Problem while running script for os update 12.6.1
Hi
Getting error while running the below script for getting the macosmonterey installer in applications
Please suggest what i am missing here
softwareupdate --list-full-installers | grep 'macOS' | awk '{print ++count " " $0}'
softwareupdate --fetch-full-installer --full-installer-version 12.6.1
Install failed with error: Installation failed Error Domain=PKDownloadError Code=8 "(null)" UserInfo={NSUnderlyingError=0x6000032f45a0 {Error Domain=NSURLErrorDomain Code=-999 "cancelled" UserInfo={NSErrorFailingURLStringKey=https://swcdn.apple.com/content/downloads/36/13/012-90254-A_BJQ1VMPD44/z225i7bzise31eo21e4kgfkafz7zq0q9tu/InstallAssistant.pkg, NSErrorFailingURLKey=https://swcdn.apple.com/content/downloads/36/13/012-90254-A_BJQ1VMPD44/z225i7bzise31eo21e4kgfkafz7zq0q9tu/InstallAssistant.pkg, _NSURLErrorRelatedURLSessionTaskErrorKey=( "LocalDataTask <F5729777-F5DD-4264-AE21-A87B94ACA121>.<1>" ), _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <F5729777-F5DD-4264-AE21-A87B94ACA121>.<1>, NSLocalizedDescription=cancelled}}}
Error running script: return code was 1.
  • December 1, 2022
Anyone found solution for this?
  • 23 replies
  • December 6, 2022
Now i am getting the below error. unable to get authorize. even though entered admin user name password
Install finished successfully Error: failed to authorize for installation. Provide a password with --stdinpass or --passprompt. By using the agreetolicense option, you are agreeing that you have run this tool with the license only option and have read and agreed to the terms. If you do not agree, press CTRL-C and cancel this process immediately.
softwareupdate --fetch-full-installer --full-installer-version 13.0.1
echo $pass | '/Applications/Install macOS Ventura.app/Contents/Resources/startosinstall' --user $admin --stdinpass --agreetolicense --nointeraction --forcequitapps
Cookie policy
Cookie settings
