Script to allow non-admins to use Xcode with Bash and AppleScript. May have other uses.
  • August 28, 2017
  • 0 replies
  • 22 views
Greetings from the cornfields!
I recently came across a security concern where our tech support folks were adding interns to the local admin group on developer machines in order to use Xcode and interact with the system. Not exactly appropriate on multi-user Macs.
Apple has a method of allowing non-admins to use Xcode with the Developer Tools group (aka _developer) on the local DS. In the spirit of Self Service, I wrote the following to help users help themselves in this particular situation. I have it scoped to Macs with Xcode installed, but there could be other ways (static groups by request, etc.) that will display the policy. You could also use the Script Options and JSS variable to re-use the script for other local groups, but be careful as it could be used to add someone to the local admin group.
Uses bash to perform the actions and AppleScript to interact with the user at the Desktop.
# Add users to local _developer group for XCode
# This group is displayed as Developer Tools
# in the Directory Utility
# 2017 - Frank Wolf
# Variable Index
# $doWhat - add delete or cancel
# $addDev - accountname to add
# $delDev - accountname to delete
# $areWeDone - do it again or done
areWeDone=0
# Functions
ask_User() {
doWhat=$(osascript <<- doThis
tell application "Finder"
    activate
    display dialog "Do you want to add or remove users for the local Developer Group" buttons {"Add", "Remove", "Cancel"}
    set doWhat to (button returned of the result)
end tell
return doWhat
EOF)
add_User() {
addDev=$(osascript <<-addUser
    activate
    set devUser to display dialog "Please enter the developers username." default answer ""
    set addDev to (text returned of devUser)
end tell
return addDev
EOF)
delete_User() {
delDev=$(osascript <<- delUser
        set Sources to the words 2 thru -1 of (do shell script "dscl . -read /Groups/_developer GroupMembership")
            if Sources = {} then
                display dialog "No users in local Developer group"
                set delDev to choose from list Sources with title "Remove Developer Users." with prompt "Select the Users to remove." & return & return & "Use the Command key for multiple Selctions" OK button name "Next" cancel button name "Cancel" with multiple selections allowed
            end if
end tell
return delDev
EOF)
ask_Continue() {
areWeDone=$(osascript <<- doThis
    activate
    display dialog "User added or removed from local Developer group." & return & return & "Would you like to add or delete another user? " buttons {"Yep", "Nope"}
    set areWeDone to (button returned of the result)
end tell
return areWeDone
EOF)
# Main Script
echo "Welcome fellow Program"
echo "Starting add developer script"
# Keep prompting until user is finished
while [ $areWeDone != "Nope" ] ;
do
#   Call ask function to  get operation
    ask_User
    echo $doWhat
    case $doWhat in
        #Add
        "Add")
            echo "Adding user"
            add_User
            echo $addDev
            dscl . append /Groups/_developer GroupMembership $addDev
            ask_Continue
        #delete
        "Remove")
            echo "Deleting User"
            delete_User
            echo $delDev
                for devName in $delDev
                    do
                        dscl . -delete /Groups/_developer GroupMembership $devName
                    done
            ask_Continue
            echo "User canceled"
    esac
done
echo "We are done here."
