Problem with IOS Home Screen layout configuration
Pshen
Hello, I encountered a problem that is not allowing me to add apps in "Home Screen Layout" configuration. I click "add" and select the app, after I try to add another one nothing happens, and it disappears after saving. New blank configuration without pre-settings. Can you help with it please?
Hi, I have exactly the same issue. Is there anyone knows the solution?
After adding an item, hover your mouse over the item you just added then scroll to the right hand side. You will see the a save button there.
That design is not helpful. It took me a while to find out.
Cookie policy
Cookie settings
