Jamf PowerBI connection
  • November 18, 2023
  • 5 replies
  • 140 views
I would like to setup PowerBI dashboards for Jamf.
However I cannot find a good up-to-date guide that steps through all the steps. Jamf's YT video https://youtu.be/PBsP84G-vtg?si=G4zj7mc2gZpH15Ml is great, but the narrator just says to use an account that has get rights to computers, etc. but does not explain how you would set that up. I find many YT tech tutorial videos are like that - missing important info that the narrator just assumes everyone knows.
I have an AD/LDAP service account added to Jamf and have given it read permissions to everything. But when I try to use that account to connect to Jamf in PowerBI it fails to authenticate and so does my regular account. I'm not clear on what URL to use for our on-prem Jamf environment. Is it https://yourcompany.domain or https://yourcompany.domain/api?
Jamf's GitHub page is 4 years old! https://github.com/jamf/powerbi/ - can't this be updated? It still talks about the custom connector which I understand you don't need anymore.
And do I need to do anything in the API to set this up?
sdagley
  • November 18, 2023
@mthoma The PowerBI example uses Basic Auth which is is disabled by default in Jamf Pro now. You should convert the script to use Bearer Token auth (see https://community.jamf.com/t5/tech-thoughts/how-to-convert-classic-api-scripts-to-use-bearer-token/ba-p/273910 for guidance) but if you just want to see how the integration works you can (temporarily) re-enable Basic Auth by selecting "User accounts and groups" in your JSS console then clicking on the Password Policy button and enabling the "Allow Basic authentication in addition to Bearer Token authentication" option. Note that option is slated to be removed early next year.
  • November 20, 2023
Thanks for that info. Wish Jamf would provide it in their docs. However I don't understand why I need a script and where that script will reside? I'm connecting to Jamf via PowerBI Desktop on my Windows laptop using the built-in Jamf connector (which is labelled as Beta).
  • November 20, 2023
Managed finally to get it working by following the advice from this post: https://community.fabric.microsoft.com/t5/Developer/Issue-with-jamf-pro-Beta-connector-since-jamf-maintenance/m-p/1484599
So make sure you don't include the final / in your URL. The odd thing though is that when loading the data, PowerBI says it's "Waiting for https://yourcompany.domain/", so somehow inconsistent.
davbeer
  • March 22, 2024
I would like to do the same without the Desktop version... @mthoma did you connect to powerBI cloud or the desktop version? It seems all documentation was not only old, but desktop only....
wakco11
  • June 19, 2024
I'm wondering the same thing, I appear to have got the Cloud Connector going, now just how to use it.
