Jamf Pro Script
  • September 19, 2024
  • 8 replies
  • 1 view
JamfAdmin2
Hello,
Does anyone out there have a script in Jamf I can use that can auto fill the "Update user and location" section. I need it to work for computers that are being setup and deployed for the first time as well as computers that have already been deployed and are current.
AJPinto
  • 2717 replies
If you require people to enter credentials to enroll, Jamf will automatically assign the device to whoever enrolls it. Devices can also be assigned with recon, but I would have to dig up the verb (for example have a function to see the userID of the logged in user, and pipe that in to recon to assign the device to that person).
You will want cloud identity or LDAP setup to actually pull in the correct information beyond the users name.
YanW
  • 180 replies
  • September 20, 2024
Do you mean this?
#!/bin/sh loggedInUser=$(stat -f%Su /dev/console) jamf recon -endUsername $loggedInUser
JamfAdmin2
  • 59 replies
YanW wrote:
Do you mean this?
I would pretty much need the script to auto fill all of this user info within user and location:
Username:
Full Name:
Email Address:
Position:
Department:
YanW
  • 180 replies
Username:
Full Name:
Email Address:
Position:
Department:
yea, maybe try it first
JamfAdmin2
  • 59 replies
It was completed but no changes happended
YanW
  • 180 replies
update inventory
Jason33
  • 223 replies
Arent those fields populated by LDAP mappings? Do you have an LDAP server integrated with your Jamf instance? If not, start there. You'll also want to go in to Settings - Computer Management - Inventory Collection and make sure to check 'Collect user and location information from Directory Service'. When a recon is completed, that info should update, if its not already.
And one more thing...check your PreStage and confirm in Account Settings that 'Pre-fill Primary Account Information' is checked. That might help out as well.
  • 7 replies
It might be more than what you need, but I suggest you look at SYM. https://snelson.us/2024/06/setup-your-mac-1-15-0-with-sym-helper-1-2-0-via-swiftdialog-2-5-0/ It streamlines the onboarding process for devices.
Cookie policy
Cookie settings
