Script Parameter Variable while running command as currently logged in user
karthikeyan_mac
We are running into issue with Script Parameters while adding it with the script. It works fine if we call that in the script, but when I run any command as currently logged in user the parameter variable $4 does not work.
For Example
I am specifying the string "TEST" in Parameter 4 Not Labeled while adding the script. When I call $4 in the script directly it works, but I need to run a command as currently logged in user. When I echo $4 as currently logged in user, its blank.
My Script is to send an email based on the Script Parameter specified at Paramater 4($4).
echo $4 # this echoes "TEST"
LOGGEDUSERS=`who | awk '/console/ {print $1}'`
su -l $LOGGEDUSERS -c 'echo "$4 Contents" | mail -s "Success" admin@test.com'   # this triggers the mail but $4 value is blank in email
Is there any way to call the script parameters while running the command as logged in user?
Regards,
Karthikeyan
Best answer by mikedodge04
I'm not sure why you would be using this, more context would be helpful. But the reason that $4 is not getting passed is because you had it wrapped in single quotes ''. Variables don't get evaluated within single quotes. If you see below I close the single quote, wrap the variable with double quotes, used the variable, and then restarted the single quote with no spaces.
su -l $LOGGEDUSERS -c 'echo "'"$4"' Contents" | mail -s "Success" admin@test.com'    # this triggers the mail but $4 value is blank in email
  • 7880 replies
  • August 14, 2013
Without testing it out I can't be sure, but you may need to use the launchctl bsexec trick here. I've had to use some code posted by others here on JN on several occasions with scripts I've written that needed to do something as the user. It seems as we moved toward Lion and Mountain Lion this need increased, since Apple added a lot more sandboxing to the OS, preventing processes from running commands as another user without going through some hoops.
Totally untested, so may be off, but just a quick idea below-
LOGGEDPID=`ps -axj | awk "/^$LOGGEDUSERS/ && /Dock.app/ {print $2;exit}"`
/bin/launchctl bsexec "${LOGGEDPID}" sudo -iu "${LOGGEDUSERS}" "echo "$4 Contents" | mail -s "Success" admin@test.com"
I'll be curious to hear if something like that helps in this case.
Slight Edit- escaped the double quotes within the command.
  • 6 replies
  • August 14, 2013
karthikeyan_mac
  • 281 replies
  • August 15, 2013
Thanks Mike. Adding the quote to variable specified you works fine.
Cookie policy
Cookie settings
