Safari 16.5 for macOS Monterey and Big Sur
  • May 18, 2023
  • 84 views
sdagley
Here are the direct Apple CDN download links for the Safari 16.5 update released today (2023-05-18) for macOS Monterey and Big Sur:
Monterey: https://swcdn.apple.com/content/downloads/46/42/032-63972-A_STXDTZU8QO/q8fdl64hobp69ahribtrieag6r3086hvy6/Safari16.5MontereyAuto.pkg
Big Sur: http://swcdn.apple.com/content/downloads/27/11/032-63973-A_V5EERCMLQS/8uk80mv3nd7zt40dw3k8ok1vrynvytj2s0/Safari16.5BigSurAuto.pkg
The Safari 16.5 update for macOS Ventura is part of the macOS Ventura 13.4 update.
Note that I have not personally tested these installers as macOS Ventura is now the minimum support version of macOS for my org.
sdagley
  • May 23, 2023
For some reason I can't edit the original post, but I wanted to add that macOS Monterey 12.5 or later is required for the Monterey version of the Safari 16.5 installer (Thanks to @Michael11 on MacAmin Slack for doing the research on that)
whiteb
  • June 21, 2023
Thank you for posting these.
whiteb
  • June 24, 2023
I'd like to get SUPER all up and working and enforce Software Updates as well as Safari Updates.
Until that happens, can I make a Smart Group with Patch Reporting: Apple Safari less than: Latest Version and Computer Group member of Monterey or Big Sur, and then a single Jamf Policy targeting that smart group that runs a /usr/sbin/softwareupdate --install --safari-only --force
And would I still need to exclude computers that are 12.0 - 12.4?
