Hi Everyone,
I have been tasked with deploying a script to our mobile systems that will add several new search domains to the DNS config. I have a working script that "changes" the current search domain, but what I need to do is have it add a new entry, not edit the current one (if that makes sense). In my current script, I can plug in all of my new search domains and it will add them as comma separated, unfortunately though that's not going to work.
For example, our systems start out with a given search domain:
company.companyusa.corp with my current script, if I plugin the new search domains it will look something like company.corp, sea.company.corp, APAC.company.corp... est..
I need these to be on new lines:
Company.corp
sea.company.corp
APAC.company.corp
I've included the script i'm currently working on. Any insight or suggestions would be very much appreciated.
# setSearchDomains.sh -- Set a search domain for a specified network interface
# SYNOPSIS
# sudo setSearchDomains.sh
# sudo setSearchDomains.sh <mountPoint> <computerName> <currentUsername> <networkInterface>
# <searchDomains>
# If the $networkInterface parameter is specified (parameter 4), this is the Network Interface for
# which the search domains will be set. The expected values for the $networkInterface parameter can
# be found by running the command:
# networksetup -listallnetworkservices
# If the $searchDomains parameter is specified (parameter 5), this is the search domain that will
# be set.
# If no parameter is specified for parameters 4 and 5, the hardcoded value in the script will be
# used.
# DESCRIPTION
# This script will set a search domain in the network settings for whichever network interface has
# been specified.
# DEFINE VARIABLES & READ IN PARAMETERS
# HARDCODED VALUES ARE SET HERE Example Interfaces are Ethernet 1, Ethernet 2, Thunderbolt Ethernet (rMBP), USB Ethernet etc basically whatever your Network Type shows in Sys Prefs
networkInterface="Ethernet"
**searchDomains="comapny.corp, americas.company.corp, europe.comapny.corp, sea.comapny.corp, asia.comapany.corp**"
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 4 AND, IF SO, ASSIGN TO "networkInterface"
if [ "$4" != "" ] && [ "$networkInterface" == "" ];then
networkInterface=$4
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 5 AND, IF SO, ASSIGN TO "searchDomains"
if [ "$5" != "" ] && [ "$searchDomains" == "" ];then
searchDomains=$5
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [ "$networkInterface" == "" ]; then
echo "Error: No network interface has been specified."
exit 1
if [ "$searchDomains" == "" ]; then
echo "Error: No search domains have been specified."
exit 1
OS=`/usr/bin/defaults read /System/Library/CoreServices/SystemVersion ProductVersion | awk '{print substr($1,1,4)}'`
if [[ "$OS" < "10.5" ]]; then
echo "Setting search domains for OS $OS..."
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Support/networksetup -setsearchdomains "$networkInterface" "$searchDomains"
/usr/sbin/networksetup -setsearchdomains "$networkInterface" "$searchDomains"
