Reset Keychain with Swift Dialog UI
  • February 10, 2025
  • 0 views
borrowed the script from @bwoods and put some nice Swift Dialog UI on it.  Gives user notification of what is about to happen and notifications along the way.
#!/bin/zsh ###################################################################################################### # # Gobal "Common" variables (do not change these!) # ###################################################################################################### export PATH=/usr/bin:/bin:/usr/sbin:/sbin LOGGED_IN_USER=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' ) USER_DIR=$( dscl . -read /Users/${LOGGED_IN_USER} NFSHomeDirectory | awk '{ print $2 }' ) OS_PLATFORM=$(/usr/bin/uname -p) [[ "$OS_PLATFORM" == 'i386' ]] && HWtype="SPHardwareDataType.0.cpu_type" || HWtype="SPHardwareDataType.0.chip_type" SYSTEM_PROFILER_BLOB=$( /usr/sbin/system_profiler -json 'SPHardwareDataType') MAC_SERIAL_NUMBER=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.serial_number' 'raw' -) MAC_CPU=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract "${HWtype}" 'raw' -) MAC_HADWARE_CLASS=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.machine_name' 'raw' -) MAC_RAM=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.physical_memory' 'raw' -) FREE_DISK_SPACE=$(($( /usr/sbin/diskutil info / | /usr/bin/grep "Free Space" | /usr/bin/awk '{print $6}' | /usr/bin/cut -c 2- ) / 1024 / 1024 / 1024 )) MACOS_VERSION=$( sw_vers -productVersion | xargs) # Swift Dialog version requirements SW_DIALOG="/usr/local/bin/dialog" [[ -e "${SW_DIALOG}" ]] && SD_VERSION=$( ${SW_DIALOG} --version) || SD_VERSION="0.0.0" MIN_SD_REQUIRED_VERSION="2.3.3" DIALOG_INSTALL_POLICY="install_SwiftDialog" SUPPORT_FILE_INSTALL_POLICY="install_SymFiles" ################################################### # # App Specfic variables (Feel free to change these) # ################################################### SUPPORT_DIR="/Library/Application Support/GiantEagle" SD_BANNER_IMAGE="${SUPPORT_DIR}/SupportFiles/GE_SD_BannerImage.png" LOG_DIR="${SUPPORT_DIR}/logs" LOG_FILE="${LOG_DIR}/ResetKeychain.log" LOG_STAMP=$(echo $(/bin/date +%Y%m%d)) ICON_FILES="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/" JSON_OPTIONS=$(mktemp /var/tmp/ResetKeychain.XXXXX) BANNER_TEXT_PADDING=" " #5 spaces to accomodate for icon offset SD_INFO_BOX_MSG="" SD_WINDOW_TITLE="${BANNER_TEXT_PADDING}Reset Login Keychain" SD_DIALOG_GREETING=$((){print Good ${argv[2+($1>11)+($1>18)]}} ${(%):-%D{%H}} morning afternoon evening) # Define the target directory KEYCHAIN_DIR="$USER_DIR/Library/Keychains" KEYCHAIN_BACKUP_DIR="$USER_DIR/Library/Keychains Copy" RESTART_TIMER=30 ################################################## # # Passed in variables # ################################################# JAMF_LOGGED_IN_USER=$3 # Passed in by JAMF automatically SD_FIRST_NAME="${(C)JAMF_LOGGED_IN_USER%%.*}" #################################################################################################### # # Functions # #################################################################################################### function create_log_directory () { # Ensure that the log directory and the log files exist. If they # do not then create them and set the permissions. # # RETURN: None # If the log directory doesnt exist - create it and set the permissions [[ ! -d "${LOG_DIR}" ]] && /bin/mkdir -p "${LOG_DIR}" /bin/chmod 755 "${LOG_DIR}" # If the log file does not exist - create it and set the permissions [[ ! -f "${LOG_FILE}" ]] && /usr/bin/touch "${LOG_FILE}" /bin/chmod 644 "${LOG_FILE}" } function logMe () { # Basic two pronged logging function that will log like this: # # 20231204 12:00:00: Some message here # # This function logs both to STDOUT/STDERR and a file # The log file is set by the $LOG_FILE variable. # # RETURN: None echo "${1}" 1>&2 echo "$(/bin/date '+%Y-%m-%d %H:%M:%S'): ${1}" | tee -a "${LOG_FILE}" } function check_swift_dialog_install () { # Check to make sure that Swift Dialog is installed and functioning correctly # Will install process if missing or corrupted # # RETURN: None logMe "Ensuring that swiftDialog version is installed..." if [[ ! -x "${SW_DIALOG}" ]]; then logMe "Swift Dialog is missing or corrupted - Installing from JAMF" install_swift_dialog SD_VERSION=$( ${SW_DIALOG} --version) fi if ! is-at-least "${MIN_SD_REQUIRED_VERSION}" "${SD_VERSION}"; then logMe "Swift Dialog is outdated - Installing version '${MIN_SD_REQUIRED_VERSION}' from JAMF..." install_swift_dialog else logMe "Swift Dialog is currently