printers not adding, not binding to domain with script
I am getting spotty results with printers not being added and machines not being joined to the domain when those options are specifically set in Casper Imaging.
We are using Centrify for joining AD, not the magic triangle. So we are running a script to kick off a command to launch a binding script. My techs are finding that after Casper reboots, they are not bound to the domain, so have to manually run the command.
This is spotty - some locations are OK, while others are not. We have a master JSS and local replicas which have replicated properly to the different sites. It is mostly failing. We are using fully qualified domain names. This same setup has worked in the past at a test site.
Ideas on what may be failing? Tests I can do?
TIA
Cookie policy
Cookie settings
