I'm using the latest from the October release of the Resource Kit to mount network shares. I need to use DFS and it isn't mapping (see attachment). The path is: starbucksamersettle sscdepartmentsit but as you can see it isn't showing that way in the error message. Is there something that I need to update to make this work?
Any direction is helpful. Thank you!
James Fuller | Starbucks Coffee Company | Technology Application Services | Application Developer