running: ${SD_VERSION}" fi } function install_swift_dialog () { # Install Swift dialog From JAMF # PARMS Expected: DIALOG_INSTALL_POLICY - policy trigger from JAMF # # RETURN: None /usr/local/bin/jamf policy -trigger ${DIALOG_INSTALL_POLICY} } function check_support_files () { [[ ! -e "${SD_BANNER_IMAGE}" ]] && /usr/local/bin/jamf policy -trigger ${SUPPORT_FILE_INSTALL_POLICY} } function create_infobox_message () { ################################ # # Swift Dialog InfoBox message construct # ################################ SD_INFO_BOX_MSG="## System Info ##<br>" SD_INFO_BOX_MSG+="${MAC_CPU}<br>" SD_INFO_BOX_MSG+="${MAC_SERIAL_NUMBER}<br>" SD_INFO_BOX_MSG+="${MAC_RAM} RAM<br>" SD_INFO_BOX_MSG+="${FREE_DISK_SPACE}GB Available<br>" SD_INFO_BOX_MSG+="macOS ${MACOS_VERSION}<br>" } function display_msg () { # Expected Parms # # Parm $1 - Message to display # Parm $2 - Button text # Parm $3 - Overlay Icon to display # Parm $4 - Welcome message (Yes/No) [[ "${4}" == "Yes" ]] && message="${SD_DIALOG_GREETING} ${SD_FIRST_NAME}. $1" || message="$1" if [[ "${MACOS_VERSION}" >= "15" ]]; then icon="/System/Library/CoreServices/Applications/Keychain Access.app" else icon="/System/Applications/Utilities/Keychain access.app" fi MainDialogBody=( --message "${message}" --ontop --icon "$icon" --overlayicon "$3" --bannerimage "${SD_BANNER_IMAGE}" --bannertitle "${SD_WINDOW_TITLE}" --infobox "${SD_INFO_BOX_MSG}" --width 760 --height 480 --ignorednd --quitkey 0 --button1text "$2" ) # Add items to the array depending on what info was passed [[ "${2}" == "OK" ]] && { MainDialogBody+='--button2text' ; MainDialogBody+='Cancel' ; } [[ "${2}" == "Restart" ]] && { MainDialogBody+="--timer" ; MainDialogBody+=$RESTART_TIMER ; } "${SW_DIALOG}" "${MainDialogBody[@]}" 2>/dev/null returnCode=$? [[ $returnCode == 2 || $returnCode == 10 ]] && cleanup_and_exit } function cleanup_and_exit () { [[ -f ${JSON_OPTIONS} ]] && /bin/rm -rf ${JSON_OPTIONS} [[ -f ${TMP_FILE_STORAGE} ]] && /bin/rm -rf ${TMP_FILE_STORAGE} [[ -f ${DIALOG_COMMAND_FILE} ]] && /bin/rm -rf ${DIALOG_COMMAND_FILE} exit 0 } function perform_reset () { typeset -i success_count && success_count=0 typeset -i fail_count && fail_count=0 # Close the Keychain Access app logMe "Closing Keychain Access application." pkill -x "Keychain Access" # Check if the target directory exists if [[ ! -d "$KEYCHAIN_DIR" ]]; then display_msg "Your personal Keychain does not exist in the expected directory!" "OK" "stop" logMe "Target directory does not exist. No actions were taken." exit 0 fi logMe "Creating a backup of User Keychain Files" mkdir -p "${KEYCHAIN_BACKUP_DIR}" cp -rf "${KEYCHAIN_DIR}" "${KEYCHAIN_BACKUP_DIR}" logMe "Starting cleanup of directories in $KEYCHAIN_DIR" # Find all directories within the target directory and delete them, logging each action find "$KEYCHAIN_DIR" -mindepth 1 -print0 | while IFS= read -r -d $'\\0' dir; do rm -rf "$dir" if [[ $? -eq 0 ]]; then logMe "Successfully deleted file / directory: $dir" ((success_count++)) else logMe "Failed to delete file / directory: $dir" ((fail_count++)) fi done if [[ $fail_count -eq 0 ]]; then display_msg "The keychain reset was successful. Your system must be restarted to finish this process. Restart will occur in $RESTART_TIMER seconds. After it restarts, you will need to run the 'Register with EntraID' from Self Service." "Restart" "computer" logMe "Initiating forced restart with $RESTART_TIMER second delay." shutdown -r now "Script-initiated forced restart." else display_msg "Errors have occured while trying to reset your keychian!" "OK" "stop" logMe "Cleanup completed with $fail_count failures. Restart aborted." fi } #################################################################################################### # # Main Script # #################################################################################################### autoload 'is-at-least' check_swift_dialog_install check_support_files create_infobox_message display_msg "If you are experiencing issues with items in your keychain, this utility will backup your current keychain and then reset it. <br><br>You will need to restart your computer after running this process." "OK" "caution" "Yes" perform_reset cleanup_and_exit
Screenshot of "Welcome" screen:
and the screen if everything was successful.  Timer can be changed inside the script..if you don't use Azure/Entra, you will need to change the message about run the register command...
1 reply
bwoods
  • 473 replies
  • March 31, 2025
Awesome implementation Scott!
Cookie policy
Cookie settings
