Hi there,
I have a script that runs once on each machine in our macOS fleet. The script essentially creates a launchdaemon that runs a script that kills and restarts jamf binaries on machines once a day to mitigate the jamf checkin issues (no we do not have a force restart schedule).
Issue I'm noticing is that some devices (about 50) even though they have the launchdaemon loaded it doesn't seem to be restarting their Jamf binaries. My thinking is it may be the script that is not working as intended.
I intend for the restart script to be re-ran everyday on the local machine but some devices have not checked in for weeks now.
cat << 'EOF' > /private/var/tmp/JamfRestart.sh
sudo killall jamf
sleep 10
sudo jamf policy
EOF
chmod 755 /private/var/tmp/JamfRestart.sh
chown root:wheel /private/var/tmp/JamfRestart.sh
cat << EOF > /Library/LaunchDaemons/com.JamfRestart.plist
<plist version="1.0">
<dict>
<key>EnvironmentVariables</key>
<dict>
<key>PATH</key>
<string>/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/usr/local/sbin:/opt/local/bin</string>
</dict>
<key>Label</key>
<string>JamfRestart</string>
<key>ProgramArguments</key>
<array>
<string>/bin/sh</string>
<string>/private/var/tmp/JamfRestart.sh</string>
</array>
<key>RunAtLoad</key>
<false/>
<key>StartInterval</key>
<integer>86400</integer>
</dict>
</plist>
EOF
chmod 644 /Library/LaunchDaemons/com.JamfRestart.plist
chown root:wheel /Library/LaunchDaemons/com.JamfRestart.plist
launchctl load -w /Library/LaunchDaemons/com.JamfRestart.plist
