NetSUS setup help
  • 351 replies
okay, so I got NetSUS installed on a fresh install of Ubuntu.
However when following the instructions to go to: https://myhostname.local/webadmin to access the NetBoot/SUS server web application, all any browser gives me is a combination of the following:
-Unable to connect
-can't establish a connection
-webpage not available
-connection refused
I've tried connecting via IP addresss, hostname.local, localhost, 127.0.0.1...and I get nothing.
What else do I need to do? Do I have to start the webserver on the machine?
This is my first dive into Linux, so yes..I'm a bit clueless.
Thanks fellas...
-A
  • 35 replies
  • May 16, 2014
Hmm perhaps if your not too familiar with Linux then using the premade applicance template might be the better way to go?
http://jamfsoftware-content.s3.amazonaws.com/downloads/NetSUS3.0.ova
you can import this into vsphere or similar and you should be good to go after entering in all the info at boot time
  • 35 replies
  • May 16, 2014
also i wouldnt use .local as the hostname if possible. i'd make sure it had a FQDN with forward and reverse records
dpertschi
Forum|alt.badge.img+19
  • 459 replies
  • May 16, 2014
I installed the NetSUS on a Red Hat server recently, with zero previous Linux experience- so I know where your coming from.
I had the same problem, see this thread: https://jamfnation.jamfsoftware.com/discussion.html?id=10420
Have a go at downloading the source and compiling a new installer and running that right on top of the existing install. That process was easier than it sounds if you've never done it.
  • 351 replies
  • May 16, 2014
Thanks fellas...
@dpertschi I've never compiled anything so yet again, something I'm clueless on. if you have quick how to's that would be great.
  • 165 replies
  • May 16, 2014
Download ZIP from:
https://github.com/jamf/NetSUS
CD into the (NetSUS-master) directory and run CreateNetSUSInstaller (e.g. "./CreateNetSUSInstaller.sh"). You should end up with a NetSUSInstaller.run file.
  • 351 replies
  • May 16, 2014
Thanks again fellas...
I got it up and running. Only problem now is that whenever I check for updates using CLI on a client, it says:
lab-testmac3:~ root# softwareupdate -l
Software Update Tool
Copyright 2002-2012 Apple Inc.
Finding available software
Can't load data from the Software Update server (10.30.2.224)
Maybe I've got the wrong catalog entered???
It's currently setup as:
URL:  http://10.30.2.224/content/catalogs/index_http://10.30.2.224/content/catalogs/index_sucatalog.sucatalog
Cookie policy
Cookie settings
