Hello folks,
any chance to run Jamf CLI commands like "sudo jamf policy" or "sudo jamf launchSelfService" from a bash script?
Thanks a lot|
Hello folks,
Thanks a lot|
Best answer by PaulHazelden
Try using the fullpath for jamf
/usr/local/bin/jamf
I have found some scripts fail until I use the full path to the command.
