How to prevent users from re-enabling SSL v2 and v3 in Oracle Java (JDK and JRE)?
  • November 18, 2014
  • 0 views
To protect against the POODLE vulnerability (CVE-2014-3566), Oracle says to disable SSL v3 and v2 from the Java Control Panel:
external image link
But it appears there's nothing stopping any user from simply re-enabling these settings again!
Does anyone know how to prevent users from re-enabling SSL v2 and v3 in Oracle Java?
And how would one do so from the command line, i.e. from a silent pkg pushed to endpoints by JAMF Casper?
We're still running Java 7 (Update 71), but the same question would apply to Java 8 (Update 25), I would presume.
Any ideas would be much appreciated.
  • November 22, 2014
If there is not any reason for the user to modify Java then one possibility is to lock down the Java control panel via configuration profile. Even a user with admin privileges would not be able to open it.
Another possibility is a modification to the Oracle deployment properties file that can be used to configure Java. See https://docs.oracle.com/javase/7/docs/technotes/guides/jweb/jcp/properties.html
I say possibility because in my initial glance I did not see that specific setting, though maybe Oracle will add it (after all, they did recently remove one of the riskier security levels).
Cookie policy
Cookie settings
