JSS 9.2 and SafeGuard for Mac Automation (SGMA) - Sophos
Just received this alert from Sophos:
JAMF Software Server 9.2 issue with SGMA 1.0.6 It has been brought to our attention that JAMF Software Server (JSS) 9.2 and SafeGuard for Mac Automation (SGMA) 1.0.6 may not be compatible with each other. SafeGuard Credentials created by SGMA do not appear to be saved in JSS after script execution. SGMA officially only supports JSS 8.52. At present, currently our recommendation is to avoid upgrading to JSS 9.2 if you wish to continue using the SGMA solution. This is currently under investigation. Please contact your Technical Support Account Manager directly if you have any concerns or require further information.
Cookie policy
Cookie settings
