by shannon_pasto
myu wrote:
Hi Moose,
I tried removing the spaces and then rebooting after removing the CP and re-applying it just to make sure but it made no difference.
Don't know how to attach images in a post so inserting a link to it instead ...
https://drive.google.com/file/d/1RJSGKBjtHpT4_i7RV0HNl-146vssMNDs/view?usp=sharing
It seems as though your plist file is improperly formatted. Try reading another plist in the same directory (/Library/Managed Preferences) and you'll see what the difference is. None of the profile info should be there, ie PayloadContent etc
