Script to write Extension Attribute?
  • 50 replies
I know you can include a script in the Extension Attribute section but can you also write to an Extension Attribute directly from a policy? If so, example? Thanks!
Forum|alt.badge.img+19
  • 582 replies
  • November 24, 2020
No, not directly. But as a work around, you could have your script write a file to the computer in a tmp directory and then have your EA script read that file and return that as the EA.
  • 50 replies
  • November 24, 2020
@RBlount Yeah, that's what I had but wondering if there was a better way. Thanks!
  • 140 replies
  • November 24, 2020
You can write to an EA using the API.
Cookie policy
Cookie settings
