Posted on 05-30-2019 11:14 AM
What's new in this release
Jamf Connect Login (version 1.2.0):
Support for PingFederate as a cloud identity provider (IdP). To integrate Jamf Connect Login with PingFederate, see PingFederate.
Jamf Connect Sync (version 1.0.4): N/A
Jamf Connect Verify (version 1.1.0):
Added support for PingFederate as a cloud identity provider (IdP). To integrate Jamf Connect Verify with PingFederate, see Configuring Jamf Connect Verify.
Added support for custom IdPs. For more information, see Configuring Jamf Connect Verify.
Added a launch agent that instructs macOS to launch Jamf Connect Verify on log in.
For more information, including Release Notes, please see the Jamf Connect Administrator’s Guide:
https://docs.jamf.com/jamf-connect/1.4.0/administrator-guide/index.html
Posted on 05-31-2019 01:19 AM
@kaylee.carlson, thanks for the update! I'm not seeing PI-006950 in Known Issues. Could you please add this so we can track when this will be fixed?
PI-006950 is about Jamf Connect ignoring the Prefixes of the last names when pulling from Azure AD to create local User. Suffixes of first name are ignored as well.
Posted on 06-01-2019 03:32 AM
Hi
Is there any way to download trail version for POC?
