Hi All,
I recently transitioned our imaging workflow from an OS packaged with composer to an installer created with autoDMG. I am using part of Rich Trouton's first run script to set up the WiFi. This results in the wifi being *almost* set up properly - it works everywhere except at the login window.
I installed 10.9.2 from the restore partition and found that the AirPort Network password keychain was granting access to /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Resources/updatesprefs. I manually granted the AirPort keychain access to this application on one of my imaged machines and the wifi stays enabled at the login window.
Anybody familiar with the command line interface for modifying the keychain? I found some info on extracting passwords, but none on modifying access control.
Thanks in advance
